Component ID and Replacement
  • StephenU
    • Dec 2013
    • 230
    • United Kingdom
    Hi all, looking for some help on replacing a part on a TV board. Part looks to be a Polypropylene Cap although I'm unsure. I have attached a picture of the damaged part for reference if anyone could help me source a replacement part it would be much appreciated.
    Also what would cause this type of failure other than possible handling damage?
    Markings indicate 2.2uF 250v - but struggling to find one online.
    Thanks in Advance
    S.
    • 30991
    Re: Component ID and Replacement
    https://uk.rs-online.com/web/p/polyp...itors/1262255/
    https://uk.rs-online.com/web/p/polyp...itors/1719221/
    https://uk.rs-online.com/web/p/polyp...itors/8712455/
    easy to find - what's the space between the pins??
    • StephenU
      • Dec 2013
      • 230
      • United Kingdom
      Thanks for the quick reply, I had checked RS but was looking for one that looked the same to the one fitted to the board, would the ones you have linked do the job? I'm unsure of the space between the pins I will need to measure this later on this evening.
      S.
        • 30991
        check pin spacing - it's gonna be the decider.
        as for looks, cheap crap is dipped - like yours.
        better ones are potted in plastic boxes for extra safety.
        • StephenU
          • Dec 2013
          • 230
          • United Kingdom
          Hi stj, does this part look like a Polypropylene or a Polyester? Pin spacing is 10mm measured.
          Thanks in advance.
          S.
            • 30991
            you cant tell if it's polyester, polypropylene or polystyrene by looks - they are just different plastics.
            you have to look at the markings or what it does.
            (or find a schematic)
            what is the tv board?
            • StephenU
              • Dec 2013
              • 230
              • United Kingdom
              Hi the component is C201 on X-SUS BOARD TNPA5623 of Panasonic TX-50UT50B plasma TV.
                • 30991
                well maybe someone can post schems or a service manual.
                • R_J
                  • Jun 2012
                  • 9535
                  Here is the Panasonic part number: F0C2E225A286, The Panasonic schematics are poor quality you can't make out the values.
                  TC-P50u50 chassis gpf15du has the same caps
                  Seem to be CBB21 Metallized polypropylene film capacitor. (CBB21 is a material type, defined by factory)
                    • 30991
                    this is the best i can see.
                    https://uk.rs-online.com/web/p/polyp...itors/7270164/
                    • StephenU
                      • Dec 2013
                      • 230
                      • United Kingdom
                      Many thanks R_J and stj, will follow up on these and hopefully can revive the TV.
                      • StephenU
                        • Dec 2013
                        • 230
                        • United Kingdom
                        Ordered up a couple of these and they work as ideal replacement, many thanks stj
                          • 30991
                          good, another fix complete.
                          • the_rem
                            Unknown transformer : how to find a good replacement part ?
                            by the_rem
                            Hello guys,
                            I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
                            I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
                            04-23-2025, 01:48 AM
                          • FreakyMex
                            Trouble to identify part (Lunii screen) for replacement
                            by FreakyMex
                            Hello guys. I'm a complete noob in electronics. I'd like to repair my child Lunii's (a "story box"), basically an audio player that allows the childs to choose between several options the places, characters, objects of the story, and then play a story according to the choice of the child. There is a screen that display the selected option before each choice. The Lunii fell and the screen is now broken.
                            I'd like to repair it (probably just have to change the part, because the lunii still works perfectly fine) but I can't manage to identify the part/order it online. Do you have any...
                            02-17-2025, 01:16 AM
                          • edugimeno
                            Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
                            by edugimeno
                            Hi There!
                            I'm trying to help my friend who owns a restaurant be just bought.
                            He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
                            It's stuck using, I guess, the 2 sided tape that comes with the strip
                            The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
                            09-05-2024, 09:34 AM
                          • G-Sting
                            iPad Pro A1876 SHORT Part Identify Help Needed
                            by G-Sting
                            So My iPad was not charging and booting up . i went to a local technician and he checked with thermal and this Part marked in 1st Photo is Short.
                            So then i went on to boardview and downloaded the schematics and identified this part in 2nd Photo. Now i am confused what exactly is the part called ? where should i get this from ?
                            i contacted my technician and he sent me his BoardVIew screenshot in 3rd Photo. In his Boardview the part is called X2826.... Something
                            SO My main concern is what part should i order what should i search the name for ?
                            on Ipad...
                            05-15-2025, 09:30 AM
                          • Cvrado
                            Led TV Board Replacement, same part number and model, different size
                            by Cvrado
                            Hello my friends!
                            I have a question that I think you can answer and help me with!
                            I have a faulty main board from an led TV. And I found the same part number board and design but is from a 43" TV and I want to use it on a 65". On its stickers , all are the same except the wattage for the LEDs backlight, both state different watts and LED Voltages!
                            So I presume that the backlight inverter section from the replacement board has lower wattage then the original one, am I right?
                            My concern is that the board won't draw enough voltage to the bac...
                            03-02-2024, 05:05 PM
