Dell Latitude E6320 - Completely dead, no {lights,fans,CPU heat}
  • fuxxy
    • 318
    Just picked this up from the trash @ work.
    Dell Latitude E6320. Unsure of battery charge level. I *DO* have the docking station.
    When plugged into power adapter (even my wife's - known good), I get no lights from the laptop. Removed battery, press power button - still nothing.
    Tried the same procedure using the docking station to eliminate DC Jack wire/solder issue, same exact results.
    I've removed the mainboard from the laptop and see nothing out of the ordinary. What are some ideas I can try next?
  • fuxxy
    • 318
    Re: Dell Latitude E6320 - Completely dead, no {lights,fans,CPU heat}
    Battery voltage is 11.92V
    Label on battery says 11.1V, 65Wh
    • diif
      • Feb 2014
      • 6978
      • England
      Here's the schematic.
      • fuxxy
        • 318
        DEAR LORD thanks so much for the schematic!
        Current path:
        1) Battery and AC adapter supply +PWR_SRC
        RESULTS: GOOD
        PJP44 (+PWR_SRC) - 11.1V with only battery, 19.6V with AC adapter plugged in
        2) IC "PU2" takes +PWR_SRC and turns it into +5V_ALW, +15V_ALW, and +3.3V_ALW
        RESULTS:BAD
        PJP49 (+15V_ALW) - 0.0V
        PJP45 (+5V_ALW2) - 1.5mV(essentially zero)
        PJP63 (+3.3_ALW) - 0.0V
        Closeup of PU2 attached.
        • fuxxy
          • 318
          Can someone offer me some guidance on how PU2 works and how to test for proper operation?
          The chip is a SN0608098.
          • fuxxy
            • 318
            Namely, does it require gate voltage to "turn on"?
            Or is it simply apply +PWR_SRC and ground, and it automatically output +15V_ALW, +5V_ALW, and +3.3V_ALW ?
            I've searched everywhere I know of, and can't find a datasheet. It's manufactured by Texas Instruments, but it doesn't come up in a search on TI's website.
            • fuxxy
              • 318
              +15V_ALW Test points are PJP49
              +5V_ALW Test points are PJP47, PJP48
              +3.3V_ALW Test Points are PJP9, PJP50
              • trebo
                • 513
                • Wales, UK
                are you sure that's right, or is it SN608098
                • fuxxy
                  • 318
                  The schematic says SN0608098
                  The chip says
                  SN
                  608098
                  Thanks for the heads up, I didn't think I needed to be that precise
                  • trebo
                    • 513
                    • Wales, UK
                    Pm6686 = isl6236 = sn608098.
                    • khaahk
                      • Dec 2013
                      • 833
                      • Estonia
                      Seems like a spill victim from 1st closeup of PU2.
                      PU2 should output voltage if enable signals are present and VIN is present.
                      • fuxxy
                        • 318
                        Quite possible, I picked up this laptop from work and have no idea of it's history. It was placed in the bin, in a covered area, but still outside in the texas humidity.
                        from the MAX17101 datasheet, it has a separate 3.3V "RTC" pin, I do get 3.3V from that.
                        I'll doublecheck at the actual pin to eliminate trace damage.
                        Which is "Enable"? Pin 4?
                        Pin 4 - ONLDO - Enable Input for LDO. Drive ONLDO high to enable the linear regulator (LDO) output. Drive ONLDO low to
                        shut down the linear regulator output.
                        If it is, in fact, pin 4 - and it is driven high - what sort of voltage should I see? Around 5V?
                        EDIT:
                        It looks like pin 14 and 27 are also Enable pins.
                        4 is to turn on LDO regulator - Measured 0.263V
                        14 is to turn on "Output 1" - Measured 0.263V
                        27 is to turn on "Output 2" - Measured 0.263V
                        Still curious about "good" voltage. Trying to determine if the problem is with the chip itself, or the supply circuit.
                        • khaahk
                          • Dec 2013
                          • 833
                          • Estonia
                          4-5V should be "good", datasheet states that it should VCC voltage.
                          What is VIN voltage on PIN6?
                          • fuxxy
                            • 318
                            Pin 6 VIN is 20.0 volts with adapter plugged in. Roughly 12 volts with only battery.
                            • khaahk
                              • Dec 2013
                              • 833
                              • Estonia
                              Does the chip get hot?
                              PIN 7 output should be 5V.
                              • fuxxy
                                • 318
                                Chip does not get hot - Roughly 105mV on pin 7
                                • fuxxy
                                  • 318
                                  I'm concerned that some sort of logic on the board is shutting the regulator down. Would it be logical to remove the regulator and check pins 4, 14, and 27 for +5V?
                                  • khaahk
                                    • Dec 2013
                                    • 833
                                    • Estonia
                                    The PIN4 - ENLDO should get its high state from divider PR42-PR44 using signal ALWON which is coming from MEC5055 microcontroller. I think that MEC5055 is powered from PU14 3.3V_ALW signal. The PU14 seems like some kind of power/charging selector controller. Check PU14
                                    pin 18 - output 3.3V ?
                                    pin 9 - input 3.3V ?
                                    pin 1 - DCIN adapter voltage?
                                    • fuxxy
                                      • 318
                                      PU14
                                      Pin 1 - 19.8V
                                      Pin 9 - 3.28V
                                      Pin 18 - 0.1mV
                                      • khaahk
                                        • Dec 2013
                                        • 833
                                        • Estonia
                                        Seems like PU14 is not outputting 3.3V to MEC5055. Why - good question, some missing control signal maybe, maybe its not working as it should.
                                        Does PU14 get hot? Resistance from pin18 to gnd?
                                        If not then can you insert 3.3V manually to PIN18 and see what happens.
