hp dv6-6c03st bios
  • asliyucegsm
    • Jun 2011
    • 349
    • Turkiye
    hp dv6-6c03st bios
    my friend
    ec and bios
    dv6-6c03st
    11a67-2 48.4rh12.021
    PCB:HPMH-41-AB6200-F00G
    PWA:HPMH-40GAB-00-F
    thanks
    • 21573
    Re: hp dv6-6c03st bios
    Bios + EC extracted from HP bios update sp59755
    • fcelikel
      • Jan 2019
      • 13
      • türkiye
      teşekkurler / Thank you
      • mikeybass
        Dell 9010 MT BIOS Update Always Fails
        by mikeybass
        Hi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
        04-23-2025, 04:30 PM
      • akwky
        by akwky
        Hi!
        04-14-2025, 01:56 PM
      • al3m0di
        Update bios EFCN58WW to EFCN59WW
        by al3m0di
        Update bios EFCN58WW to EFCN59WW for solving The Connected AC adapter has a lower wattage than the recommended AC adapter
        I have a Lenovo Legion 5 15imh05a device that I bought used online. It came with a 20V 8.5A 170W charger.
        The BIOS version is EFCN58WW.
        When I turn on the device, it displays the message:
        "The Connected AC adapter has a lower wattage than the recommended AC adapter..."
        The device rarely charges the battery, and even when it does, it doesn't show that it's charging.
        I've tried
        07-29-2024, 10:32 AM
      • 0xx
        2022 Razer Blade 14 (RZ09-0427) won’t boot after Windows update, only the green LED blinks - overheated or BIOS?
        by 0xx
        Hi folks,
        My son clicked “Update and Shutdown” on a Razer Blade 14 (2022, RZ09-0427), closed the lid, disconnected the charger, and put the laptop in his backpack. The next day, it wouldn’t boot: only the green LED blinked, no fans, no keyboard backlight, no display. The chassis does get warm, so the CPU/GPU seems to get power.
        What I’ve tried so far: disconnecting the main battery, CMOS reset with power drain (30s), using a different power adapter, and connecting to the monitor - same result.
        I assumed that Windows Update was interrupted due to closing...
        09-14-2025, 03:46 PM
      • Julian Bailey
        BIOS update wont complete - Dell Latitude 7420
        by Julian Bailey
        Hi all
        Anyone come across this issue where a BIOS flash will only part complete?
        It will update the system BIOS and Primary EC BIOS fine but fails to update the Intel TBT Retimer, Intel TBT Retimer 2 and ME Firmware.
        NVMe m.2 drive isnt detected in the BIOS, but you can get into the BIOS fine and it all works in there as intended.
        The drive works fine in another laptop.
        Link to a video I made of what its doing here:
        Any ideas on how to overcome this?
        Cheers...
        06-02-2025, 01:39 PM
