Samsung Q1 - display flat cable "unglued" pins
  • selfrepairing
    • Aug 2019
    • 18
    • serbia
    Hello people, this is my first post. I am completely amateur in this field, but I am trying to fixing this and that.
    I have few old pcs running win xp and this samsung is great little device among them. but, I tried to fix power jack and managed to run it for a few minutes. after that laptop was dead, again. trying to find what the heck is a problem now, disassembling it, i found, also, this additional problem:
    pins on flat cable was "unglued"... strange but, this is what it is. anything I can do with them, or to wait a month for a aliexpress 20pin flat cable to arrive....
    I thought to use microscope and carefully glue them back. also thought to cut end by around 1-2 millimeters after that.
    thank you.
  • peste
    • Dec 2016
    • 12748
    • ROMANIA
    Re: Samsung Q1 - display flat cable "unglued" pins
    https://www.youtube.com/watch?v=SNOzbpfSpec
    • lijs
      • Aug 2019
      • 2
      • Worldwide
      • selfrepairing
        • Aug 2019
        • 18
        • serbia
        Originally posted by lijs
        i will try lijs because i do not have hot air gun. that was my thought, but as i saw stripping can be very tricky. anyway, nothing to lose. thank you people!
        • R_J
          • Jun 2012
          • 9535
          Digikey also carries these FFC/FPC cables https://www.digikey.ca/products/en/c...per-cables/457
            09-07-2024, 05:50 AM
          • marce002
            Help me make charger USB C cable with no cc pins!!
            by marce002
            Hi all, please
            I just want to make a "usb c" charging cable from 5V power supply (have cut cable w/ red black green and white pins connected from factory.... i just want to use 500mah max !
            How do I connect this ? if I do not have CC1 /2 physically wired, how to proceed?
            NOTE: an identical new (not cut) USB A to USB C cable charges my phone but not the remote control!
            here is a picture of the remote, the cable to be used and a picture of what are the factory connected pins
            thanks in advance!!
            11-17-2023, 09:16 AM
            09-06-2024, 11:40 PM
            09-06-2024, 08:40 PM
