Dead Samsung 46" LED (model UN46C6300SFXZA)
  • Jidis
    • Nov 2013
    • 62
    I've been fighting off and on with a 46" Samsung LED television someone gave me last year and still haven't gotten a definitive answer to narrow the problem down to which board I need to order.
    Description:
    It's pretty much dead, and doing that common thing where you can hear the relay clicking once every five or six seconds when you try to power it up, with no other signs of life.
    Things I've tried:
    One of the first was disconnecting the main 18-pin ribbon link between mainboard and PSU. Some info seemed to state that this was a way to make sure the backlights worked and all, as the PSU was supposed to automatically enable everything in that case. No go here, unfortunately. With the mainboard offline, the unit just sits dead with no clicking and no way to start it. I think someone or something implied that they may have changed that behavior, so I'm not positive that disconnecting it should have worked here.
    Next, disconnecting the T-Con board. Same as before, just clicking relay and dead screen.
    Disconnecting any/all of the remaining small cables does the same dead screen with relay clicks, with the exception of that 10-pin or whatever it is that goes to the power on circuitry in the front panel. If that's out, you have no way to start it.
    Most of the main connector lines have really low voltages on them, often fluctuating. I think there are a few that hang around .3V, but the unstable ones are in the lower millivolts. I do get a solid 5.3V on the Standby pin there, and there's one other pin (P_DIM, I believe) which stays at 4V. The standby/power-on circuitry seems to work (remote or panel switch).
    I also tried feeding the available 5V into the "BL_ON" line to see if I could start the lights, but I guess there's too much else wrong with the set in this state (no lights).
    All fuses on the power board are intact, as is a small surface mount I saw on the T-Con board. There's also no sign of any poor condition electrolytic caps or any other visibly damaged components across the boards.
    If there's any "tell tale" procedure I can try, or have already tried, I'd like to figure out what I need to order. FWIW, I also have rework equipment here, but it sounds as if most of the stuff that goes wrong ultimately requires the swapping of full boards. I also wouldn't have a clue as to the tracking of a failed part with this mess, unless there was some specific part which commonly fails on this model (and isn't proprietary).
    Let me know if there's any other info which might help.
    Much Thanks,
    George
    PS- There's a story behind this set, but I'm not sure how much stock to put in it. The relative who gave it to me says that a tech came out to look at it, and installed two boards which didn't fix it, and it would have needed a third. All three would have made the repair too costly, but I don't know why he would sell him all three if the first two weren't the problem, and I can't see every board in the thing being faulty. He also said that the TV came up at one point, with a blank blue screen or something, which was when the tech said he would need the third board. Again, I wasn't there nor do I know the tech or whether he was on the level.
  • mmartell
    • Oct 2013
    • 3189
    Re: Dead Samsung 46" LED (model UN46C6300SFXZA)
    A lot of these sets (at least in the "D" series) are suffering from open LED's in the backlight system which will prevent them from starting at all.
    You need to find out if this set will fire the backlights with the cable between the main board and PSU disconnected. Then you need to be positive your PSU is good. Then you will know your backlights are the problem.
    As a last resort you could disassemble the panel to get to the led strips and test them but I would recommend you to troubleshoot the other causes first.
    • freakaftr8
      • Oct 2012
      • 3743
      Agree. Just got done repairing a sharp 60 inch with a failed led in one of the strips. It also prevented the tv from coming up.
      • Jidis
        • Nov 2013
        • 62
        Thanks Guys!
        mmartell- That (disconnecting the main ribbon) was one of the first things I tried, but it seems I may have read somewhere else that it might not automatically enable the backlight power lines.
        If I get *no* backlight power with the mainboard disconnected, what would be the logical next step? I may have to look into getting to the LEDs to check them as you suggest.
        Thanks,
        George
        • mmartell
          • Oct 2013
          • 3189
          Originally posted by Jidis
          Thanks Guys!
          Thanks,
          George
          Try to find the service manual or field guide for your particular model. Some need extra jumpers in place to fire the backlights.
          How many wires going from the power supply to the backlights ?
          • Jidis
            • Nov 2013
            • 62
            Hey again,
            Assuming that's the only other jack coming directly from the power board, there's eight (two bundles of four).
            If the "field guide" is a little four page thing with basic checks and troubleshooting steps, I've got that. It's called the "Fast Track Troubleshooting Manual". In there, they say that disconnecting the main ribbon and applying power should immediately bring the backlight up, but I swear I read some mention of that not working, either on different models or different board revisions. Could be wrong on that, but I guess if I can figure out if there's an LED issue that might answer it.
            I never had much luck finding an actual service manual.
            Thanks,
            George
            • mmartell
              • Oct 2013
              • 3189
              Well if that's what the Fast Track says then you either have a problem with your PS or your led backlight. Unfortunately there is no real test for the backlight other than what you've tried, especially without knowing how many leds are in there and how they're wired.
              • freakaftr8
                • Oct 2012
                • 3743
                Yea a sharp lc-60le810un quattron LED tv has 280 LEDs!! One went bad and the whole set goes down! Unfortunately I jumpered the one bad one and reassembled. Its a gamble now. Lol but man it looks good!
                • freakaftr8
                  • Oct 2012
                  • 3743
                  when and if you decide to disassemble the TV remove the screen the easy way is to get an inverter power supply but if you don't have the means to do so what I did is used a voltmeter and diode check mode and tested every single led to see if it Lights up. a good voltmeter has the power to light up an LED when I got to the last led it was dead barely lighting up and then died completely so I was able to confirm that that was the issue. It was the first led On the strip after the connector.
                  • mmartell
                    • Oct 2013
                    • 3189
                    So if you have a known good PS then your led backlight is faulty and you would need to go into the panel to repair.
                    • tibimakai
                      • Jan 2012
                      • 3680
                      https://www.badcaps.net/forum/showth...hlight=samsung
                      • mmartell
                        • Oct 2013
                        • 3189
                        Backlight should still fire with mainboard removed.
                        • mmartell
                          • Oct 2013
                          • 3189
                          Originally posted by freakaftr8
                          ...the easy way is to get an inverter power supply...
                          What do you mean by this ?
                          • freakaftr8
                            • Oct 2012
                            • 3743
                            A stand alone power supply for testing the led strips.
                            • Jidis
                              • Nov 2013
                              • 62
                              mmartell-
                              In that other thread, it sounds like tibimakai's set did the same as mine with no mainboard connection and just stayed dead, but his failed part turned out to be the mainboard itself.
                              Tom66 actually has a comment about it
                              Originally posted by tom66
                              May not apply for new Samsung LED, using multi-region dimming, it might need commands to set up the dim level on each LED.
                              I think that's why I was remembering reading something about newer ones not working like that anymore (with the mainboard disconnected).
                              tibimakai's power supply voltages at that 18-pin connector looked much healthier than mine though. I checked *while* the boards were connected and the set was switching on/off.
                              I like the idea of checking the individual LEDs (that's low-tech enough for me ). Stupid question, but can each of these lights be individually powered by a "normal" LED supply (something in the 2V range with a current limiting resistor)? I actually have a supply dedicated to that here.
                              Thanks again all!
                              George
                                You can test individual white LED using 3~3.6V voltage source with current limiting resistor to about 5~10mA. 2V is not enough to forward bias on white LED.
                                • Jidis
                                  • Nov 2013
                                  • 62
                                  Thanks Budm,
                                  I'll try to get that set up today if I can figure out how to get to everything. I'm hoping it's either that or the supply. Would seem to be a lot cheaper than having to buy the whole main board.
                                  George
                                  PS- I'm guessing that the main supply which feeds the whole chain of LEDs is not something we regular people can produce, right?
                                    It depends on how LED are connected in series per string, each LED has Vf of about 3.6V so multiply that to get at least that much voltage + the voltage drops on the current limiter resistor. you can tel which string is dead at least by putting the DC AMP meter with that string to see if it draws current at start up or not, that will at least tell you which string is dead due to open LED.
                                    • Jidis
                                      • Nov 2013
                                      • 62
                                      Ouch!
                                      If they're not a complete PITA to get to, I think I'll go with the original idea of just going through the chain with a small power supply.
                                      George
                                      <edit> If anybody's got any good threads or links on disassembling the backlight/screen part of these units, it might help. I'm looking now, but it doesn't seem to be one of the more common repairs.
                                      • Jidis
                                        • Nov 2013
                                        • 62
                                        Sorry to nag you guys on this, but still wondering if there are decent disassembly instructions for the panel part of these sets anywhere (to get to the LED strips). I'm trying to avoid ripping apart a bunch of stuff I don't need to.
                                        Thanks Again,
                                        George
                                          09-07-2024, 05:50 AM
                                        • jesterace
                                          Samsung UE49MU6400 acts dead until disconnecting backlights, then works.
                                          by jesterace
                                          Hi everyone I have this TV which was dead one day when I tried to turn it on. I've had the cover off and there was just a pulsating/electrical clicking/ticking noise from the PSU. I disconnected the mainboard as sometimes this works to just fire it up with backlights on? That didn't help. Same noise. Then I disconnected the backlight cable from the PSU and the TV came alive. It appeared to respond to the remote and i'm pretty sure it's fully operational when there is no backlight connected.
                                          However, I am in a dilemma.
                                          I tested the backlight outputs with the lights disconnected...
                                          10-20-2024, 10:15 AM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
