Hello all,
I think my IC7-MAX3 may be on it's way out. Although 2 or 3 caps are bulging and one has leaked, it still works fine. There are 5 suspect caps altogether, all of the same type/spec (1000 uF 10V).
I did find an old thread with discussion about this board here:
https://www.badcaps.net/forum/showthread.php?t=14718
And this image from the above thread shows the suspect caps:
https://www.badcaps.net/forum/attach...9&d=1306414325
I don't really want to replace the caps for fear of killing the board, but I suppose it's only a matter of time before the caps start to give me trouble?
Before I found this forum I bought some Panasonic FM caps with the correct specs in case I start getting problems, but after reading the thread I mentioned above it's not clear if they will be suitable or not.
So should I have a go, and would the caps I have be acceptable? I cant find caps from other manufacturers that have been mentioned as being suitable unless I buy from Chinese ebay sellers, which I'm weary of doing.
Thanks for any help.
