Puzzling - Toshiba 49L621U Good backlight
  • jason123
    • Oct 2015
    • 1135
    I see many posts about this TV and I'm puzzled by this one.
    I got this TV with no backlight. I used a tester and sure enough one string was open.
    This TV has 3 strings, each with 4 strips and 7 LEDs each (28 LED per string)
    I found 1 bad LED in one string and replaced it, as the strips are not available new.
    Tested all the strings with tester. all checks out. Buttoned it up. TV only flashes bright light upon pluging in AC once and that's it.
    Opened it up again. Used my home-rigged 200 V setup. Started with current limit of 107 mA all pass. increased to 161 mA - all pass. Now I'm trying to break something so I went to 322 mA - and all pass.
    I was testing a string at a time (200 V - 3V*28 = 116V across)
    where do I go from here? Any suggestion would be appreciated.
    Photos Uploaded
    On P803 (Power to LEDs)
    VLED+ (referenced to Chassis) goes up to 105 V then down to 65 and slowly discharge
    VLED3- and VLED2- goes to ~6 V or so, then discharges to 4.5 V then slowly discharge
    VLED1- goes to ~5.8V but almost instantaneously discharges to zero V
    On the connector that goes to the main board, all voltages seem present and good
    Pin 1 = 15.89 V (16V2)
    Pin 2 = 15.89 V (16V2)
    pin 3 = 15.89 V (16V2)
    Pin 4 = GND
    Pin 5 = GND
    Pin 6 = 15.89V (16VA)
    Pin 7 = GND
    Pin 8 = 15.89 V (16V2)
    pin 9 = GND
    Pin 10 = 5.02 V (5V1)
    Pin 11 = 3.32V (ACD)
    Pin 12 = 3.98 V (PWON)
    Pin 13 = 3.20 V (BLON)
    Pin 14 = 5.02 V (5V1)
    Pin 15 = 0.899 V (DIM)
    Re: Puzzling - Toshiba 49L621U Good backlight
    Show us good clear pictures of the backside of the TV showing all the board, then good clear straight shots of the whole power supply LED driver top and bottom side.
    What Voltage testing have you done so far?
    • jason123
      • Oct 2015
      • 1135
      Let me know if you need a closeup of anything, or better shots
        "I was testing a string at a time (200 V - 3V*28 = 116V across)"
        Please clarify that.
        3V x 28 LEDs = 84 total Vf for the string.
        116V across what?
        • jason123
          • Oct 2015
          • 1135
          Hopefully this helps clear it up
          200VDC source
          Series R 1k or 720 or 360 ohm
          Across led string (4 strips- 28 LEDs )
          Actual measured voltage is 92 across the LEDs
          • Diah
            • Feb 2013
            • 6498
            again we are at topic LEDs ... they are working together as currents forward not V. !! which type of LED build in the string? i guess yours replacement LED didn't match the CF
              200VDC source
              92V/28 = 3.28V
              As you can see in the graph, the higher the current the higher the Vf as to be expected.
              • jason123
                • Oct 2015
                • 1135
                Yup, makes sense budm
                The LED tester is giving very similar voltage reading on the original strips vs. the strip that I changed the one LED on.
                So, I can't sleep and naturally what do you do when you can't? you fix TVs
                I was searching on youtube and found a video (Toshiba 49" TV, no backlight, 1 Flash only. LED feedback circuit repair) by "bigdog8882" that solved my issue.
                Sure enough R585 was reading about 4k instead 100 ohms. Replaced and TV fired right up.
                Not sure I can share a link to the video here, but you can see search for it. Thanks for the help folks
                  Glad to hear you found the root cause of the problem.
                  Can you show me where the location of the R585?
                  BTW, what is the P/N of the LED driver IC?
                  Also make sure to turn down the backlights level on all input mode to as low as possible to extend the life of the LED's.
                  You can post Youtube link here.
                  • jason123
                    • Oct 2015
                    • 1135
                    Hi budm
                    The resistor is right to the left of the 2 caps below the FETS
                    See picture
                    Here is the video
                    https://m.youtube.com/watch?v=oFFMpmak2cI
                    Unfortunately the TV is back with its owner (my 70 year young neighbor) and i no longer have access to get part number. Sorry
                      Hi budm
                      See picture
                      Here is the video
                      So one of the Resistor for the PWM controlled MOSFET for VLED1 (one of the three PWM controlled MOSFET's, One Boost converter) for controlling the constant current is bad..
                      Thanks for the info.
                      So the measurement in your post #1 gives us the clue:
                      Photos Uploaded
                      • jason123
                        • Oct 2015
                        • 1135
                        I knew that indicated something, but I wasn't sure what
                          09-06-2024, 05:27 AM
                          09-06-2024, 05:59 AM
                          Toshiba Satellite L635-10K Notebook Specification for Upgrade or Repair
                          This specification for the Toshiba Satellite L635-10K Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L635-10K boardview and L635-10K schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...
                          Toshiba Portege Z30-C Notebook Specification for Upgrade or Repair
                          This specification for the Toshiba Portege Z30-C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Z30-C boardview and Z30-C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba Portege...
                          09-06-2024, 05:33 AM
