Transfer Windows-Key from bad BIOS to new BIOS
    the situation:
    I get a laptop with bad bios (mostly DELL).
    Then I try to find and download a suitably ROM-File for that BIOS.
    Next I solder out the BIOS chip and read it in an external programmer.
    Sometimes in the new BIOS there is a Windows key included - so I overwrite the key with the one from my BIOS-extraction.
    Then I reprogram the chip with the BIOS I found here.
    In most cases windows is working with my original key.
    But the most ROM-Files contain no windows key.
    And later if I check in Windows I get the information "Unable to open MSDM table".
    My question:
    Is it possible to transfer the information from the bad ROM to the working ROM?
    Re: Transfer Windows-Key from bad BIOS to new BIOS
    i asked same on MyDigitalLife (thay made cotribution to win7 activator) but never got replay
    sometimes keys can be extracted from working machine and inserted with phoenixtool (slic2.1, win7 key) but for win10 i never found solution
    if you want to experiment you can send me 2 working bios, with key and without key so we can try to make it
    lots of time and reflashing will be needed
    Im Back... sort of...
      Its always best to try and repair the original bios to preserve any windows keys,and dmi info. Win 7 oem keys and slic table can be edited in with a hex editor or phoenixtool.Win 8 keys,if any,with hex editor. Laptops with win 7,8 that were upgraded to win 10 will have a digital entitlement key,you can find that key with ShowKeyPlus .
        I can pull out the key if the DMI table around it is damaged.
        Follow the white rabbit.
          Quite old topic, but any progress - maybe different topic? I've got DELL Optiplex 9020 with physical sticker and would like to "transfer" it into BIOS
            i think you must post your question here : https://www.badcaps.net/forum/forumdisplay.php?f=15
