Need - Bios Samsung NP870Z5G BA41-02337A
  • Simpletek
    • Mar 2011
    • 35
    • Italy
    the only i found for free WORKS but has PASSWORD
    anyone can help me?
  • rioreno
    • Feb 2009
    • 540
    • Indonesia
    Re: Need - Bios Samsung NP870Z5G BA41-02337A
    anyone can help me?
    Post your lock bios, i'll try help you...
    • Simpletek
      • Mar 2011
      • 35
      • Italy
      there it is, thanks
      • rioreno
        • Feb 2009
        • 540
        • Indonesia
        there it is, thanks
        try this..
        please confirm..
        and goodluck
        • Simpletek
          • Mar 2011
          • 35
          • Italy
          try this..
          please confirm..
          and goodluck
          Work perfect, thanks a lot
          if you can explain me how you did it the next time I do it myself
          • salawayon
            • Nov 2012
            • 572
            • philippines
            maybe someone could repair my attached backup with no display problem.
            infos:
            Samsung NP870Z5E
            nike2-15H_QC
            rev: 1.1
            intel processor with RADEON GPU
            thanks
              • 20984
              infos:
              Samsung NP870Z5E
              nike2-15H_QC
              rev: 1.1
              thanks
              With these old samsung models its usually the NVRAM that gets corrupted,so cleaning the ME firmware might not fix it.To find the right bios look for platform ID in your backup using a hex editors search function https://www.badcaps.net/forum/showthread.php?t=88206
              The bios at post #4 is P09RCL ,P09 is the bios version, RCL is the platform ID .Your bios is P02ADH , platform ID ADH
                • 20984
                P05ADH ME_Clean + DMI.
                • salawayon
                  • Nov 2012
                  • 572
                  • philippines
                  thanks. maybe someone could share the right bios file...
                    • 20984
                    You have the right one at post #8
                    • salawayon
                      • Nov 2012
                      • 572
                      • philippines
                      Sorry. that file is working but the unit got problem with radeon GPU, radeon gpu drivers can't be installed. the unit will freeze at 60% during drivers installation. RADEON GPU can be totally disabled?
                        • 20984
                        I don`t know,ask in the laptop troubleshooting forum.
                        • Kjell
                          Samsung Series 9 - BIOS issue
                          by Kjell
                          After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
                          Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
                          08-01-2025, 09:15 AM
                        • macabook
                          by macabook
                          🧩 Initial Issue
                          07-24-2025, 02:17 PM
                        • Habble7
                          I need a BIOS dump for the Samsung S49CG934SU monitor
                          by Habble7
                          The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
                          Suspected Cause:
                          I suspect the BIOS may have been corrupted during a power interruption while updating the firmware. The official website provides firmware updates, but they can only be installed via USB flash drive.
                          Troubleshooting Attempts:
                          05-22-2025, 07:28 AM
                        • Citymin
                          NT955XED (Samsung Galaxy Book2 Pro - 15.6) BIOS dump file Request
                          by Citymin
                          My Samsung Galaxy Book 2 Pro 15.6-inch laptop has no display and won't boot.
                          The charging red LED lights up, but the charging screen doesn't show any indication.
                          When I press the power button, the blue LED cycles on and off three times, then the screen doesn't turn on, and the device won't boot.
                          (I've tried removing the battery and resetting the device, but the issue persists.)
                          NoteBook Model name : Samsung NT955XED-KK51G(Galaxy book2 pro, i5-1240p, 15.6inch AMOLED)
                          PCB model name : Venus2-15-5G(REV1.2), Venus2-15 ADL NPC
                          S/N : 5RNK9FFT70...
                          08-05-2025, 05:12 AM
                          09-07-2024, 05:50 AM
