SONY VAIO VPCCA15FG Shutdown randomly in 1 or 2 minutes..
  • degutji
    • Dec 2012
    • 173
    • Indonesia
    Hi All...
    Here is my story....
    SONY VAIO VPCCA15FG
    M/B : MBX-239 ( See attachment )
    Bios : See Attachment
    Test power on with lcd only and MB + Heatsink Fan ( no hdd etc ) DOS mode only, it will shutdown randomly at 1 or 2 minutes, it can power up again just for 1 or 2 minutes, just like that. HM65 Chips and PL16 get hot when we touch it's about 45'C measure with my DMM.
    1. Change PL16... Done
    2. Reball HM65... Done
    3. Change CPU... Done
    Any suggestion on this case ? I don't have shematic or couldn't find till now and bios dump file too. I've attach original bios with pic of MB
    Best Regards
  • techman1025
    • Jun 2014
    • 497
    Re: SONY VAIO VPCCA15FG Shutdown randomly in 1 or 2 minutes..
    Here is a different bios to test with ....if works i will fix me region meaning put a clean un used one. If still does the same thing see what voltage is falling out .... most likely core voltage .. alwon 3/5 should be present with just adapter plug in and not pressing power button..test point big square coils they should be the only one's with power with just adapter in. nexted CLK circuit 32.768 at crystal ? you could always check resistance in both circuit with no power to board and set meter to diode mode red probe on ground and black on +line .. also could be crack heat pipe ...have you tried one stick of memory in each slot one at a time? if one socket is bad just double up on good one. hope this helps
    techman1025
    Techman1025
    • degutji
      • Dec 2012
      • 173
      • Indonesia
      Techman1025
      Thk's for your respond Techman..
      Flashing bios with your file still does same, alwon 3/5 present for 20 seconds and missing alias no 3/5 after that ( but I still can power on even 3/5v missing on that coils ), here is I attach measurement on each coil
      Regards
      • techman1025
        • Jun 2014
        • 497
        Hi
        Ok what i need to know with just adapter in don't press power button. is the 3/5 stay there? it don't turn off ? also clk signal there 32.768 ? did you try a different power adapter maybe your's can't handle load? you could also check this by putting a dc 24V bus bulb as the load see if it stay's on.
        if yes i say no clk single ?. Maybe also I say the SN608098 is dead(RT8206A/B=ISL6237=PM6686=SN0608098)
        techman1025
        • degutji
          • Dec 2012
          • 173
          • Indonesia
          Hi...Thanks for you replay Techman,
          Stay there for 20nd's
          Dunno how to test it but I do have Frequency Counter
          Use a Workbench PSU 5A ( with charger still does same )
          techman1025
          I'll give it tray that and let you know soon
          Regards
          • degutji
            • Dec 2012
            • 173
            • Indonesia
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3599
              • slovakia
              "but I still can power on even 3/5v missing on that coils"
              thats not possible.
              • degutji
                • Dec 2012
                • 173
                • Indonesia
                thats not possible.
                it happen on sony vaio I've normal sony vaio missing 3/5 after 20 sec but u can still power on without problem
                • degutji
                  • Dec 2012
                  • 173
                  • Indonesia
                  Finally Done !!
                  • meritosari
                    • Oct 2010
                    • 774
                    • Indonesia
                    problem solved bro?
                    • storexxm
                      • Oct 2012
                      • 107
                      • Vienna
                      Originally posted by degutji
                      Finally Done !!
                      i think for other users it would be intressting... HOW ?
                      • degutji
                        • Dec 2012
                        • 173
                        • Indonesia
                        Originally posted by meritosari
                        problem solved bro?
                        Just put everything back and give it back to customer while saying this " Sorry can't help you, I give up " ( this sony have been 1 month in my table )
                        • mahmoud2561
                          • Nov 2015
                          • 1
                          • united kingdom
                          hi how u could flash bios?
                          thanks
                            Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                            This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                            09-06-2024, 05:27 AM
                            Sony VAIO VGN-FZ31J FZ Specification for Upgrade or Repair
                            This specification for the Sony VAIO VGN-FZ31J can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the VGN-FZ31J boardview and VGN-FZ31J schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO VGN-FZ31J...
                            Sony VAIO SVT1122I4E Hybrid (2-in-1) Tap 11 Specification for Upgrade or Repair
                            This specification for the Sony VAIO SVT1122I4E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVT1122I4E boardview and SVT1122I4E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                            Sony VAIO VPCM12M1E/W Netbook Specification for Upgrade or Repair
                            This specification for the Sony VAIO VPCM12M1E/W Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the VAIO VPCM12M1E/W boardview and VAIO VPCM12M1E/W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                          • Carlos#2003%
                            Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                            by Carlos#2003%
                            Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                            02-15-2024, 07:52 PM
