Hp aio 20 clean me needed
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    I've this HP 20 AIO PC with no display. I flashed the attached bios and got display but display is coming after almost a minute or so. I tried cleaning the me region but still same. May be, i'm doing some mistake.
    MB Marking : IPSHB-AT REV 1.02 Nothing else is mentioned on the mb. Please look into the bios and advise.
    PS: Tried Hp virgin bios-still display very late.
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: Hp aio 20 clean me needed
    Pegatron board made for HP. Does yours have a dedicated GPU? What's the exact model of the machine?
    If the BIOS directly from HP doesn't work properly either, I'm not sure ME region is the issue.
    Can you post the original (non-working) dump of the machine?
    Also try other RAM sticks.
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      @piernov, here is the no display bios. Have alook. I tried Known good PC3-L ram stick. Memory slots are clean. No gpu on my board
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        http://www.ascendtech.us/hp-aio-20-r...3298001mb.aspx
        This is the board. Customer gave me only the mb-so dont know the exact model number. The link above gives compatible model. I downloaded bios for this HP 20-r110d AiO PC
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          This is the hp virgin bios i used(ALT_A010) as well as ALT_A009. Both these bios gives display but very late.
            • 20952
            There are 5 different bios to try for the 22-3000 series, they all have a different SSID number for each bios.The SSID might be on a sticker on the PC case. Yes i know youve only got the board.
            https://support.hp.com/us-en/drivers...series/7779739
            • piernov
              • Jan 2016
              • 4435
              • France
              Yours has BID ALT_8001 rather than ALT_A009 or ALT_A010.
              This might be the problem.
              Try the attached one.
              • piernov
                • Jan 2016
                • 4435
                • France
                Model number in original BIOS is 20-r011il, SSID is 2B3C and product code is M1Q78AA#ACJ .
                BIOS update is: (I extracted ALT_8001.bin from there)
                ftp://ftp.hp.com/pub/softpaq/sp71001-71500/sp71147.exe
                ftp://ftp.hp.com/pub/softpaq/sp71001-71500/sp71147.html
                In BIOS update file NVRAM is empty, so no DMI info. Will probably have to be added with dmifit.
                  • 20952
                  The latest bios on HP support for SSID 2B3C is A0.10 Rev.A (ALT_A010) the oldest is 80.01 Rev.A (ALT_8001) .If you go to the HP support page while using win 10 ,only 4 previous SSID 2B3C bios are listed.If you change your OS version at the top of the support page to Win 8.1 then 6 are listed.I use Win 7 and there are no drivers listed at all until i change the OS version.
                  Try ALT_8001 posted by @piernov and run fpt -greset with Flash Programming Tool .
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    Thanks for your support piernov & smdflea. I'll try and report back.
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      Got display with bios posted by piernov. Now display comes after 30 seconds. I tried cleaning the me region but still it takes 30 seconds to post. Is the dmi info on bios at post#3 is from block 220000-24850F?? I cpoied this block in bios posted by piernov and it gives no error message on boot but after entering setup it shows serial etc as blank. This pc came to me after repair attempt by someone else(it was dead unit when i recd it)-so may be the bios posted by me as original not working is not the original bios in true sense. I coul not locate serial number in that bios.
                      Anybody can guide me??
                        • 20952
                        Will probably have to be added with dmifit as piernov said. Does the customer have the case with the i.d. sticker and all the info,serial,model number etc.
                        The bios might not be the original,all you can do is try each bios for the 22-3000 series ,the same bios are listed for the 22-r**** models with the IPSHB-AT motherboard.
                        • UEFIUnited
                          Dell Optiplex 5260 AIO - EC Region Reset/Blank Needed
                          by UEFIUnited
                          Hey,
                          Can someone please help with blanking (seems to be termed 'resetting' by the looks of things) the EC Region of this dump I have from a Dell Opti 5260 AIO computer?
                          Thanks guys...
                          01-06-2023, 11:11 AM
                        • tom3k
                          Dell Precision 5540. Need clean ME Region
                          by tom3k
                          Laptop: Dell Precision 5540
                          MB: LA-H331P Rev: 1.0(A00)
                          Hi.
                          I am looking for a clean ME Region 12.0.95.2489 Corporate H CNP/CMP-H B, A
                          After extracting my BIOS in FIT the ME Region size is 7565 KB.
                          However the ME Region files I fouud online are 11688 KB in size.
                          Can someone help me find he correct clean ME Region?
                          Thanks!
                          Code:
                          ║ Family │ CSE ME ║
                          06-28-2025, 12:34 PM
                        • Adenitz
                          Clean ME region - a bit of theory
                          by Adenitz
                          Hello laptop repair experts,
                          can someone plese, help me understand the significance of cleaning ME region in a BIOS dump file?
                          I know that Manegement Engine (ME) data is part of BIOS/UEFI firmware. I know that it contains some HW specific data for the particular laptop.
                          What I don't know, why do I need to clean ME region if I try BIOS dump file from another laptop (of course same type and model). I'm not sure if this is only because of the serial number (not sure if that is stored in ME region at all).
                          Recently, I had a two cases where laptops (one is Lenovo Idepad...
                          10-21-2023, 04:44 AM
                        • Lexsmash85
                          Bricked bios from a legion y540-15irh (81sx) . Needing dmi/clean me region maybe
                          by Lexsmash85
                          Edit: apologies, I only need help with the DMI info.. I thought the ME region would need attention in order to recover from bricked state but maybe I misunderstood.
                          Im a novice to this experience but in short, I performed a backlash from the latest and final bios firmware BHCN45WW to BHCN26WW hoping that would solve an issue with keyboard functionality failing after an update. Ended up hanging during flash process and then system would no longer POST on reboot.
                          USB recovery process didn't seem to take. So today I successfully managed to get the BIOS dump from my machine...
                          08-06-2025, 03:41 AM
                        • konovalec85
                          Clear me region Acer VERITON L670G Q45T-AS
                          by konovalec85
                          Hello
                          Can someone help clean the ME region?
                          I flashed the BIOS with this file and writes intel me unconfiguration in progress when loading
                          I wanted to try to clean the region myself, but I don't know which and where to get a file with a clean region for this motherboard. And what version do I need?
                          FITool 10.0.46.1002?
                          Chipset * North Bridge – Intel Q45 * South Bridge – Intel ICH10...
                          01-12-2025, 05:14 AM
