Sharp LG Vizio edge led tv repair tips.
  • capwizard
    • Jun 2016
    • 1991
    Sharp LC60LE660U power does not turn on. Because the protection circuitry has been activated three times consecutively by edge LEDs failure. Push Vol down, channel up to reset.
    Easy as 1-2-3. (for PRO only)
    1. make sure the problem is Eled strips.
    By push Vol down, channel up and power trick to start it, you will see the screen blink briefly. Dummy tester at post #7
    https://www.badcaps.net/forum/showthread.php?t=58769
    2. Used 852D hotair gun change the bad LEDs. Temp: 475F air:2
    3.reset again & update the TV .
    Conclusion: Not knowing the TV at shutdown mode, as a module Tech am I , I ordered the all boards still not fix the TV. I am hoping someone does not make the same mistake like I did. After this lesson, I've fixed more than 10 of them.
    service manual LC-52LE640U,C6400ULC-60LE640U pdf
  • rddube
    Aspiring Expert
    • Jun 2013
    • 957
    Re: Sharp LG Vizio edge led tv repair tips.
    Hello Capwizard,
    I wonder if you can help me. I have a Sharp LC60LE660U that doesn't power on and I suspect it is the same problem you describe here. How much dissassembly is required to access the leds and change the bad ones? Also which leds do I need to get? I checked the service manual but it doesn't say.
    Any help you can provide would be greatly appreciated. Thank you!
      • Jul 2011
      • 6070
      This where a 50 volt @ 5 amp Lab power supply comes in handy I bought one about a year ago because I had a LED module I need to test because I thought it might be the power supply problem and I was right
      • rddube
        Aspiring Expert
        • Jun 2013
        • 957
        ok, I checked the leds (finally dug in) and to my surprise, none of them are bad. I powered the tv without the panel and they all come on bright and stay on. So my problem is not the leds.
        What do you think it could be, as when I power on, all I get is a flash of the backlights and then the power on led stays on white without blinking of any sort. I can even turn the tv off with the remote control. What else could it be?
          • Jul 2011
          • 6070
          Can you please provide some pictures of the the boards in this tv
          • rddube
            Aspiring Expert
            • Jun 2013
            • 957
            Absolutely, I will have to put it back together first and then I will take photos of the boards and post them. Should I start another thread? Tks Sam!
            • rddube
              Aspiring Expert
              • Jun 2013
              • 957
              Here are the photos Sam. If you think they are not sharp enough, let me know and I will take better pictures in daylight (it's getting dark here in Canada)
              Tks,
              Ray
              • rddube
                Aspiring Expert
                • Jun 2013
                • 957
                Sam, I started a new thread in the right forum here:
                https://www.badcaps.net/forum/showthread.php?t=71144
                  LENOVO ThinkCentre Edge 71 SFF ThinkCentre Edge G630 Specification for Upgrade or Repair
                  This specification for the LENOVO ThinkCentre Edge 71 SFF can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkCentre Edge 71 SFF boardview and ThinkCentre Edge 71 SFF schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                  09-12-2024, 03:36 PM
                  LENOVO ThinkCentre Edge 71 ThinkCentre Edge G630 Specification for Upgrade or Repair
                  This specification for the LENOVO ThinkCentre Edge 71 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkCentre Edge 71 boardview and ThinkCentre Edge 71 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                  LENOVO ThinkCentre Edge 71 ThinkCentre Edge i5-2400S Specification for Upgrade or Repair
