Replacing LGA CPU sockets
  • dicky96
    Sun Seeker
    • Mar 2017
    • 1825
    • Spain
    I've tried this several times but I just seem unable to solder the new LGA socket.
    I have no problem removing the old socket with broken pins, but using the same profile (or a bit hotter one) to fir the new socket results in a socket that is firmly attached to the board but just using the multimeter and checking continuity between Vcc pins (or ground pins) it is obvious the new socket is not soldered properly. I find maybe the outer pins and the next row may solder but not the inner ones and not all around the socket either
    I've tried about half a dozen times now on various boards with various profiles and get the same result
    I am using the technique - remove old LGA1151...
    clean PCB with leaded solder ball and then braid
    use paintbrush to apply this layer of Amtech 559 to the PCB
    use optical alignment to set the socket position
    solder
    I've now come across this other method, on a very similar machine to mine, where they don't use flux, not any that it mentions anyway, and use a stencil and solder paste instead
    https://www.youtube.com/watch?v=zEPNmOXjy4Y
    Has anyone tried this method, and did it work?
    Rich
    Follow me on YouTube
    Learn Electronics Repair
  • dicky96
    Sun Seeker
    • Mar 2017
    • 1825
    • Spain
    Re: Replacing LGA CPU sockets
    Hmm well it seems I am pretty much on my own with this one then - I've ordered a direct heating 1151 stencil so I can try this for myself.
    For sure the method I am currently using does not work
      • 22119
      What sort of nozzles do you have,are the ones with "nets" better for a more even airflow .
      • dicky96
        Sun Seeker
        • Mar 2017
        • 1825
        • Spain
        The bottom nozzle has the 'net' or mesh, but the top one does not
        • dellxps15
          • Feb 2014
          • 1598
          • italy
          sorry for the late answer.
          1) always use flux.... a good one.... without flux u wont be able to remove the socket even at 245°.
          2) when lifting the socket use 2 tweezer... one on the right one on the left and lift it as much clean as possible
          3) make picture of the pads on mainboard after socket lift..... are all pads with same amount of residual solder?
          if when u lift the socket all pads had same amount of solder on them... then the temperature is right.
          bebore solder new socket, check if pcb is 100% in orizontal position and pcb didnt make any curve.
          if pcb is good, profile is good ( dont go too fast with temperature ... i take approx 7-8 minutes to remove the socket with an ir rework station.) cover also the capacitor near the socket ( generally they are in 3-4 side) cover with one strip od kapton and one of alluminium. it happened on first try that some of those can explode if u dont cover them properly.
          if mainboard didnt get any damage from booting with shorted pins, u can make it work again.
          look in the picture how much flux i use for removing the socket. when i solder it back i apply just one thin layer on the pads with a brush.
          look also the residual solder on pads after removing the socket... all have same amount.
          edit: i forgot to mention that old socket dont have any support to prevent socket touch the pcb, while all new socket have them... so if pcb is not perfect straight, it wont solder some ball because that spessor wont allow the socket to touch properly the zone.
          • re-atari
            Gigabyte GA-H110-D3A schematic/boardview needed
            by re-atari
            Hello all,
            Does anybody have a schematic and/or boardview of the Gigabyte GA-H110-D3A mainboard available? It would really help me out big time...
            This board was donated to me in a known non-working state. In its previous life it was used as a mining board, so I suspected bad caps and a relatively easy fix. My intention is to use the fixed board as a testbed for a Truenas or Unraid build. The previous owner told me that the mainboard started to act 'weirdly' after replacing the originally installed Celeron for an i5-6400, varying from starting up irregularly to not at...
            02-24-2025, 06:45 PM
          • langbaobao
            DIY 3D-Printer WSON8 Pogo Pin Adapter
            by langbaobao
            Hi.
            I'm posting this here in part as a memo to self as well as to describe the procedure I used in case anyone else found it useful. I found a lot of the necessary information to make this work on this forum and I figured I would give something back. If this is not the appropriate place to post this, I don't mind it being deleted but I hope it can help other people.
            I got an admin password locked HP Elitebook 840 G5 recently that I wanted to unlock. I'm a relative newcomer to reprogramming and unlocking firmware. The only previous experience I had was unlocking a BIOS...
            01-08-2024, 05:58 PM
          • testaccgta
            Unable to verify IC or write/erase/flash BIOS file to XMC QH128AHIG SPI chip using NeoProgrammer/AsProgrammer
            by testaccgta
            Hi, everyone!
            I've recently acquired two brand new SPI chips to replace the one currently in my Acer A514-54G laptop MB (FH5AT LA-K092P). The reason why I'm replacing the current SPI chip is because I had some difficulties with a third-party IT assistant who pretty much lacked the soldering skills and ended up destroying the current SPI chip soldered to my MB from factory.
            I've decided to do this on my own because I spent the past month or so learning some soldering skills and BIOS modding through Badcaps and WinRaid forums, hence the attempt. I've also chosen to buy...
            09-01-2024, 08:24 PM
          • petemanuk
            BGA solder balls not connecting - help pls
            by petemanuk
            So I though in my spare time I’d set myself up repairing motherboards mainly pin damaged lga1151 sockets types.
            I’m using an achi ir sc pro rework station (gave up on my Achie ir6500 - don’t recommend)
            I’ve managed to get my rework profile somewhere in the correct region (after a lot of trial and error) to get the old sockets off and reflow new ones back on again, the problems I’m getting is not all of the solder balls are re-attaching when re-flow occurs. I know this because when socket is removed pads still look clean and have no solder...
            11-16-2022, 05:21 AM
          • acedogblast
            by acedogblast
            11-02-2024, 05:13 PM
