Samsung PN42C430A1D turns on but no picture
  • neilc6
    • Nov 2015
    • 1550
    This plasma turns on and off with chimes but there is no picture. Checked Vs and Va on the power supply and they were about 10V. No short detected at the supply input to the Xmain board (found repair kit for this problem). Appears that PSON is not coming from the logic control board. 5.3V is present at the supply to the control boards Not sure if I should try to trace it back to the main board or jumper PSON high. Will continue investigating.
  • neilc6
    • Nov 2015
    • 1550
    Re: Samsung PN42C430A1D turns on but no picture
    Further measurements indicate the TV is powering up, but VSON isn't staying in the on state. In the off state, PSON is 3.3V and VSON 0V. When turned on, PSON goes low, VSON is at 3.3V, VS=212V, VA=54V but after the startup chime, VSON goes low and VS and VA voltages start dropping. I unplugged the connector to the Ymain board and it exhibits the same behavior. Not sure if the power supply is detecting a fault or if there is an issue with the PSON signal.
    • neilc6
      • Nov 2015
      • 1550
      Tried to do a test by jumpering pins 3-4 on the header connector of the logic board and disconnecting the cable to the main board but VSON still didn't come on. Looking at a schematic for another plasma power supply, VSON should switch a transistor pulling the leg of an optoisolator to gnd. VSON is not shorted so I believe the issue is with the logic control board. Luckily used boards are plentiful on ebay and only around $5 so worth a gamble.
      • neilc6
        • Nov 2015
        • 1550
        Thinking about this some more, there are ribbon cables coming from the Xmain and Ymain boards going to the logic control board. Error signals on these lines could cause VSON to shut down. Will need to do some more probing.
        • neilc6
          • Nov 2015
          • 1550
          Bumping this thread. Any input here?
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            I don't know if this is similar to your set. May be of assistance to you.
            • freakaftr8
              • Oct 2012
              • 3743
              Try disconnecting the flat white ribbon cable that connects from the logic board to the Ysustain. It's your voltages come up then it's most certainly a problem with the Ysustain
              • neilc6
                • Nov 2015
                • 1550
                Disconnected the ribbon cable from the Ysus and the voltages stay up.
                Vsc and Ve measure ok on the Ysus. Pulled out Ysus and inspected. No cold solder joints on coils and parts attached to heatsink not shorted. Shopjimmy repair kit for this board replaces all the FETs and Diodes attached to the heatsink.
                • freakaftr8
                  • Oct 2012
                  • 3743
                  I would try disconnecting the buffer boards from the Y main and power up to see if voltages stay up if so then you have buffer board failure and Y main is probably ok
                  • neilc6
                    • Nov 2015
                    • 1550
                    Disconnected the Y buffer and voltages stay up. Does this confirm the buffer is bad. Could it be the panel??
                    • freakaftr8
                      • Oct 2012
                      • 3743
                      No its most likely the buffer board. This TV looks like it most likely has just one buffer board that spans from the top to the bottom so you would have to find a replacement.
                      • neilc6
                        • Nov 2015
                        • 1550
                        I ordered a used one on ebay for $15. Worth a gamble since this model is a newer and lighter plasma.
                        Thanks for the feedback since I could have potentially replaced the logic, xmain and ymain boards.
                        • tvtimmy
                          • Mar 2015
                          • 1160
                          • usa
                          Let us know if it worked. I think it will.
                          • neilc6
                            • Nov 2015
                            • 1550
                            Got a replacement board and I think the new board caused a short in the Y-main. PS clicks and no more chime so it is worse. Old board put back in has the same new symptoms. Think I'll scrap the tv for the power supply and main boards.
                              09-07-2024, 05:50 AM
                            • TR103
                              by TR103
                              - it keeps rebooting
                              01-22-2025, 04:12 PM
                            • JJAAMM
                              by JJAAMM
                              Problem
                              07-06-2023, 06:01 AM
                            • Mgiffune
                              by Mgiffune
                              06-09-2024, 10:28 AM
                            • Dodgethis
                              Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                              by Dodgethis
                              Hello all,
                              This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                              09-11-2024, 07:39 AM
