Dead Okuma Power Supply see photo
    • Jul 2011
    • 6059
    This is in a CNC machine it will not power ON
    However it powered ON yesterday with no problem
    My guess is that one or more caps are probably bad but I have not checked them yet
    But what concerns me is that some of the diodes are very discolor
    Which is one of first thing I am going to check and also maybe replace the switching IC chip
    Can anyone add to what else I should check
    I am going to do a complete cap replacement on this board
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8297
    Re: Dead Okuma Power Supply see photo
    is there a black resistor too? R2 something on the left of the diode? See if that cap leaked next to it.
      • Jul 2011
      • 6059
      Ok I will do that thanks
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
        by sam_sam_sam
        03-31-2024, 02:12 PM
      • Andreas_de
        Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
        by Andreas_de
        Hello!
        i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
        Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
        Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
        04-12-2025, 10:38 AM
        by sam_sam_sam
        07-01-2024, 06:34 AM
      • JimBanville
        Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
        by JimBanville
        The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
        Opened it up and discovered the power supply is making a faint clicking or ticking sound.
        I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
        I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
        09-13-2023, 07:21 AM
