GPU PCB Schematics
  • chrle
    • Sep 2013
    • 158
    • slovakia
    GPU PCB Schematics
    hello,where I can find gpu PCB Schematics?
    something like this:
  • Sparkey55
    • Jan 2010
    • 1523
    Re: GPU PCB Schematics
    I would not call that a schematic. That is more of a parts placement/label diagram. If you had the graphics card in front of you, it would show it all on the silkscreen printing. Those type of drawings are relatively useless.
    • chrle
      • Sep 2013
      • 158
      • slovakia
      ok i need schematic to identify part that is missing on GPU board.
      • SteveNielsen
        Retired Tech
        • Jun 2012
        • 2327
        You need to supply more information. What GPU board is it? What is missing? Uploading good pictures of the board will help.
        • chrle
          • Sep 2013
          • 158
          • slovakia
          Asus hd 7950 -dc2t-3gd5-v2
          • re-atari
            • Oct 2010
            • 136
            The components look like they were sheared off by blunt force
            On photo 1, the left missing component probably is a 10nF smd ceramic cap, and the right component probably a 100nF smd ceramic cap. On photo 3 it looks like a diode is missing in action (silkscreen says 'D702'). Which type of diode? Your guess is as good as mine... I can't see anything missing on the other photos.
            re-atari
            • chrle
              • Sep 2013
              • 158
              • slovakia
              re-atari
              graphic card fell down on the floor,so this is why this parts are missing,ok I found D 702 diode from another gpu picture.
              • chrle
                • Sep 2013
                • 158
                • slovakia
                thank you guys ,so I need now only to identify C1467 cap
                • re-atari
                  • Oct 2010
                  • 136
                  Couldn't you spot the diode and other 2 components laying on the floor? Chances are you can resolder the diode right back on the board (after checking it with a multimeter, of course).
                  BTW: check the silkscreening to make sure the big component on the 2nd photo actually is a ceramic cap. It looks like the legenda is printed to the lower left, but it is only partially visible on your photo. The photos of the other board could be of help to you. And check the components surrounding the sheared off ones, I see a few looking less than pristine. C116 looks damaged. There might be other victims.
                  Edit 1: On the 2nd set of photos you uploaded you can see that both are actually ceramic caps. The left one is listed as C1600, but the part nr. of the bigger cap is not to be found on the silkscreening.
                  Edit 2: Only just now I see you indicated a 3rd cap on your first set of photos. As this one (C1467) is still in place I'd just resolder both sides. The same goes for C116 and C109. Solder one side first, and let it cool down before heating up the other solder side.
                  Consider yourself lucky if you get the board working again.
                  re-atari
                  • chrle
                    • Sep 2013
                    • 158
                    • slovakia
                    re-atari
                    Thank you re-atari , I will order new caps but how to know voltage? I need to measure good caps on board? 6.3v or 16 v?
                    • re-atari
                      • Oct 2010
                      • 136
                      AFAIK ceramic smd caps are 25V, that should suffice for your card.
                      re-atari
                        master hoarder
                        • May 2008
                        • 12175
                        • Bulgaria
                        The video card might just run fine without those ceramic caps (and at worst display artifacts or run unstable at full load). I'm not saying you shouldn't replace them, but don't worry about them now. First get that missing diode fixed - the video card won't run without that and you can damage something if you try it. That diode is 100% vital. Observe the correct polarity too.
                        • chrle
                          • Sep 2013
                          • 158
                          • slovakia
                          I contacted several Electronic Parts stores,but nobody have this diode..
                            master hoarder
                            • May 2008
                            • 12175
                            • Bulgaria
                            Well, that's not unusual.
                            No worries, though. This is the datasheet:
                            If it doesn't open, search for "SX32", and that should pop some good results.
                            It's a 3A SMD schottky diode rated for 20V reverse voltage and an average forward voltage drop of 0.5V. So just see if those parts stores carry any 3A schottky diodes - they don't have to be SMD. You can certainly use an axial diode too - the fix will just look a bit more ugly, but who cares.
                            Worst case, buy a 6A fast recovery diode/rectifier and use that. Why 6A? Because fast recovery diodes have a higher forward voltage drop (usually around 1V minimum), so it will be dissipating much more heat. Something like SPR600 will probably work. Actually even a 3A diode might work... like HER301-HER303, or MUR405, or PR3001-PR3007 <- all of these should be easily found as they are common diodes. But, of course, see if you can find a schottky first.
                            • chrle
                              • Sep 2013
                              • 158
                              • slovakia
                              thank you,momaka,I ordered schottky diode 3A 20V,I will post here when it arrives.
                              • Suoh
                                • Apr 2017
                                • 1
                                • Lithuania
                                Good afternoon. I own FX-795-TDJC v3.0 . The problem I am facing is that a few components are missing. To be more specific - Q215, R227, Q207 and D202. Is there any schematics or diagrams for this GPU board? Or, if possible , can anyone post the names of those missing components, so it will be easier to find a analog part to put instead of missing one.
                                • Popalwali
                                  Asus Nexus 7 2012 (ME370T REV 2.4) Schematics needed
                                  by Popalwali
                                  Hello Everyone,
                                  I will be really grateful if someone shares schematics and if possible the boardview of the old Asus Nexus 7 (2012) Tablet. The motherboard is ME370T Rev. 2.4. Now I can find schematics for the Rev. 1.0 but I could not find the schematics for the Rev 2.4. I tried to look for similarities in the Rev. 1 but there are somethings missing, plus the board i have has nearly no component names printed on it which as a newbie makes pretty hard for me to locate things. Any assistance will be appreciated. Thank you.
                                  08-25-2024, 11:28 AM
                                • Techmanx
                                  Schematics Download Site
                                  by Techmanx
                                  If anyone needs schematic diagrams for any pro audio gear like what professional musicians use, such as guitar amps, power amplifiers, vintage tube amps, musical gear like keyboards, effects pedals, guitar wiring diagrams and service manuals, check out https://schematics.ca . I'm a road musician and an electronics tech and I got schematics for just about every piece of gear in my band from this site and they are free to download. It's always good to be prepared in case you fry something while on on the road, which always happens it seems. https://schematics-free.com has a lot of free audio schematics...
                                  06-28-2023, 12:08 PM
                                • Plg_666
                                  Need schematics of Msi claw a1m
                                  by Plg_666
                                  Hello, comrades. I've encountered the following issue. I live in a small town, and we had a power outage. My girlfriend's MSI claw was unlucky because it was charging at the time and didn't turn on afterward. The local service center suggested replacing the Tps65993bh controller. However, after replacing it, the motherboard still didn't start. The technician believes that the processor might be dead, but he needs the motherboard's schematics to confirm this. Please share the motherboard schematics if you have one for this console or a laptop with a core ultra 5/7 125H/155h processor.
                                  Today, 01:35 AM
                                • CG_Dionysos
                                  MacBook Pro 15-Inch | Mid 2017 | A1707 | 820-00928-A | 3,1 GHz i7, Radeon Pro 560, 16GB, 1TB | Boardview and Schematics
                                  by CG_Dionysos
                                  I am looking for the boardview file and the matching schematics (PDF) for the following MacBook Pro:
                                  • Model: A1707
                                  • 15-inch, Mid 2017
                                  • 3.1 GHz Core i7
                                  • 16 GB RAM
                                  • Radeon Pro 560
                                  • 1 TB SSD
                                  • Board number: 820-00928-A
                                  I already searched the forum, but so far I haven’t found a matching boardview for this board. In several posts I came across, it was also mentioned that the uploaded files were often incorrect.
                                  Thanks in advance!
                                  Greetings from Germany...
                                  09-16-2025, 06:43 AM
                                • Tribalus43
                                  Lenovo Thinkpad T14 gen 2 intel schematics/boardview
                                  by Tribalus43
                                  Request: Lenovo ThinkPad T14 Gen 2 (Intel) Schematics/Boardview
                                  Hi everyone,
                                  I’m looking for the schematics or boardview for a Lenovo ThinkPad T14 Gen 2 (Intel) with the following board:
                                  HT4B07HP4B0 / HT5B1 / HP5B1 / HT4B2 NM-D352 Rev: 2.0
                                  I’m currently dealing with some startup issues and would like to test for shorts. Any help would be greatly appreciated.
                                  Thanks!
                                  09-01-2025, 12:10 PM
