Accent a15hc bios need
  • medinfo
    • May 2016
    • 331
    • Morocco
    Accent
    a15hc mb rev 2.0 bios dump plz
  • electronica
    • Apr 2014
    • 88
    • algeria
    Re: Accent a15hc bios need
    https://drive.google.com/file/d/0B3c...BsRldjaFk/view
    • denilloo
      • May 2013
      • 60
      • indonesia
      This BIOS is working for MSI CX640 on A15HC MAIN BOARD REV 2.0 but the logo POST is CASPER not MSI. Thanks a lot
      • Chieftain
        • May 2016
        • 72
        • Greece
        It is not working for A15YA and A15FB... Just to know...
        • abbassink
          • Aug 2015
          • 83
          • iran
          thanks bro!
          • arivaaa
            • Mar 2010
            • 7
            Thank you
            • manusr
              • Nov 2018
              • 6
              • Spain
              thanks, works
              • abbassink
                • Aug 2015
                • 83
                • iran
                its ok
                • rafsad ck
                  • Apr 2016
                  • 22
                  • kuwait
                  Originally posted by abbassink
                  its ok
                  thanks its working
                  • Ahari
                    by Ahari
                    I...
                    08-13-2025, 06:12 AM
                  • mkdj
                    ASUS ZenBook UX480F : need help with cleaning the ME region of my BIOS dump
                    by mkdj
                    Dear all,
                    I have a ASUS ZenBook UX480F with the following symptoms:
                    I suspect it is a BIOS issue. So I decided to try to clean the ME region. I followed the guide on win-raid, and I believe I have done everything correctly. My problem is: when I open the outimage.bin in ME Analyzer, it says that it is Extracted, and not Region, Extracted as it should be. Is it normal, or did I do something not correctly? This is my first experience editing BIOS files.
                    I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...
                    10-19-2025, 04:41 AM
                  • Habble7
                    I need a BIOS dump for the Samsung S49CG934SU monitor
                    by Habble7
                    The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
                    Suspected Cause:
                    I suspect the BIOS may have been corrupted during a power interruption while updating the firmware. The official website provides firmware updates, but they can only be installed via USB flash drive.
                    Troubleshooting Attempts:
                    05-22-2025, 07:28 AM
                  • haitham sharabati
                    [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                    by haitham sharabati
                    Hello engineers 😀,
                    I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                    🔧 Device Info:
                    - Model: HP 15-da2007ne
                    - Product Number: 8XF55EA#ABV
                    - Serial Number: CND0338P0D
                    - CPU: Intel Celeron N4000
                    - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                    💀 Problem:😅
                    - Device shows “Administrator Password”...
                    08-07-2025, 04:54 AM
                  • Citymin
                    NT955XED (Samsung Galaxy Book2 Pro - 15.6) BIOS dump file Request
                    by Citymin
                    My Samsung Galaxy Book 2 Pro 15.6-inch laptop has no display and won't boot.
                    The charging red LED lights up, but the charging screen doesn't show any indication.
                    When I press the power button, the blue LED cycles on and off three times, then the screen doesn't turn on, and the device won't boot.
                    (I've tried removing the battery and resetting the device, but the issue persists.)
                    NoteBook Model name : Samsung NT955XED-KK51G(Galaxy book2 pro, i5-1240p, 15.6inch AMOLED)
                    PCB model name : Venus2-15-5G(REV1.2), Venus2-15 ADL NPC
                    S/N : 5RNK9FFT70...
                    08-05-2025, 05:12 AM
