Samsung SyncMaster 2693hm - Dead backlight
  • ensign.fodder
    • Nov 2016
    • 25
    Short version - person thought their video card was failing since it took the monitor about 15, then 30, then 60 minutes to come on and display an image. They replaced monitor and gave it to me. I have confirmed unit is working "fine" in that the image is displayed but only if you shine a flashlight or other secondary source of light.
    I have disassembled the unit to remove inverter board, logic, and power. Visual inspection as expected did not show any visible signs of a problem else I would not need to post here.
    There is no other indication of a problem, meaning the power light, switch, controls, and such all work fine.
    I have a basic multi-meter, I have a macro lens, I have little time but lots of desire to save this monitor from the junk heap.
    I will attach the general pictures of the boards in the next post and await some help. If you want macro pictures of the components, please ask and I will respond when I can.
  • ensign.fodder
    • Nov 2016
    • 25
    Re: Samsung SyncMaster 2693hm - Dead backlight
    Inverter and logic boards.
    Power in next post.
    • ensign.fodder
      • Nov 2016
      • 25
      Power board.
        • 31015
        the rubycon caps on the invertor are starting to dome.
        ZL's dont last anyway.
        the psu looks surprisingly good.!!
        • ensign.fodder
          • Nov 2016
          • 25
          OK - so happy to break out the soldering kit (iron, bulb, wick, etc) and replace those four. Can you provide a better sense of your answer, meaning how are they starting to "dome"? I checked the sticky (A guide on how to troubleshoot 2 seconds to black) and it says you cannot test the caps with a multimeter.
          Thank you.
          • ensign.fodder
            • Nov 2016
            • 25
            Suggestions on what to order? Amazon Prime so if I can get them there bonus!
            • ensign.fodder
              • Nov 2016
              • 25
              Amazon Link
              Presuming I get shipped what is advertised link to Mouser for product
              • ensign.fodder
                • Nov 2016
                • 25
                Researching existing caps seem to point to following specs:
                Rubycon part number: 35ZL220M8X16
                Rated Voltage: 35v
                Rated Capacitance: 220uF
                Capacitance Tolerance: 20%
                Temperature Range: -40 to 105C
                Rated Ripple Current: 995
                Diameter: 8mm
                Height: 16mm
                Nichicon replacement:
                Voltage Rating DC: 35 VDC
                Capacitance: 220 uF
                Tolerance: 20 %
                Ripple Current: 350 mA
                Maximum Operating Temperature: + 85 C
                Diameter: 8 mm
                Length: 11.5 mm
                Summary - Initial Amazon Linked product is not up to task (Temp and Ripple)
                  • 31015
                  i think you can get free shipping from one of the u.s. suppliers - maybe digikey or mouser.
                  you dont want to use amazon or ebay because of fakes.
                  the best caps to use would be something like panasonic FR series.
                  about "domed", the top of the cap should be either perfectly flat or even slightly curved inward.
                  any curving outward at all is a sign of pressure building up inside the can.
                  this will eventually lead to the liquid being pushed out around the leads or the top bursting.
                  • ensign.fodder
                    • Nov 2016
                    • 25
                    So per DigiKey the FR series don't have a 35v 220uF model (Link)
                    Mouser order placed --> Link to item
                    • ensign.fodder
                      • Nov 2016
                      • 25
                      Thanks for the help.
                      • ensign.fodder
                        • Nov 2016
                        • 25
                        Next question - How to remove old caps safely?
                        So the caps are not through hole or similar, but have large globs of solder so I expect some sort of pad or similar underneath. I clipped the existing cap's legs off and was thinking about next step, and thought I would ask two questions.
                        1) Soften solder and use wick and bulb to remove and free cap leg or just soften solder and embed new leg?
                        2) If the pad get damaged, how would I know and what can I do about it?
                        Thanks!
                          • 31015
                          melt the solder and remove the legs with tweezers,
                          then remove the solder with a sucker.
                          put the new caps on and apply new solder.
                          • ensign.fodder
                            • Nov 2016
                            • 25
                            Re: Next question - How to remove old caps safely?
                            Thanks!
                            Any thoughts in this? I ask since I have seen some scorching (PCB) around the first one I removed and it did not come out clean. Meaning even with full solder melt it seemed "stuck" to PCB. Once I remove rest of the solder, I am afraid for what I will find. Second leg on same cap did not present same issue. Solder melted and leg came out leaving solder blob in place.
                            Thanks for all the help.
                              • 31015
                              the "scorching" is probably flux, try to scrape it a bit with a flat screwdriver.
                              • ensign.fodder
                                • Nov 2016
                                • 25
                                Did as requested but still not confident that part of the PCB did not come off.
                                Will post pick in a minute.
                                I did find the edge that showed copper color and tested conductivity to next pad so I think I have enough to work with but may always be a point of failure.
                                Of course I have to see if this fixes it in the first place.
                                • ensign.fodder
                                  • Nov 2016
                                  • 25
                                  So soldering done, conductivity tests on negative leg of caps done, conductivity tests on positive leg of caps done. Board and connections restored but end result is the same. Caps are in parallel or on a common bus so lighting one of six sets of CCL should be possible but not sure if that happens or control circuitry would prevent.
                                  Let me know what I need to check and I will go forth with multi-meter.
                                  Again, original owner said it was taking longer to "warm" up or was showing a dim image. I can still see content with flashlight. I can play sound out of speakers, and PC detects display.
                                  Travelling 12 out of 14 days till X-mas so may be delayed in responding.
                                  Thanks!
                                  • cpt.charlie
                                    • Sep 2013
                                    • 270
                                    • Spain
                                    You need to check signals like bl_on and have a look at the inverter controller IC.
                                    • ensign.fodder
                                      • Nov 2016
                                      • 25
                                      Sorry for long delay - I am back on this.
                                      Can you provide some detail as to how to, "check signalslike bl_on" and "inverter controller IC"?
                                      Thoughts about this post in the comment by Michael | Apr 13, 2012 7:35 PM
                                      http://blog.whitesites.com/How-to-Fi...97265_blog.htm
                                        https://www.badcaps.net/forum/attach...0&d=1480973043
                                        https://www.badcaps.net/forum/attach...2&d=1480973043
                                        See those connectors? They have labels for each pin to tell us what they are for, so we need you to take DCV reading of each pin when the unit is plugged in but the power switch is not activated, then take the reading again after the power switch is activated.
                                        You MUST report the readings in the format that we can easily read by putting down the PIN NAME, and follow by the DCV readings, very simple request. Black probe of the meter is on GND pin.
                                          09-07-2024, 05:50 AM
                                        • soopacrucial
                                          Samsung Syncmaster 740BF repair
                                          by soopacrucial
                                          Hi folks,
                                          I'm new here and was wondering whether you might be kind enough to give me some advice on troubleshooting the following problem:
                                          Quite a few years ago now, a couple of years from new, my Samsung Syncmaster 740BF LCD monitor starting playing up by making a buzzing noise and then the display would go blank. I seem to remember the blue power led would also go off when this happened but that I'm not 100% sure of. By pressing the power button I do remember I could at first get it working again but eventually the problem would come back. At the time I had read about...
                                          10-29-2024, 02:40 PM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
