Cybex "Commander" 8 Port Digital KVM switch - Bad caps
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16959
    Yup, this one from my own server array.... I noticed it was acting funny, KB was intermittent, and display was ghosting.... Open it up, some bad Lelon's in the power supply....
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Cybex "Commander" 8 Port Digital KVM switch - Bad caps
    just recapped the power brick for my 24" panasonic lcd.
    for an industrial product i am surprised to find ltec and jun fu in it.
    was starting to show jaggies on text.
    sucks when you have to fix your own stuff.
    i tend to inspect and recap even stuff thats new.
      Seasonic B12 BC-550 – barely 2 years old and with BAD CAPS already!
      by momaka
      I know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
      For today's considerations, I have a Seasonic B12 BC-550 [A551bcafh] 550 Watt ATX power supply for you (click on links for full size images).
      https://www.badcaps.net/filedata/fetch?id=3591771
      https://www.badcaps.net/filedata/fetch?id=3591772
      It's a modern ATX unit with fixed (non-modular) cables and an 80-plus bronze certificate. Here's the label:
      https://www.badcaps.net/filedata/fetch?id=359177...
      03-12-2025, 03:42 PM
      Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
      This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
      09-06-2024, 05:30 AM
    • eryjus
      Heathkit IO-4205 Power Supply Caps
      by eryjus
      First, I am a complete noob with high voltage stuff. I'm learning, but I need help by someone looking over my shoulder.
      I recently came into posession of a Heathkit IO-4205 5MHz Dual Trace Oscilloscope. The documentation is copyright 1978. I'm told it works.
      I opened it up to check the caps before I applied power, and found the following black caps and wanted to know what they were. They are on the power supply board. I was able to read the name and model and came up with, "Nytronics 162J-1, 0.1uF, 20% tolerance, 2000VDC."
      05-10-2023, 11:21 AM
    • Natob82
      Micro Momentary Push Switch?
      by Natob82
      Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
      12-21-2022, 05:22 AM
    • grimacelord
      NEC TurboExpress On/Off Power Switch Replacement Help
      by grimacelord
      I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
      I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
      I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
      11-09-2023, 09:49 AM
