Power, but no video on LG 60PN5700 Plasma flat panel
  • SurrealMustard
    • Jan 2015
    • 487
    • The United States of America
    Here's what I've got: 1 LG 60PN5700 60" plasma television that seems to power on normally (you can even see light output from the screen if you look closely) but displays no video. The back has been removed from the set and a visual inspection of all the boards reveals no obvious issues. The small green light on the board in the center occasionally blinks while the television is on (I'm guessing this is what it's supposed to do).
    Any ideas on what might be the problem or what the next step for troubleshooting might be?
  • capkid
    • Oct 2010
    • 1339
    Re: Power, but no video on LG 60PN5700 Plasma flat panel
    It sounds like it could be a ZSus issue. You'll need to start by checking for the standard voltages - there should be labeled test points on each of the boards:
    (1) PSU: VS and VA
    (2) YSus: -Vy and VSCAN
    (3) ZSus: VZB
    Please post clear pics of the circuit board layout if you need further guidance.
    LG Plasma Mal-Discharge Correction Service
    • SurrealMustard
      • Jan 2015
      • 487
      Measurements for the LG Plasma Television
      (1) PSU: VS and VA
      (3) ZSus: VZB
      On the power supply board, VS is at 200 and VA is at 55.
      On the Z sustain, neither VZB1 nor VZB2 registered any voltage.
      On the Y sustain, D Vy1 and 2 didn't seem to register anything at all either. VSC seemed to go off the chart on the multimeter no matter which connector I measured from - it just put "1" on the screen like it does when you're in too low of a range for the voltage that's being measured.
      All measurements were taken using the metal on the TV's framework as a ground.
      Last edited by SurrealMustard; 02-02-2015, 06:21 PM. Reason: updated voltage information
      • capkid
        • Oct 2010
        • 1339
        It doesn't sound like you took the readings correctly.
        VZB should be taken by simultaneously placing the negative probe on the negative test point and the positive probe on the positive test point, not using the chassis as ground.
        The VSC reading on the YSus is taken in the same manner as VZB. Can you take a picture of the -Vy test point on the YSus?
          If Capkid's tests are ok, the next step will be to jumper the EXT AUTOGEN points to see if you can get good test patterns.
          • SurrealMustard
            • Jan 2015
            • 487
            trouble points
            So you're saying that I should be putting one lead on VZB1 and the other lead on VZB2? I don't know how well it'll work because the pins are so close together, but I can give it a try.
            The VSC will present the same challenge, but I'll give it a look. Here's the connection on the Y board where I was testing the Vys (you've gotta zoom way in on the writing on the left, but it's there):
              I think you're misunderstanding. VZB is a test point on the Z-sustain, and it's usually marked across a resistor on the Z-sus board. Similarly, -VY and VSC are also marked on the Y-sustain. They are not the labels next to the connector coming from the control board.
              • SurrealMustard
                • Jan 2015
                • 487
                I see
                So I will not be finding or measuring these values on any connector, that clears it up a bit. I'll have to take a second look at it to see if I can find the correct locations of those points.
                • SurrealMustard
                  • Jan 2015
                  • 487
                  The board
                  Upon further inspection today, I was unable to find those points. Here's some photos of the boards:
                  Z:
                  Y:
                  • capkid
                    • Oct 2010
                    • 1339
                    I've attached annotated pics. I can't see the -Vy on the YSus. Can you take a picture of the label on the back of the panel that lists the voltages? Also, please include a pic of the back of the TV with all the boards visible.
                    Edit: It looks like your boards are different from the pics I posted, but the test points should be in similar spots.
                    • SurrealMustard
                      • Jan 2015
                      • 487
                      Follow up with proper voltages and pictures
                      Thanks, the points were right in front of me the whole time and I missed them somehow. The correct VZB reading is about 113 and the VSC fluctuates between 154 and 174.
                      Here are the pictures of the entire set and the sticker with the voltage information:
                        Wow, I think this panel may not use -Vy or may use some alternate drive method, as it's not marked? Really odd.
                        • SurrealMustard
                          • Jan 2015
                          • 487
                          Onward
                          In that case, any idea what the next troubleshooting step would be?
                          • capkid
                            • Oct 2010
                            • 1339
                            Yeah, I scanned the pics closely, and I saw no -Vy. Very different.
                            It looks like the VSC is having issues. I'd turn the TV off, unplug it, disconnect the Y-buffers from the Ysus, then turn the TV back on and recheck VSC.
                            Note: If you go to reconnect the Y-buffers to the YSus after the above test, wait about 10 mins. before doing so. The high voltage caps on the YSus need time to discharge.
                            • SurrealMustard
                              • Jan 2015
                              • 487
                              Buffer question
                              Because of the way the Y buffers are connected to the Y sustain, would it be better to disconnect them by means of unscrewing the Y sustain and letting it hang around unplugged from there or would it be better to do it some other way?
                              • capkid
                                • Oct 2010
                                • 1339
                                Unscrew the boards.
                                Disconnect buffer from YSus.
                                Screw YSus back onto chassis.
                                • SurrealMustard
                                  • Jan 2015
                                  • 487
                                  VSC Voltage without the buffers connected
                                  With the buffers disconnected from the Y Sustain, I'm getting just a few volts on the VSC. It's ranging from 0 to 30, but mostly hanging around the mid teens.
                                    So, just to check, the white connectors are fully out? If so, this would indicate a bad Y-sustain, to me.
                                    • SurrealMustard
                                      • Jan 2015
                                      • 487
                                      Confirmation
                                      Yup.
                                      Actually, now that I look at it again, the voltage fluctuates more like between 50 and 115, sometimes varying depending on what angle the leads are at.
                                      • capkid
                                        • Oct 2010
                                        • 1339
                                        I agree with Tom: Looks like a bad YSus. I'd try the logic control board test that Tom mentions in post #5, just to cover all bases. The logic board is the small one in the middle of the panel.
                                        • chazh
                                          LG 60PS11-UA 60-inch 1080p Plasma TV-service lit & video help needed
                                          by chazh
                                          This is my first posting, so forgive me everyone in advance if I made mistake(s) in my posting.
                                          I know there have been much about this plama tv already and I have read through most what I could find. However; I still have not come across any service lit/schematics for this tv. I even looked for the 50PS11 which would be basically relevant other than display size. Anyone know to find the documentation would greatly be appreciated.
                                          The set that I have has issues with lower third of screen being dimmer than the above portion. From my past experiences with tube, solid state,...
                                          09-01-2025, 08:56 PM
                                          HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
                                          This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
                                          09-12-2024, 02:00 PM
                                        • KYBOSH
                                          VIORE PDP4210EA Plasma TV 42 inch - No Video on DVI
                                          by KYBOSH
                                          Got my hands on an relatively unknown TV brand about two weeks ago.
                                          I certainly hadn't heard of it before.
                                          Previous owner didn't give a description of what was wrong and when I got it the back cover was already off.
                                          I put it on the back burner until I had so spare time to look it over.
                                          Today was that day.
                                          I plugged it in and was surprised to see that it started up without any issues.
                                          This is an older TV and the most modern video input that it has is DVI.
                                          I was scrambling to find a DVI connector or adapter as I haven't fooled with that...
                                          01-27-2023, 08:19 PM
                                          GeForce RTX2080 Super Aero video gaming card issues help need
                                          by sam_sam_sam
                                          This is from my son’s gaming computer that at first had minor overheating issues when playing a very intense game with it causing the computer to crash or reboot
                                          Then bough a new motherboard and a new computer case that a cooling system in it already installed also brought the cooling system for this video card but now the issue with it is that it randomly rebooted screen goes blank randomly and suddenly video freezing or started with video being there then blank screen and then the video comes back or it just stays blank for a while and then maybe it will come back but it...
                                          05-07-2023, 08:12 AM
                                          HP EliteBook x360 1030 G2 + GoPro HERO6 Black 4K Ultra HD Video Camera Notebook Specification for Upgrade or Repair
                                          This specification for the HP EliteBook x360 1030 G2 + GoPro HERO6 Black 4K Ultra HD Video Camera Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1030 G2 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and 1030 G2 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users...
                                          09-06-2024, 06:20 AM
