Toshiba C55 - da0blimb6f0 rev:f Schematic Needed
  • sonunigam
    • Aug 2013
    • 151
    • Pakistan
    Hello all guys,
    I want to download Toshiba C55 DA0BLIMB6F0 Rev:F Schematic Diagram.
    Laptop Power is ok but Display not showing anything. Reprogrammed the BIOS already but nothing changed.
    Please help me out. . . ..
  • sonunigam
    • Aug 2013
    • 151
    • Pakistan
    Re: Toshiba C55 - da0blimb6f0 rev:f Schematic Needed
    I think no one is helping out in this forum. . . So Sad
    • bluestone
      • Jun 2011
      • 343
      • Ghana
      not available
      • no3mangroup
        • Jul 2014
        • 59
        • egypt
        anyone have account from here https://***********/threads/toshiba-...limb6e0.14532/
        • Jckman
          • Nov 2018
          • 6
          • usa
          I notice from other posts that Toshiba C55 , L50 and the L55 use the same motherboard p/n DA0BLIMB6F0 rev F. Has anyone seen this board used in other toshiba laptops? If someone has schematics for another laptop similar using the same motherboard could you please post.
          • Duranitron
            • Jul 2014
            • 544
            • Philippines
            Originally posted by sonunigam
            Hello Guys,
            Please Upload Toshiba C55-B1069 DA0BLIMB6F0 Rev:F Schematic Diagram.
            The problem is no display. When i check Bios Voltages there are no voltages. Only 0.7 Volts. I don't know where to find those voltages, that's why i need schematic diagram. Please upload it.
            have you ruled out the problem? i mean did you connect your laptop to a known good power adapter? did you connect it to an external monitor via hdmi or vga cable? any led blinks or sound beep? have you re seat or clean the ram.
            Never stop LEARNING because life never stops TEACHING!
            • Madhusha
              • Apr 2012
              • 15
              • Srilanka
              try this...should same
              • whitevolf
                • Feb 2014
                • 123
                • TÜRKİYE
                thanks
                • Sergio Kub
                  • Jul 2018
                  • 175
                  • Brasil
                  thank you
                  • CIB-TECH
                    • Oct 2016
                    • 14
                    • algeria
                    thanks
                    • nassimhamdi
                      • Feb 2016
                      • 150
                      • algeria
                      thank you
                      • tmkbc
                        • Jan 2016
                        • 28
                        • Algeria
                        schematics which should have much more similarity
                        • anshad
                          • Nov 2010
                          • 249
                          Quanta BLID is an Intel SoC board BD9 on the other hand is an AMD SoC one.
                          • Bananis
                            • Apr 2022
                            • 1
                            • Norway
                            Thanks!
                            • paijo.keren
                              • Nov 2024
                              • 13
                              • surabaya
                              do you know the cause? i also have that problem please answer
