Sony kdl-46ex706
  • bf350
    • Aug 2016
    • 24
    • home
    Sony kdl-46ex706
    Hi folks,
    i have an SONY KDL-46EX706 wich flashes intermittently, which means that the picture gets white for only a couple of ms and i can see the picture flashing/flickering.
    the failure cant be reproduced it just comes and goes
    Not matter what source
    No matter how log the TV is running
    Software is up to date
    kock test is negative, also coolant spray
    BAL TCON Panel??? any ideas??
    regrads
  • sordids999
    • May 2013
    • 2161
    • uk
    Re: Sony kdl-46ex706
    Posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
    • bf350
      • Aug 2016
      • 24
      • home
      hope this helps, more clear pics when i am @home
      • bf350
        • Aug 2016
        • 24
        • home
        well the tv flickers more and more often now, but when the tv internal menu is opended over the home button the tv does not flicker.....
        any ideas?
        regards
        B
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          Have you tried this?
          https://www.youtube.com/watch?v=xox5E_29rtM
          • bf350
            • Aug 2016
            • 24
            • home
            yep checked that already and makes no difference....
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              Is it the picture on the screen or backlight that brighten up?
              • bf350
                • Aug 2016
                • 24
                • home
                its the picture, backlight is steady
                • Diah
                  • Feb 2013
                  • 6565
                  posting photo from service manual make no sense to check the reality of the sets condition, you need to take the cover back out. reseat all cable after cleaning them.. if didn't help, remove some load for the TV, while its on and display Chanel plug it off from wall sockt only,, remove the IR section socket connector then plug it again to wall socket and check.
                  • bf350
                    • Aug 2016
                    • 24
                    • home
                    • bf350
                      • Aug 2016
                      • 24
                      • home
                      • bf350
                        • Aug 2016
                        • 24
                        • home
                        • bf350
                          • Aug 2016
                          • 24
                          • home
                          cleaning the connectors and reseating them did not solve the problem
                          • dick_barton
                            • Aug 2015
                            • 6643
                            • Wales
                            Have you checked to see if any of the power supply voltages glitch in time with the picture flashing? Do you have max - min on your DVM and if so that would be useful for carrying out the check.
                            • bf350
                              • Aug 2016
                              • 24
                              • home
                              nope Voltages are ok, got a PSU and have changed the PSU for testing purposes, same behavior.
                              also i saw that the OSD of the TV is not effected by the flickering....
                              • bf350
                                • Aug 2016
                                • 24
                                • home
                                means when the tv is flickering and i open any kind of menu from the tv the picture becomes steady again, wghen exiting the menu the tv is flickering again....
                                • bf350
                                  • Aug 2016
                                  • 24
                                  • home
                                  have changed the 2pcs 16V 100µf on the bal board now as their ESR was a bit to high, seems to work at the moment...
                                  i guess i will change all the caps on the bal board later...
                                  • bf350
                                    • Aug 2016
                                    • 24
                                    • home
                                    well back again....
                                    not it has turned into a green screen, sinco today it started up with a total green screen, after pressing "home" button, picture was ok again.
                                    but depending on the image contend it gets green again....
                                    i guess it is the BAL board, dont ya?
                                    thanks
                                    regards
                                    • bf350
                                      • Aug 2016
                                      • 24
                                      • home
                                      anyone can tell me which source driver ic's this board uses:
                                      Bal Board: A1763467B
                                      ill give it a try changing them if possible.... as a new board costs around 300USD..
                                      • bf350
                                        • Aug 2016
                                        • 24
                                        • home
                                        To bring this to an end, tv is working again, changing the BAL Board was the solution.
                                        BAL Board (Service) A1763467B
                                        thanks @ all for helping
                                        • Carlos#2003%
                                          Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                          by Carlos#2003%
                                          Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                          02-15-2024, 07:52 PM
                                        • dkneyle
                                          Sony KDL-46HX850 Can't upgrade/update firmware
                                          by dkneyle
                                          Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                                          Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                                          09-25-2024, 10:44 PM
                                          Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                                          This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-06-2024, 05:27 AM
                                          Sony VAIO Duo 11 Hybrid (2-in-1) Duo 11 Specification for Upgrade or Repair
                                          This specification for the Sony VAIO Duo 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Duo 11 boardview and Duo 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
                                          09-06-2024, 05:30 AM
                                          Sony VAIO VGN-CS11S/Q CS Specification for Upgrade or Repair
                                          This specification for the Sony VAIO VGN-CS11S/Q can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the VGN-CS11S/Q boardview and VGN-CS11S/Q schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
