Samsung PS43D450A2 with arcing/crackling sound under X-electrodes
  • Ijaz Ahmed
    • Dec 2013
    • 35
    • Pakistan
    Hello Everybody
    I have this PS43D450 Samsung Plasma with a strange problem which I haven't found a solution or even some mention of such a problem on the forums/internet.
    This TV when powered up, starts arcing (under the X-Electrodes or X-Flex cables) with loud popping sound and there does not appear any picture or even glow on the screen. It just keeps arcing. The Arc travels from panel glass to the back metal chasis, under the X-electrodes.
    I disconnected all X and Y electrodes (flat brown cables) and turned on the TV. In this state, I have observed the following.
    1) Green LED on control board blinks every 1 second (which seems normal)
    2) VS, VA, VSC and VE are all normal (as per panel sticker)
    3) Then I turned the TV off and connected X-Electrodes and only one (top) Y-Electrode and then ran the test pattern.
    4) Test pattern started on upper portion but many pixels were not coming ON. After few minutes of running the test pattern, many pixels started turning on.
    5) If I attach more Y-Electrodes, the arcing starts under the X-Electrodes. With only one Y Electrode, there is no arcing except when you power up the set and before the start of test pattern.
    What could be the possible reason ? I haven't seen this kind of problem before nor anybody else mentioned this kind of issue with a plasma TV.
    Help and guidance will be highly appreciated.
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Re: Samsung PS43D450A2 with arcing/crackling sound under X-electrodes
    IF you take the Panel Out of the Plastic case--You'll see that the tab has failed where it attaches to the glass, the copper/gold/grey of the tab/glass/conductors will appear burned....
    Ive seen this Twice--Both sets--On the same day--Although, its Not a very common fault--That was a VERY bad day!
    Unrepairable unfortunately--Although--As its on the X-SUS side, all the conductors are connected together, so you Could try conductive paint, but doubt it would last long with the extreme currents passed....
    TELEFIX
    • Ijaz Ahmed
      • Dec 2013
      • 35
      • Pakistan
      Thanks - under the circumstances, that makes perfect sense.
      You have seen two such sets while I got 3 of them. All Samsung, apparently having same fault i.e. tab bond failure on X-SUS side.
      I will take out the glass panel tomorrow and do a close up examination. Will post what I find there.
      Thank you again.
      • sir_anthony
        Samsung UE55D6200 Crackling Sound
        by sir_anthony
        Hello, TV has a cracking sound from the speakers, sound from the headphone jack is ok.
        with new speakers the sound is just as bad.
        UE55D6200
        BN44-00457A Power Board
        BN41-01587E Mainboard
        What exactly can I check, what could be the cause?
        How do I repair the error?
        I can't find a circuit diagram on the internet
        thanks greetings from austria
        08-08-2024, 08:16 AM
        09-07-2024, 05:50 AM
      • Ierwin
        by Ierwin
        05-13-2025, 03:31 PM
      • jchang
        Samsung UN70NU6900F no picture and no sound
        by jchang
        Hi all
        I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
        Symptom:
        No picture no sound.
        When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
        No sound at all.
        What I tried:
        1. I tried unplugging the left or right ribbon...
        01-09-2023, 06:28 PM
      • ChaosLegionnaire
        by ChaosLegionnaire
        09-13-2022, 09:02 AM
