Panasonic TNPA5335 YSUS Difficult Fault
  • foxyUK
    • 35
    • United Kingdom
    This board has had a hard time due to fake components (I've fixed 3 since without issue, using good IGBTs, but this one is very sick still).
    All IGBT's have been changed, and many other components. All IC's pass a diode check as given in Panasonic fault-finding guide, and everything else seems the same resistance as a good board, but the picture is as per the attached clip. May not be obvious on the clip but there is some image retention. This was intermittent for a while, but now solid.
    Vscan, Vad and Energy recovery volts are all OK at 147v, 200v (to Vfg) and 113v (to ground).
    Any ideas anyone?
    Thanks!!
    Last edited by foxyUK; 08-14-2018, 03:13 PM. Reason: changed linked pic to attached pic
  • foxyUK
    • 35
    • United Kingdom
    Re: Panasonic TNPA5335 YSUS Difficult Fault
    Ok... couldn't attach a short video clip, so back to a link!
    https://photos.app.goo.gl/aF6HHWnbWkwR15Ja9
    • tw2005
      • Oct 2011
      • 6458
      Honestly don't know, out of the loop now but what's th efull history? sevearl attempts by yo or before you? is the ysus correct version for this model TV?
      • foxyUK
        • 35
        • United Kingdom
        Sorry for the delayed response TW and thanks for looking!
        It's the original correct board. Fake components for the first attempted repair made things worse and it was all downhill from there. Eventually a repairer got it working properly but after a short run it degraded to how you see the video. Initially intermittent, then hard.
        • Nick's Tvs
          • Jan 2014
          • 621
          If you could also let us know which parts you have attempted to replace or have been attempted to be replaced as well.
          Also are you getting 7 blinks, are you getting 6 blinks?
          Sometimes when using fake components, they can break other parts of the board as well and change the error code to 6 which then means you have a lot more work to do.
          • foxyUK
            • 35
            • United Kingdom
            Hi 'Nick'..
            The usual 6 IGBT's were changed along with IC501,502, and the little driver pairs. When the fake IGBT's blew, those had to be changed again, along with IC521, Q521and I also learnt later that usually only the IGBTs blow on this board. After much checking and measuring, ICs 784 and 786 were changed and this brought the board to life but with the poor images that you see in the clip. However, without changing anything, handling and refit of the board made it work properly for a while, before going faulty again. I have searched for bad joints and cracked tracks until my eyeballs hurt, but don't find anything, and no amount of prodding will restore function. All active components have been 'diode checked' against values from a good board and the Panasonic guide values, and are OK. Voltages are OK. There are no blink codes...it runs. This board is effectively a spare, as I bought enough dead TVs to get the boards I need, but it remains a challenge that niggles me. Ultimately it might just have to be a board for donating components.
            • Rictech
              Panasonic SA-MAX770PU SMPSU board fault....
              by Rictech
              Hello everyone. πŸ˜€
              As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
              Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
              Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
              This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
              There are no devices that have exploded or otherwise show signs...
              08-26-2024, 01:05 AM
            • PlasMatt
              LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
              by PlasMatt
              I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
              09-20-2025, 06:50 PM
            • BigPete
              Panasonic Heatpump Dryer Repair
              by BigPete
              I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
              The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
              In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
              Unfortunately the whole machine has to come apart to fix it.
              I have...
              11-01-2025, 06:40 PM
            • Andre Gilbert
              by Andre Gilbert
              Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing hereπŸ€”?
              Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting πŸ˜‚.
              11-20-2024, 08:52 PM
            • chockimon
              Panasonic TX-40AX630B has developed a fault
              by chockimon
              I bought a Panasonic 40" TX-40AX630B TV from Richer Sounds 7 years ago and it has developed a strange fault. If I attempt to press any button on the back of the TV or remote control (access media features etc.) the TV locks up for a few minutes or longer and sometimes goes blank. However, if I turn the TV off and on again and quickly select a channel it will work fine all day long, as long as I don't touch the remote or controls on the back of the TV.
              I've tried changing batteries on the remote, changing plug sockets and doing other things such as a...
              06-02-2022, 12:03 PM
