APC Back-UPS RS 800 VA (BR800I) overload LED
  • Behemot
    • 4845
    • CZ
    Anybody familiar with these? Schematic attached. Usually small 22uF/10uF caps are bad but here it was almost not used so they are still OK. Overload LED with PWR LED are blinking, that usually means shortd transistors and indeed, Q3 and Q4 were bad. But no luck after replacement. I've also swapped all four relays from different ditched unit, no change. Other semiconductors measure fine.
    I am thinking maybe shorted T1 transformer on the board? The iron transformer is not the problem, tried different one too.
    • 31256
    Re: APC Back-UPS RS 800 VA (BR800I) overload LED
    i would try changing the op-amp's
    • Behemot
      • 4845
      • CZ
      All five of them?
        • 31256
        the ones that seem related to monitoring the output.
        • Behemot
          • 4845
          • CZ
          Them all seem relevant all right
          • Behemot
            • 4845
            • CZ
            I 've tried removing transformer and measuring it with new ring tester, seemed OK. That unit was ditched.
            Got another one with blasted transistors again, seems like somebody tried to repair this one but they have been still blasted (maybe for second time?). Replaced, nothing. Replaced those foru optocouplers, nothing. I am flying blind here…
            • Christos K
              • Dec 2016
              • 1
              • Greece
              Hi, i had the same problem twice...!!!
              My battery was ok, everything was ok but
              the beep keep going on, for overload...
              Both times i fixed doing these steps...
              - Turn off the unit
              - Flip over the unit
              - Open the battery-cap and turn the power on
              - Green Light is flashing
              - Try Now (with the green light flashing) to disconnect the battery...
              - Now it should be ON with the Empty battery light on (Red light)
              - Connect again the battery as it is...
              Now it should be ok...!!!
              Good Luck...
              • Behemot
                • 4845
                • CZ
                Not really, that's no fix for anything, it's just temporary hack, maybe, for some situations.
                I've learned something about the Back-UPS BK650EI in the meantime which shares a bit of the same circuitry, plus I made the BR1500G explode and fixed it. In the end the FET driver was bad, and I also found similar condition as one of previous units showed: after turning it off, after a while all the LEDs started glowing. The problem is either in some of the small transistors arround the processor, or the processor itself. It should turn into low-power mode after 5-10 seconds, don't remember exactly. It seems that the CPU detects when it does not and shows fault.
                So it is good to check the SMD transistors as some of them may be bad. Also when FETs explode check the PWM modulator SG3525A near the CPU, mine was shorted.
                • Duckbill
                  • Apr 2017
                  • 3
                  I recently repaired my RS 800 which showed a variety of fault symptoms including overload until I finally was able to have it help me track down the fault (C60 in the -8V charge pump). Yup, a bad cap. I'll get to the details shortly.
                  The first APC overload issues I had were with XS 1500 and XS 1000 models. In both cases, it was the FET 'modified' sine wave switchers (34N20 or similar 20NQ20). I wrote an amazon.com review of these units years ago, link here: https://www.amazon.com/review/R26OF4E1QBAOUF
                  In the case of the RS 800, I suspected this type of failure again. The unit failed to provide backup, and with all load removed, on AC, pressing the 'on' button gave a momentary green light, followed by beeping and overload and replace battery LED's on, sometimes solid, usually flashing.
                  The unit had relatively new batteries, less than one year old, but pulling them out revealed that they were almost totally discharged. Swapping them out with known good batteries changed the behavior slightly, but overload and replace battery still came on, though now in intervals of a few seconds, and relay switching could clearly be heard.
                  I was able to gain some control manually using front panel button pushing sequence to lower unit sensitivity (this procedure can be found by google-ing). With low sensitivity, the several second switching changed to almost a buzz of the relays, but the overload and replace battery lights went out.
                  At this point, I connected a laptop to the unit's RJ45 port and installed APC's PowerChute software. The UPS was unloaded, the laptop independently powered. From there, I was able to lower the low voltage switching level to the lowest offered, 94V. This stopped the relay switching, and all lights went out except the green On-line. In the Current Status window, I was able to see the Input Voltage reading ranging between 99 and 121, even though an independent voltmeter (and oscilloscope) showed a solid 121V. This explained a lot, since the UPS had been set on high sensitivity and low over/under voltage tolerance. Due to its measured input voltage variation, it discharged the battery by rapidly switching off and on, never staying off long enough to recharge the battery.
                  So now, the question became why is the voltage reading incorrect? I'll shorten a long story, but first having a schematic is invaluable. If you don't have one for the RS 800, you can get it here:
                  It would have been possible for me to repair my UPC without an oscilloscope, but it was very valuable. I used a differential input to avoid as much common-mode noise as possible, with the battery negative terminal as the reference. The third terminal, Green wire utility ground is noisy and NOT the electronics ground. The circuit diagram referenced above shows a "Line Sense Circuit" and an "Output Line Sense Circuit". Output of the Line Sense Circuit was the expected sine wave but surprisingly full of hash. This hash noise was causing the measured voltage to fluctuate. By setting the UPC action low voltage lower than the hash noise induced variation, the unit was able to keep operating and charge the battery. I suspected a problem with the Line Sense Circuit, so looked at the Output Line Sense Circuit, expecting to see a good sine wave there, and providing a troubleshooting companion to the clearly malfunctioning Line Sense Circuit. To my surprise, I saw the same noisy variation there.
                  These circuits both use quad op-amp IC9, powered by +12 and -8V. The +12 terminal was clean, the -8V terminal was overwhelmed by the noise I saw on the Line Sense outputs.
                  This sent me to the "-8V Charge Pump" circuit, and from there immediately to output cap C60 (22uF, 16V). The hash noise was simply the charge pump oscillator signal feeding through. Temporarily bypassing C60 cleaned everything up, and replacing it fixed the problem for good.
                  Interestingly, the Current Sense circuits (needed for power calculation and overload) also use the -8V power supply. I've reasoned that the overload indication was due to these faulty voltage and current sense value (that coupled with a failing battery due to the incessant switching).
                  I hope this will be useful to someone ...
                  • Behemot
                    • 4845
                    • CZ
                    Interesting story But simply by measuring the caps with ESR Micro v4.0 I've learned ages ago that good start is usually to replace all the SMD crapacitors in these units, and than continue if there is something else
                    Thanks for the manual, I'll upload it here for backup. There is one question though. Can the unit handle long-life Chemi-Con LE? Their ESR is somewhat between standard and low-ESR, slightly closer to standard, according to my measurements. There are always GP craps in these APC units. I know that units like BExx0CP (FR) don't like these caps in most places (especially around opamps and all these other analog ICs), I could only use like 3 pieces there. What about here? After all, rated life of 10000 hours instead of 1000 hours is signifficant difference. Even though normal-sized GP 105°C caps, and also Chemi-Con, should still work much longer than the original craps, usually tiny 85°C. But still…
                    • Duckbill
                      • Apr 2017
                      • 3
                      Thanks for your reply Behemot! While I certainly agree with your rationale of simply replacing all the SMD caps, I do not have an inventory of components with which to make such a change. I must admit to having a bias for repair over replacement in general, even though it may not be economically sound -- I intensely disliked the notion of sending my UPS to a garbage dump. Considering only the replacement cost of batteries, after two replacement cycles, it is probably more cost effective to buy a new UPS than a third set -- nevertheless ...
                      As to your ESR consideration, you raise excellent points. I favor longer expected life over ESR in this application. To a significant extent, the built in surge protection mitigates ESR risk. Long duration heat exposure is a certainty, however. You may find it interesting that my failed SMT 22uF cap did not fail either open or shorted -- it still had a residual capacitance of 4.1UF. I replaced it with a normal sized GP 105° cap lying on its side, secured with a dab of adhesive.
                      My vocational work is largely theoretical and analytical, but I do have a reasonably wide understanding and knowledge of hardware from components to subsystems; I'm only able to work on hardware because I have a home 'lab' (workshop). I've always had an aptitude and interest in physical 'things', repairing electronics and machines for family and friends (and a little extra money decades ago when at graduate school). Lately, I've depended greatly on the kindness of strangers posting on the Internet to help me with these non-work interests. My post at badcaps is among my efforts to give back (and hopefully to get badcaps some 'clicks' if my post is interesting to others). By the way, I donated to elektrotanya.com via PayPal in appreciation to them for providing the schematic; I hope you can help them with a recognition of some sort.
                      • Behemot
                        • 4845
                        • CZ
                        Most of the new plastic UPS ppl buy are even way worse than this is, trust me.
                        Not sure bout Florida but I can get Panasonics quite cheap from distributor here. Usually higher capacity for half the price of APC-labeled Longs or similar cheap PoS. They do just this, take Longs, put APC sticker on them and sell it three times more expensive as RBC.
                        • Duckbill
                          • Apr 2017
                          • 3
                          By the way, I was thinking ESD, not ESR. At the frequencies in play in the UPS, I don't think really low ESR is necessary.
                          • Behemot
                            • 4845
                            • CZ
                            Does not matter if necessary or not, long-life caps always have lower ESR than GP caps.
                            • ohren
                              Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                              by ohren
                              Hello!
                              I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                              Measured voltages with no load:
                              After rectifier diodes
                              12V: 6.17 V
                              5V: 5.67 V
                              Secondary transformer pins AC measurement (really don't know if this says anything)
                              12V: 2-2.5 V
                              5V: 1.04 V
                              I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                              03-18-2023, 10:33 AM
                            • mikey5791
                              Is it possible for transformer substitution?
                              by mikey5791
                              Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                              Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                              My questions are
                              1. How do i test to see if the transformer is in good working condition?
                              2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                              Hope you guys understand what i was asking. My intention is...
                              11-03-2022, 02:11 AM
                            • dennis_elx33
                              3PHASE STEP-DOWN Transformer in Check
                              by dennis_elx33
                              Hello All,
                              i would like to post an interesting topic regarding 3-phase stepdown transformer which we suspect to cause an overcurrent (138A) which resulted to power tripped off of the HV power supply (80KV output).
                              Problem statement: Power tripped Off
                              Initial Problem: Found 2 IGBT and 2 rectifier diodes shorted (burnt).
                              Action Done:
                              1) Replaced the faulty parts with good spare.
                              2) Measured impedance of the 3phase input lines and found that L2 to L3 has 23.3ohm while other pairs are 51Kohm. This pins will...
                              12-02-2024, 06:52 AM
                              ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) Book Specification for Upgrade or Repair
                              This specification for the ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T101HA - X5DHD boardview and T101HA - X5DHD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                              09-06-2024, 04:40 PM
                              ASUS Transformer T304UA-P71SP-CA Hybrid (2-in-1) Pro Specification for Upgrade or Repair
                              This specification for the ASUS Transformer T304UA-P71SP-CA Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T304UA-P71SP-CA boardview and T304UA-P71SP-CA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                              09-06-2024, 12:00 PM
