how to read bkp from 25Q64FVIG
  • recan21
    • Oct 2018
    • 23
    • Algeria
    any one have already tested to read backup from new 25Q64FVIG
    do i must solder directly pins to mother board ?
    i have EZP2013 programmer
    thanks for help.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: how to read bkp from 25Q64FVIG
    You need something like this
    https://pt.aliexpress.com/item/Free-...802865327.html
    • recan21
      • Oct 2018
      • 23
      • Algeria
      i have solder all pins like this adapter and no chance to deyect eeprom
      maybe not supported by ezp2013 programmer!!!
      • recan21
        • Oct 2018
        • 23
        • Algeria
        it's ok now !! i will read backup and post it here !
        • recan21
          • Oct 2018
          • 23
          • Algeria
          here is backup locked bios ! i need dump bios unlocked thanks:
          https://www.4shared.com/rar/7_tafx2o...rd-locked.html
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Where is the model number details?? Write comlete details like HP X360 G2 etc.
              • 21692
              Post your bios backup here, not on 4shared crap.
              • recan21
                • Oct 2018
                • 23
                • Algeria
                ok thanks for reply !
                i o a mistake about bios chip its not 25Q64FVIG. It's MX25L128(16MB)
                i make a new thread about this!
                • langbaobao
                  DIY 3D-Printer WSON8 Pogo Pin Adapter
                  by langbaobao
                  Hi.
                  I'm posting this here in part as a memo to self as well as to describe the procedure I used in case anyone else found it useful. I found a lot of the necessary information to make this work on this forum and I figured I would give something back. If this is not the appropriate place to post this, I don't mind it being deleted but I hope it can help other people.
                  I got an admin password locked HP Elitebook 840 G5 recently that I wanted to unlock. I'm a relative newcomer to reprogramming and unlocking firmware. The only previous experience I had was unlocking a BIOS...
                  01-08-2024, 05:58 PM
                • STKR123
                  The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
                  by STKR123
                  Greetings badcaps community,
                  I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
                  So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
                  Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
                  I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
                  These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
                  I learned that desoldering...
                  10-29-2024, 06:03 AM
                  Common SPI bios chip programming Questions and Answers
                  by SMDFlea
                  Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
                  A: If you can`t read from it how do you expect to write to it ?.
                  Q: Why is my bios chip unreadable ?.
                  A: The programmer is faulty or has a worn or broken zif socket.
                  The USB cable is frayed,connector pins worn or some other physical damage.
                  Not enough amperage or voltage to power the programmer properly.
                  Bad...
                  09-02-2021, 04:40 PM
                • araxnido
                  Programming KBC IT8987VG ASUS TUF FX506L RT809F+PEB
                  by araxnido
                  Dear friends, I want to share my experience repairing an ASUS TUF FX506L gaming laptop motherboard: DABKXDMB8E0_F_BKXD. Boardview and schematic are available, as well as the BIOS and ITE ROM.
                  When the customer brought in this laptop, it was initially dead; it showed no signs of booting for any reason. After hours of measurements, checking each stage, MOSFET, and seeing if there was a short circuit in any capacitor, I discovered a strange 0.7V leakage voltage on the 3V_S5 rail, particularly on the PL9 coil, with the board not powered on. There were 3V_LDO and 5V_LDO voltages, which...
                  06-10-2025, 09:26 PM
                • Teeheeze
                  RT809H Programmer Firmware Corrupted
                  by Teeheeze
                  This is a shot in the dark, but I was just using my RT809H programmer and it got stuck in a certain state so I power cycled it. Now, the device LED just flashes quickly and does not connect to the software. I've tried to update the BIOS of it and it fails. I went so far as to remove the ROM from the programmer itself but it's some weird chip (I believe ATMEL, but I can't find any datasheet on it) so I've been unable to read the BIN from it w/ my other programmer. Chip has ATMLHC4C56BM CN written on it (I think). I'll upload an image. I have the programmer's BIN ready to program it manually. Anyone...
                  02-13-2025, 04:51 PM
