Need Schematic and Boardview for HP G75A DAG75AMBAD0 REV: D
  • greypally
    • May 2013
    • 23
    Hoping that someone has this, trying to repair a liquid damaged board.
    Please and Thanks in Advance!!!
  • Mechanicalbytes
    • Apr 2020
    • 30
    • United Kingdom
    Re: Need Schematic and Boardview for HP G75A DAG75AMBAD0 REV: D
    Is it possible to get the other side of this motherboard. The brd file provided is of the underside of the motherboard, I require the top side.
    The following image shows chip "BAC7KE" I need to find out what chip it is.
    Thanks.
    • Mechanicalbytes
      • Apr 2020
      • 30
      • United Kingdom
      Sorry, sorted it out. New to boardview, got the otherside to showup.
      • Spider1211
        • Oct 2019
        • 532
        • Mauritius
        Silergy SY8288CRAC.
        https://www.badcaps.net/forum/showthread.php?t=82402
        • Mechanicalbytes
          • Apr 2020
          • 30
          • United Kingdom
          Thanks @spider1211
          That thread gives me all the info required.
          Big smiles and a thumbs up.
          • hh200523
            • Jul 2020
            • 1
            • المملكة العربية
            HP G75A DAG75AMBAD0 REV: D DATASHEET
            i need it
            • Abdulkadertabbakh
              • Feb 2018
              • 10
              • syria
              Thanks.
              link is dead.
              can you please renew the link address.
              • mon2
                • Dec 2019
                • 14660
                Attached is the boardview file for the G75A.
                • kodox
                  • Jul 2017
                  • 329
                  • Indonesia
                  Thank's
                  • MattCambi
                    • Nov 2023
                    • 2
                    • Italy
                    Hi guys, I am struggling with this motherboard. I have the broken EC14009 component, but I can't figure out how much capacity it has. Would anyone have the association between the components and their parameters?
                    Thank you very much​
                    • fichamba
                      • Dec 2011
                      • 133
                      • Spain
                      Thank you, mon2
                      • Denim Jean
                        • Jun 2025
                        • 2
                        Thank you, mon2. Thank you everyone for all those info provided. I guess I can fix this hp power series laptop now XD
                        • fikonaz
                          • Mar 2017
                          • 38
                          • turkey
                          Thank's
                          • PacoGT
                            HP ENVY x360 gidget 8L 203038-1, boardview and schematic need
                            by PacoGT
                            hello firends
                            i search the schematic or boardview
                            I have this motherboard, but I can't find the schematic or the boardview.
                            The problem is that on the chip marked where 3V should be, there are 5 volts, which indicates that the two are connected.
                            So the computer doesn't turn on, and the 3V disappears after a few seconds.
                            The original problem was that when I turned off the computer, the fan stayed on and saw that it was bad since it was directly in the 5V area.
                            The new problem arose after removing the bad chip.
                            3V and 5V remained together,...
                            08-19-2025, 08:25 PM
                          • hosain0489
                            Request for Schematic and Boardview for HP Omen 16-xf0006AX (AMD Ryzen 7 7840H Version)
                            by hosain0489
                            I’m looking for the schematic and boardview files specifically for the AMD version of the HP Omen 16 laptop, model xf0006AX, equipped with the Ryzen 7 7840H CPU.
                            Most of the files I’ve found are for Intel CPU versions, and I need the exact files for this AMD Ryzen 7 7840H model to assist with repair and troubleshooting.
                            If anyone has access to these files or can kindly share the boardview and schematic for this particular AMD version, I would really appreciate your support.
                            Thank you very much in advance!
                            07-15-2025, 11:20 AM
                          • re-atari
                            Gigabyte GA-H110-D3A schematic/boardview needed
                            by re-atari
                            Hello all,
                            Does anybody have a schematic and/or boardview of the Gigabyte GA-H110-D3A mainboard available? It would really help me out big time...
                            This board was donated to me in a known non-working state. In its previous life it was used as a mining board, so I suspected bad caps and a relatively easy fix. My intention is to use the fixed board as a testbed for a Truenas or Unraid build. The previous owner told me that the mainboard started to act 'weirdly' after replacing the originally installed Celeron for an i5-6400, varying from starting up irregularly to not at...
                            02-24-2025, 06:45 PM
                          • jonyhdtv
                            HP ProBook X360 11 G3 ee (winbook) schematic and boardview thanks
                            by jonyhdtv
                            Looking for schematic and boardview
                            Model: HP ProBook X360 11 G3 EE
                            Serial: SCG9114JG7
                            Motherboard: L43774-601
                            defect: touchscreen doesn't work (touch works on another computer)
                            thanks to all​
                            01-29-2025, 08:16 AM
                          • jonyhdtv
                            HP ProBook X360 11 G5 ee schematic and boardview thanks
                            by jonyhdtv
                            HP ProBook X360 11 G5 ee (winbook) schematic and boardview thanks
                            Model: HP ProBook X360 11 G5 EE
                            Serial: SCG0164QLH
                            Motherboard: L83950-601
                            defect: no POWER
                            thanks to all​
                            01-29-2025, 08:11 AM
