LC42D62U All UCC capacitors power supply.
  • Wizard
    • Mar 2008
    • 2296
    All capacitors on SMPS board checks out fine, what bought standby power supply down was a small diode on hot side from standby transformer for standby SMPS IC shorted out. This diode is filtered by a small capacitor. New diode bought standby back alive, was flubbing.
    But the processing quality and too much judder makes me still uninterested about Sharp's line especially I had a LC40LE700UN returned for credit so I'll wait for new line of Samsung TVs in March.
    Cheers, Wizard
    Panasonic switching power supply daughter board has two 27uf @ 50 volt capacitors which I do not keep in stock
    by sam_sam_sam
    I did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
    This is one of the shit est boards I seen in a very long time and it was the daughter board the traces just lifting off the board I had to use the capacitor leads to repair the the traces and the main board is not any better because I had to repair several traces for the daughter board to the main board
    After all of...
    07-13-2024, 08:14 PM
  • tvguy12012012120
    by tvguy12012012120
    02-07-2025, 05:13 PM
    Mitsubishi CNC switching power supply board dead / relay board bad diode failure
    by sam_sam_sam
    I was working on this CNC machine today found no keyboard functioning no control relay powering on
    The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
    Found shorted diodes on main controller relays there are 3 of them that...
    01-07-2023, 05:43 PM
  • Yanleb
    UN65MU6300FXZC, no standby LED but power supply good. Bad IC1604 25Q40?
    by Yanleb
    My UN65MU6300FXZC is dead and the standby LED stays off. The power supply is good. The main board is BN94-12434A.
    Disconnecting the main board from the power supply makes the backlight come ON.
    I did disconnect the panel cables and the WIFI modules, the board is still dead.
    I did read in many posts that IC1604 25Q40 becomes corrupted. It has proper 3.3 volt on VCC pin 8. I did read that if I post its dump here someone can fix it. Is that right?
    Thanks.
    11-18-2024, 12:34 AM
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
