Samsung S4 mini GT-I9195 completely dead. Please help
  • goodpsusearch
    • Oct 2009
    • 2850
    • Greece
    My Samsung S4 mini GT-I9195 turned off on its own and doesn't start anymore. I put it on flight mode last night, and after the alarm clock went off this morning, I think I turned off flight mode and then the phone turned off and now it's dead. The battery was not empty. I also tried with another New Original battery to no avail. Holding down multiple buttons to enter service mode doesn't give me any respond, not even vibrating. But when I plug it into my computer i can see a Qualcomm HS-USB QDLoader 9008 (COM30).
    Is there any way to try to save the data?
    How can I know whether it's a hardware problem or firmware corrupt?
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: Samsung S4 mini GT-I9195 completely dead. Please help
    Corrupt bootloader I would say. Doesn't exclude the fact that the NAND may be dead. It happens sometimes on those devices. If you have a full dump (or at least the first few MB) of the NAND you may be able to restore it, ask on XDA developpers for example.
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3630
      • slovakia
      https://www.aliexpress.com/store/pro...239907738.html
      • goodpsusearch
        • Oct 2009
        • 2850
        • Greece
        I had emmc and RAM reflowed, the phone came back to life and charged, then I removed battery to reassemble the whole thing, but it was dead again.
        The tech guy removed emmc IC from the motherboard but several pads lifted. emmc IC looks ok. Is there any way to get the data from emmc IC without installing it on another board?
        Sorry, this item is no longer available!
        • piernov
          • Jan 2016
          • 4439
          • France
          Most of the pads that get lifted in this case are not connected so it shouldn't be an issue. Check with the eMMC pinout to be sure (it's generic).
          You can solder some wires between the eMMC chip and an SD card adapter, then insert the SD card adapter inside an SD card reader. There are tutorials on the web.
          Otherwise you'll need to get an eMMC programmer with costs at least $100.
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3630
            • slovakia
            There are many sellers of this item. its common problem
            • vinceroger69
              • Mar 2012
              • 6714
              • uk
              you can get the data back this is a s6 but shows it can be done
              https://www.youtube.com/watch?v=fqYIFXCglg4
              • diif
                • Feb 2014
                • 6978
                • England
                The data should have been the first thing you backed up when the phone came back to life.
                eMMC data recovery requires dedicated/expensive software to recreate the image into recognisable data.
                • goodpsusearch
                  • Oct 2009
                  • 2850
                  • Greece
                  What is the cause of the problem? IC unsoldering itself due to vibrations/phone getting dropped/heat? Or emmc suddenly corrupts?
                  I am asking because I would like to know the chances of cloning the data from the old emmc to a new identical phone without problems.
                  As soon as the phone came back to life I ran into my apartment, downloaded Samsung Smart Switch and other back up software and then tried to power on the phone.
                  When we tested the phone, he was holding the battery with his hand, because we hadn't reassembled it yet. It couldn't be used for anything other than testing.
                    09-07-2024, 05:50 AM
                  • max-power
                    Dell E6540 laptop completely dead after dssasembly
                    by max-power
                    Hi, I disassemble my laptop to replace the speakers, to access them, you have to remove everything including the heat sink and fan, unscrew the motherboard, lift it up a bit to access the speaker wire.
                    that was not the first time I dissasemble it, i did replace the same speaker a few year ago and I repaste it last year, so I had nothing to worry about. but when I put everything back together, its completely dead.
                    After a bit of investigating, i found one pin of the status led ribbon cable that was unglued from the cable and bend touching another pin, I bend it back at his place...
                    03-24-2025, 08:49 AM
                    09-06-2024, 11:40 PM
                    09-06-2024, 08:40 PM
