6-71-p6500-d03 moster tupar t5 v4.1
  • bekirsalman
    • Nov 2016
    • 137
    • turkey
    6-71-p6500-d03 u37.bin u38 bin
    moster tupar t5 v4.1 bios
    Electronicman
    • 22110
    Re: bioss helppppp
    Post your bios backups, there are 2 chips .
    • bekirsalman
      • Nov 2016
      • 137
      • turkey
      Re: bioss helppppp
      Electronicman
        • 22110
        Re: bioss helppppp
        Flash U37 and U38 with your programmer, then flash the EC with a bootable DOS USB drive. You can use Rufus https://rufus.ie/en_IE.html .Read the readme_EC.txt in the EC folder .
        Monster TULPAR T5 V4.1
        CLEVO P650SE Bios Ver: B0501 EC Ver: E0501 .http://repo.palkeo.com/clevo-mirror/P65xSE/
        • bekirsalman
          • Nov 2016
          • 137
          • turkey
          Re: bioss helppppp
          thanksssss
          Electronicman
          • goccanhcafe@gmail.com
            GC
            • Oct 2021
            • 3
            • Việt Nam
            Re: 6-71-p6500-d03 moster tupar t5 v4.1
            password=???
            help?
              • 22110
              Originally posted by goccanhcafe@gmail.com
              password= repo
              • ugamazing
                Best place to source RAM chips? 8GB 820-00850 boards to 16GB or 32GB
                by ugamazing
                I'm looking to upgrade several 8GB 820-00850 boards to 16GB or 32GB for personal use. I am curious what the best practice and process is for sourcing new replacement chips, and what vendor(s) you guys prefer? Another question is, how do I find compatible chips and their corresponding part/model numbers? For example, in the 820-00850 schematic, the DDR chip U2600 model listed (EDFB232A1MA) corresponds to 1x32GB chip. Of course, I would need 4x8GB chips to replace the 4x2GB chips currently on the board. How do I find compatible 8GB chips? Is it as simple as searching "BGA178 8GB 2133"...
                08-31-2022, 07:34 AM
              • feherhollo
                WSON8 NEW Bios Chips READ, ERROR, ETC.
                by feherhollo
                I asking for help on some new WSON8 256MB chips. Please share your experience. I faced error on some new chips on read, erase, write with different programmers. These new chips are not exist in any programmers database. (GD25B256D, XM25RH256, W25Q256JV so on.)
                I'm using RT809F V.5.0, EZP2023 Pro, CH341A Green
                For the exact experience with GD25B256DYIG is RT809F erase the chip under 33sec. This kind of 256MB chip normal erase time is 70-120sec so I think not all the partitions are erased. If I do blank check or reread the buffer says FFFFFF but when I write the correct...
                11-26-2023, 09:33 AM
              • Prott
                [RoG Ally] Fault in one of the onboard RAM chips. Any way to diagnose which?
                by Prott
                Hello dear badcappers!
                The title pretty much says it all - do you, please, know if there's any way to troubleshoot which of the integrated RAM chips (LPDDR5X in this case) is faulty?
                Backstory:
                After replacing the 4 onboard (soldered) memory chips on a RoG Ally (4x4 GB to 4x8 GB) it got stuck on the RoG logo. I assume one of the chips is either not soldered properly or faulty. However after reflowing and replacing bunch of them I am still stuck at the same place.
                If there is a way to narrow down which memory module is faulty it would make my life much...
                06-03-2024, 12:05 PM
              • HotSaladMan
                Lenovo ThinkBook 14S Yoga ITL Bad Flash + Need Bios
                by HotSaladMan
                *##*#*#*#*#*#Cringe Warning Used Clips for Tl866ii Plus Backups#*#*#*#*#*#
                Model : Lenovo ThinkBook 14S Yoga ITL
                S/N : MP28JT19
                MFG Date : 2022/02/09
                Factory ID PRC4
                MO : MPNXB26080FX
                MTM : 20WE001US
                MODULE FCC ID : PD9AX201NG
                IC : 1000M-AX201NG
                BOARD INFO
                FLV34 LA-KO51P
                REV : 1B 2020-08-24
                Bit of Info
                Using Tl866ii Plus, it would scan the chip but wouldn't not detect the
                chip id, so i would always uncheck the id check, so it would bypass the error
                i did in fact make...
                11-07-2024, 07:46 AM
              • LukeDavis
                Is there a list of known dodgy ATI Radeon chips?
                by LukeDavis
                Hello again! (People are likely going to get tired of seeing posts from me lol)
                I'd like to try and compile a list of known bad AMD/ATI Chipsets and graphics processors.
                While I do not possess the knowledge of some of the brilliant minds on this forum, I can at least mention a few chips I've encountered as being troublesome.
                1. ATI 216-0752001 (RS880M/RX280M) found inside 2 HP laptops, one I've since deemed screwed, and swapped the board to an intel one, the other HP seems to be less hateful and runs fine.
                2. ATI Mobility Radeon X1600 and the...
                02-16-2024, 04:34 PM
