toshiba c850 bios dump needed
  • salawayon
    • Nov 2012
    • 578
    • philippines
    Board info:
    DK10FG-6050A2491301-MB-A02
    Unit got voltages at power switch, bios chip and also 3v and 5v also present... it wont power up.
  • imranromi
    • Jan 2015
    • 1290
    • Pakistan
    Re: toshiba c850 bios dump needed
    Try this dump.
    • amjedsha
      • Sep 2016
      • 9
      • india
      Dk10fg-6050a2491301-mb-a03 bios plees
      • amjedsha
        • Sep 2016
        • 9
        • india
        NEED Dk10fg-6050a2491301-mb-a03 bios plees 8MB PLEESSSS
        • amjedsha
          • Sep 2016
          • 9
          • india
          • burakdag
            • Aug 2016
            • 3
            • Maltepe
            hi
            • junjuntech
              • Aug 2025
              • 3
              • phillipines
              Hello. I need help with a BIOS mod for my Toshiba Satellite L850.
              - Board model: DK10FG
              - PCB part number: 6050A2491301-MB-A03
              - BIOS chip: Winbond 25Q64 (8MB)
              - Original GPU: AMD Radeon — already physically removed
              - Symptoms: Board powers on (fan, LED, Caps Lock working), but no display via internal screen or VGA.
              - I confirmed the short was on the AMD GPU and it's now removed.
              - I suspect BIOS is still locked to PEG (discrete GPU), and does not fallback to Intel iGPU.
              Please help me modify the BIOS to:
              1. Force `Primary Display = IGD` (Intel graphics only)
              2. Disable PEG graphics
              3. Disable Switchable Graphics (optional)
              I can flash the .bin file back using CH341A.
              Thank you!
              • DynaxSC
                MSI PRO B660M-G DDR4 - real bios dump from board needed (no stock bios)
                by DynaxSC
                Hi, I have an MSI PRO B660M-G DDR4 board with damaged BIOS and i need a bios dump from a real board, along with MAC, UUID and Serial Number info (eg. a BIOS screenshot and pictures from the board stickers).
                I need to reconstruct the bios on my board, based on another bios image form a real board - meaning a bios image containing MAC address, UUID and Serial number. A stock BIOS is not suffiecient, as it is impossible to discover where the MAC, UUID and SerialNumber are stored. Tried with a similar board, but there are too much differences, and the stock BIOS is missing a lot of...
                11-17-2023, 10:56 AM
              • TacticalFahrrad
                [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                by TacticalFahrrad
                Hi everyone,
                I'm trying to recover a Fujitsu Lifebook E5513 (most likely 2023 model) that was bricked during a BIOS update. The update was interrupted (probably due to power loss), and now the laptop is stuck in a boot loop showing "PBB rollback" / "SBB rollback" messages.
                BIOS access (F2) and Boot Menu (F12) are no longer possible – the system instantly reboots after the rollback messages.
                I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                06-30-2025, 04:09 AM
              • mui
                Toshiba satellite pro 30-d-14k Bios Dump needed
                by mui
                Anyone who can help remove pasword on satellite pro 30-d-14k bios here is a dump
                post moved...next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread.....
                05-02-2025, 05:12 AM
              • vinaypundith
                Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
                by vinaypundith
                I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
                So, I'm looking for a BIOS dump for this machine - a 16MB one....
                08-03-2024, 12:32 PM
              • James Maxwell
                HP DM1-4000er Bios Dump needed
                by James Maxwell
                I badly need bios dump for HP DM1-4000er,
                Model: HP DM1-4000er
                Motherboard: DA0NM9MB6D0 REV.D
                Product: QJ490EA#ACB
                Please help. My bios chip burned so I don't have the old bios anymore. I need bios dump before I can install the replacement.
                10-28-2024, 05:38 PM
