Sony VPCE range Board MBX-223 issues
  • Bisketti
    • Oct 2013
    • 252
    • Ireland
    Hi folks I have a spillage damaged MBX-223 i3 CPU here initially was dead /no power. The bios pins and pad were damaged swapped bios from same model scrap board and repaired traces. Unit now powers up with no Video it only draws max 1/2Amp on the bench supply.
    The GFX core was 0v so after checking around the regulator (PU25) and replacing pr127 and also Pu25 Im now getting 0.88v- 0.90v on coil PL19 (GFXCORE) . The screen continues to stay black on draw 1/2a and after a minute or so fan spins very fast also it will not switch of using powerbutton but will switch on?.
    Any ideas would be great
    MOD EDIT: Schematic moved - https://www.badcaps.net/forum/showthread.php?t=99921
    This thread moved to "Bios Requests ONLY!" section
  • polytek
    • Dec 2013
    • 496
    • TUNISIA
    Re: Sony VPCE range Board MBX-223 issues
    reprogram EC bios, it can cause no display,
    • silicons
      • Jan 2014
      • 7
      • India
      thanks for the bios
      • Attif
        Attif
        • Dec 2016
        • 49
        • pakistan
        thanks for bios bro
        • delelab
          • Jun 2017
          • 1
          • greece
          Thanks for bios bro nice work
          • mcoytzhi27
            Mr
            • Nov 2015
            • 43
            • philippines
            i have same issue with this model.. the fan spin fast then it auto off.. any idea guys?
            • mbertaina
              • Jun 2016
              • 7
              • Argentina
              hello, with this bios I could solve that the fan works fast and the machine turns off. I hope it works
              • nabilgo
                • May 2016
                • 303
                • L.A
                i still have same issue after progaming this new bios fan probleme then turn offf
                • Badcaps.netforum
                  • Aug 2017
                  • 8
                  • Peru
                  thanks for the bios...
                  • Andyservo
                    • Jun 2013
                    • 152
                    • Indonesia
                    • hussaka
                      • Jan 2015
                      • 154
                      • italy
                      thank you
                      • badisrep
                        • Apr 2021
                        • 17
                        • algeria
                        many thanks
                        • mikailcoban
                          • Aug 2014
                          • 73
                          • turkey
                          Sony Mbx-223 m971 bios
                          hi friend I need bios or programmed bios .. I didnt save old bios which is didn charge battery .. nor I have bios , no charge problem but after 40 minute shut down ..
                          Mbx - 223
                          M971 mainboard
                          6 layer rev :1.1
                          1p-0106200-6011
                          can you help me ..My bios is :
                          https://drive.google.com/file/d/1RZr...ew?usp=sharing
                          • mikailcoban
                            • Aug 2014
                            • 73
                            • turkey
                            Re: Sony Mbx-223 m971 bios
                            Mbx - 223
                            M971 mainboard
                            6 layer rev :1.1
                            1p-0106200-6011
                            https://www.alisaler.com/sony-vpceb3...x-223-bios-ec/
                            solve with kbc bios
                            • ME Tech
                              • Aug 2019
                              • 26
                              • Philippines
                              hello where can i find the EC bios sir? i can't find the EC bios chip please help
                              • peste
                                • Dec 2016
                                • 13619
                                • ROMANIA
                                the EC bios is in the I/O chip ...
                                • Thechaperman97
                                  • Oct 2022
                                  • 2
                                  • Ecuador
                                  Hi guys, I need the boardview of the mbx-223 mainboard please.
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 12330
                                    Boardview request here : https://www.badcaps.net/forum/forumdisplay.php?f=41
                                    • bhaskar
                                      • Nov 2015
                                      • 13
                                      • India
                                      Mother board is on and disply also ok but within in a minute its off...
                                      Main bios flshes from labone
                                      pls help
                                      • marian.pigna
                                        • Oct 2023
                                        • 12
                                        • Argentina
                                        hola amigo, con el bios que subiste se soluciono el problema de que a los 30 seg aprox se apaga de una la compu? es el bios del ec? como lo programaste? muchas gracias!
                                        Hi friend, with the BIOS you uploaded, is the problem that the computer shuts off immediately after approximately 30 seconds solved? Is it the EC's BIOS? How did you program it? Thank you very much!
                                        in English please..
                                          Sony Vaio VPCE DA0NE7MB6D0 Boardview
                                          Quanta NE7...
                                          10-29-2024, 03:43 AM
                                        • HarryZ
                                          Sony XBR-49X800G networking issues
                                          by HarryZ
                                          Aloha. First post here, hope I can find someone to assist me.
                                          I have a Sony XBR49X800G with streaming issues. The issue mostly occurs watching sporting events (basketball and football). The picture will sometimes get pixelated, sometimes freeze for a few seconds while the audio continues, sometimes it's jerky. In other words, you get a headache watching the TV.
                                          My ISP provides 500 Mb service and I have verified that I have at least 500 Mb on ethernet, and something over 300Mb on WiFi. I installed Analiti on the TV (it's an Android TV) and I get ~ 70 Mb on both WiFi...
                                          01-26-2024, 04:49 PM
                                        • Carlos#2003%
                                          Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                          by Carlos#2003%
                                          Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                          02-15-2024, 07:52 PM
                                        • PontyPCs
                                          Sony Android TVs eMMC Issues
                                          by PontyPCs
                                          Hi people.
                                          I have been trying to get my head round these issues with the eMMC putting the TV in to a boot loop condition, or completely dead, when a dump of the Boot 1, Boot 2 and USERDATA partitions have been made, the MLC lifetime counter has been reset, using the original eMMC with the RPMB partition intact and the eMMC is flashed with the original dump, Netflix and a few other Apps don't work. i assume all the DHCP keys and factory programmed RPMB access Key will be contained within the original dump, and as we are re-flashing the original eMMC i would expect every thing to work....
                                          12-10-2023, 10:43 AM
                                        • ptcriserx3
                                          Sony trinitron crt bowed and side color issues
                                          by ptcriserx3
                                          Hi
                                          Ive got a vintage 2001 sony trinitron flat tube tv
                                          The image is slightly bowed and the left and right sides about 1-2in has fluctuating discoloration that comes and goes if i move or hit tv on sides
                                          See many images attached...
                                          Just windering if this is not fixable or something i can correct without getting too invloved
                                          Im trying to sell the tv
                                          06-17-2023, 07:27 PM
