Need help, HP omen ax236tx , no boot capslock blink 5long 3 short
  • stingerchamp
    • Sep 2020
    • 425
    • Pakistan
    Hi Everyone,
    Need Help
    HP omen laptop after bios update from F48 to F55 , laptop stop booting and giving caps lock led blink error 5 long and 3 short
    Following checked and still getting error caps lock blink 5 long 3 short
    1- RTC battery removed and waited 30min and again inserted.
    2- RAM memory Gold contacts cleaned and reseat.
    3- Power hard reset: Battery and cmos cell removed and checked
    4- Bios bin flash with working bios
    Need help to diagnose the issue
  • stingerchamp
    • Sep 2020
    • 425
    • Pakistan
    Re: Need help, HP omen ax236tx , no boot capslock blink 5long 3 short
    Hi
    i am facing issue of no display on my laptop , i have gone through many steps as mentioned in above posts but recently i found something strange when i open laptop cover.
    Can anyone tell me whats wrong with this COIL , i noticed this and took a picture
    It is a coil for bulk convertor +1.0Vs5_s2 near RAM slot
    • stingerchamp
      • Sep 2020
      • 425
      • Pakistan
      Originally posted by stingerchamp
      Hi
      Any help here????
      • stingerchamp
        • Sep 2020
        • 425
        • Pakistan
        Hi
        Can anyone tell me whats wrong with this COIL by, i noticed this and took a picture ,
        It is a coil for buck converter +1.0Vs5_s2 near RAM slot
        is this coil ok.
        • Techtiger
          • Oct 2014
          • 1602
          • france
          How did you flash BIOS & what are the Voltage missing on the coils ?
          • stingerchamp
            • Sep 2020
            • 425
            • Pakistan
            I flashed the bios chip using Ch341a programmer black one that usb type hardware thing using clip adapter soic8. i did not check any voltages yet.
            is there anything wrong with it?
            • Techtiger
              • Oct 2014
              • 1602
              • france
              Check all voltages now DRAMRST / SYS_PWROK
              • stingerchamp
                • Sep 2020
                • 425
                • Pakistan
                Hi
                First of all thanks for your kind help
                Kindly share in detail as i am unaware of the pin number for DRAMRST signal and SYSPOWEROK signal, should i check it on memory slot pin 108 or at PCH pin (dont know) and i am also attaching memorystick and memory slot pic for your reference.
                I am not sure if the above schematic is valid for Quanta G35D rev D
                • stingerchamp
                  • Sep 2020
                  • 425
                  • Pakistan
                  Hello
                  • Techtiger
                    • Oct 2014
                    • 1602
                    • france
                    Hello
                    follow the Schematic what are the Voltages mising on the BIG GRAY COILS PL9017 ect then we will move forward
                    • stingerchamp
                      • Sep 2020
                      • 425
                      • Pakistan
                      hi,
                      capslock is not flashing anymore but still no image and no backlight( no display) black screen.
                      update: first i checked laptop charger volts 19v found then i tried to check coil voltage while laptop was on and power button pressed , laptop suddenly stopped and now there is no light on power cable and neither power button is working anymore
                      • Techtiger
                        • Oct 2014
                        • 1602
                        • france
                        what is the voltage on PQ1002 it's a 5 leg Mosfet check the voltage on pin 3 4 5 & find out the Coils PL2003 PL2004 voltage ? near the dc connector do you get the white or blue light ? did you accidentally short middle pin of the charger with the inner outer layer ?
                        • stingerchamp
                          • Sep 2020
                          • 425
                          • Pakistan
                          hi , i was getting white led light at charging port now laptop does not have led light and not power on. i have checked charging cable plus adapter it is giving 20 volt constant is it ok?
                          should i check voltages while adapter plugged in or without?.
                          notable thing: led light thing happend when i was checking with only laptop cover removed and everything inside except battery(which is dead replacement is under process) and hard disk removed and cmos battery still inside the laptop. i did not notice maybe the cable touched the outside metal of the hinge (i did not removed hinge) plus laptop power button was on with light led before i heard a simple click and light off.
                          • stingerchamp
                            • Sep 2020
                            • 425
                            • Pakistan
                            Hi
                            This motherboard has lot of caps and two coils PL1002,PL1003 and also
                            PL2003 coil is absent ( empty space )
                            here are the readings
                            charger pin is fine but no white light at port
                            charger CN1001 pin 1,2 ,3= 20volts
                            pin 3,4 of PQ1002 = 19volts
                            pin 5 = 19 volts( +VA)
                            PD1002 : pin 1 = 19 volts (+VAD)
                            PL2001 : pin1 and pin2= 0volts
                            PL2004 : pin1 and pin2= 0volts
                            PL6001 : pin1 and pin2= 0volts
                            PU3002: pin 3 , 4, 5, 6 = 0 volts
                            RTC battery =3volts
                            jumper j1 pin1 (RTC_RST#) = 3volts
                            R138 resistor pin1 (+ 3v_rtc_0) and pin2 (+ 3v_rtc_1) = 3volts
                            pin 1 diode D1 = 3volts
                            what to do next
                            • stingerchamp
                              • Sep 2020
                              • 425
                              • Pakistan
                              hello
                                • 21889
                                test voltage on R5117 ,PR1021
                                • stingerchamp
                                  • Sep 2020
                                  • 425
                                  • Pakistan
                                  R5117
                                  pin1: 1 volt
                                  pin2: 1 volt
                                  PR1021= 0volt on both pins
                                  pr1057= 0 volts also
                                  all grey coils have 0 volts
                                  • stingerchamp
                                    • Sep 2020
                                    • 425
                                    • Pakistan
                                    Hello
                                    Need help, ALL big coils have 0 volts. should i check charger IC pins?
                                    • mcplslg123
                                      • Jun 2015
                                      • 7262
                                      • india
                                      PQ1002-You are getting 19V at gate and that;s the problem.PIN 1/3/4/5/6 voltage?? Measure PQ1004 and see if it is working or not.
                                      • stingerchamp
                                        • Sep 2020
                                        • 425
                                        • Pakistan
                                        Hi
                                        I checked again for all measurements
                                        connector charger voltage CN1001 : pins 1,2,3=20volts
                                        cn1001: pin8=1volt
                                        cn1001 : pin9,10:led1,led2 = 0volts
                                        PC1002: pin2 (j1_1) = 20 volts
                                        PR1009 : pin1=19volts ,pin 2=20 volts
                                        PR1021: pins 1,2= 0 volts
                                        PR1012: pin1=2, 19 volts
                                        PR1007 :pin1= 19 volts
                                        PR1006 :19volts both pins
                                        PR1005 = 18volts
                                        PQ1004 :pin 1,2= 19 volts , pin3 =18volts ,pin4=19 , pin 5,6=19 volts
                                        PC1004=20 v
                                        PQ1002: pin1,2,3=19 volts , pin4 =18 volts , 5,6,7,8 pins= 19 volts
                                        PD1007: pins1,2=19 volts
                                        PD1002: pin1=19 volts
                                        PR1038: 19 v (va_air) pin1 , pin2=1volt(ad_air)
                                        PR1041:1volt pin1 and pin2=0
                                        PC9110 : pin1=0 volts
                                        PR1008 : 0 volts both pins big fuse
                                        PC1020: pin 2= 6volts reg6v
                                        PR1032: pin1= 3volts Vacdet
                                        PC1018:CSIP=0v , PC1013:csin=0v
                                        PC1008=19volt
                                        PQ1003: pin1,2,3=0volts
                                        PQ1003:pin5= 19volts
                                        help
                                        • questore
                                          HP OMEN 15-ce012nh give error code 5long 3 short after CPU LOW SIDE MOSFET BURN
                                          by questore
                                          Hello everyone.
                                          Someone brought this poor hp in.
                                          All power rails had normal resistances so i turned it on. Instant power cutoff...
                                          First mosfet was shorted so replaced it...
                                          After that I have tryed to start since no short was on the main power rail. the CPU middle dual mosfet heated up and protection shut down the laptop.
                                          After investigating i have found that when the mosftet turning on then the mostfet got instantly hot (not the CPU)
                                          Removed the faulty mosfet. -> now laptop turns on CPU mildly gets hot but laptop gives the common 5 long 3 short LED...
                                          08-25-2025, 10:09 AM
                                        • Tom_x
                                          HP Omen 15-dc0001nh capslock blinks 5 long and 3 short
                                          by Tom_x
                                          I have HP Omen 15-dc0001nh (DA0G3DMBCE0 rev: E) with blinking capslock 5 long and 3 short. Fans spin constans speed.
                                          HP worked for 2 months after i repaired (before damaged by thunder via rj45 port) I removed LAN ic and powered on
                                          Now with blinking capslock:
                                          All voltage present on big coils, except +VCCGT (i don't know this need for booting)
                                          I tried re-flash bios with known firmware- same result (now i don't have spare bios chip to test spi flash failure)
                                          DDR4 ram is ok, tested on other laptop
                                          WLAN and SSD removed,...
                                          07-20-2023, 10:10 PM
                                          HP OMEN OMEN by Desktop PC - 870-128na OMEN 870 i7-6700 Specification for Upgrade or Repair
                                          This specification for the HP OMEN OMEN by Desktop PC - 870-128na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN OMEN by Desktop PC - 870-128na boardview and OMEN OMEN by Desktop PC - 870-128na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-12-2024, 03:44 PM
                                          HP OMEN X OMEN X by Desktop PC - 900-077na OMEN X i7-6700K Specification for Upgrade or Repair
                                          This specification for the HP OMEN X OMEN X by Desktop PC - 900-077na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN X OMEN X by Desktop PC - 900-077na boardview and OMEN X OMEN X by Desktop PC - 900-077na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                                          HP OMEN X OMEN X by Desktop PC - 900-010 OMEN X i7-6700K Specification for Upgrade or Repair
                                          This specification for the HP OMEN X OMEN X by Desktop PC - 900-010 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN X OMEN X by Desktop PC - 900-010 boardview and OMEN X OMEN X by Desktop PC - 900-010 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
