Powerware 3105 UPS bad charger caps
  • japlytic
    • Oct 2005
    • 2086
    A week ago, I bought a Powerware 3105 UPS from a local junk shop.
    Opening it revealed two bad Rifeking WL series capacitors (C10 and C11) in the charger circuit. Another Rifeking capacitor of the same series was connected between the battery and common was found.
    All three Rifeking capacitors were replaced with low-ESR units.
    The battery sulphated because of the two bad capacitors having a lower capacitance, and therefore, lower reactance.
    For a 1000uF capacitor, the reactance is 3.2 ohms @ 50Hz.
    The capacitance and reactance of the bad units were 36.8uF @ 86.5 ohms, and 27.6uF @ 115 ohms, both at 50Hz.
  • motormayhem
    Lenovo T460 Only Charges on One Charger
    by motormayhem
    Laptop Question
    I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
    A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
    05-12-2023, 01:46 PM
    ISL88739AHRZ ISL88739 Laptop Battery Charger Datasheet
    The ISL88739 & ISL88739AHRZ are a highly versatile combo battery charger
    configurable for operating as either a Hybrid Power Boost (HPB)
    charger or a Narrow VDC (NVDC) charger, supporting 2-, 3-, or
    4-cell batteries. Both configurations allow the battery to work with
    the adapter together to supply the system load when it exceeds
    the adapter capability, referred to as system Turbo mode. HPB
    charger configuration reverse-boosts battery energy to the system
    bus to help the adapter provide the system power in Turbo mode.
    NVDC charger configuration...
    11-05-2024, 03:28 PM
  • flat-earther
    how to prevent a connected charger from draining battery when not charging?
    by flat-earther
    I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
    So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
    but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
    So the battery is backfeeding the charger and being drained.
    How can I prevent...
    08-07-2025, 01:04 PM
  • flat-earther
    ASUS X54H laptop thinks it's always charging even with charger unplugged
    by flat-earther
    The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
    Windows also shows ''Plugged in'' when charger is not connected.
    This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
    Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
    If I let battery run out and say it has 3% Windows will...
    06-24-2025, 09:32 AM
  • Johndill
    Dell Inspiron 7567 LA-D993P odd charger issue
    by Johndill
    Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
    There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
    I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
    Here are the tested scenarios:
    1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
    2. With the laptop off, plug in charger (LED says on) & the front charging...
    11-16-2022, 10:55 PM
