Acer AL2216W / DAC-19M009 dead?
    Re: Acer AL2216W / DAC-19M009 dead?
    U7 gives me 13 Ohms on middle pin vs. ground from the VGA connector, close enough to zero? =(
      Well, the regulator could be internally shorted to ground. The only real way to test would be to remove U7 from the board and measure the middle pad to ground. Once off, you can also try testing U7 with a 9V battery. Apply the 9V to the input and measure the output with your meter. However, without a load on the regulator, there's potential for a false reading. Of course, if you read a zero volt output, then you know it's bad for sure.
        Okay, i'll try it tomorrow. Thank you so far
          Looks like Jetadm is leading you to the right path to find the problem. If you remove the regulator and the low resistance reading is still there, then you can possible have bad MLCC , there are 5 of them that are connected to the regulator output pin, they tend to fail shorted out.
            I just unsoldered the regulator. Its resistance values are:
            GND/ADJ - OUT: 338 Ohms
            GND/ADJ - IN: 1810 Ohms
            IN - OUT: 1491 Ohms
            Looks fine so far, I guess.
            I measured the caps you marked on the picture. I unsoldered one side of each one and measured eachs resistance, all infinte -> caps are fine too?
              Are these the value measure at the pads on the board without the regulaor or the measurement made on the regulator itself?
              The resistance we are interested in is the OUT pin pad and Ground pad reading.
                Values are from the regulator itself. So I have to unsolder it again and measure between the connectors on the circuit board?
                  We need to find out where the 13 Ohms reading on the OUT pin is from.
                    Ah okay. I unsoldered it and it gives me the 13 Ohms between GND/ADJ- and OUT-pad.
                    Following the conducting path near the left cap you marked me (red) led me to the blue marked component. Ohm-meter gives me 13 Ohms between both pins and 0 Ohms between bottom pin and ground of the DVI-connector. The brown color implies that component being burnt, especially because its nearby "friends" are all black. What kind is it? It says "Z6" on circuit board and C2 (or 02?) on the component itself.
                      OK, you found it! Those are protection diodes for the Video dvi input signal, you can remove the burnt one out and see if the 13 Ohms goes away. They are use for the surge and spike protection for the DVI, there should be similar setup for the VGA input also.
                        I removed the burnt one and reassembled the monitor as far as needed to test if it works now.
                        Plugged it in -> no LED, no starting possible.
                        I measured the Voltage of top 2 pins from the PSU: 1.11V giving me 1.27V on the circuit where the sources of the LED-MOSFETs and the OUT-pin of the regulator are in. Any new ideas? :/
                          Ok , so the 13 Ohms is no longer there? And unless I read it wrong, what voltage do you get now at the Out put of the regulator, it should be 3.3V as Jetadm had indicated.
                            13 Ohms gone, 338 Ohms now (guess from the regulator OUT-GND).
                            The voltage is the 1.27V I mentioned above (remeasure gave me 1.35V now), thats the circuit in which the sources of the status LED controllers are.
                              From the thread, it is indicated that this is a 3.3V regulator, same as the other one on this board, both of them has the same number printed on them, right? If that is the case, this one should also put out 3.3v, it could be damaged due to that 13 OHMS load. You were getting less than 0.5V before you found that shorted component.
                                Did you test the regulator with the 9 volt battery? - post 22
                                  Yes, i just did. New 9V battery (delivered 9.6V) attached to the regulator gave me 3.6V from OUT-pin.
                                    The ADJ pin connected to the Negative of the batteries, and put a 100 Ohms resistor between Out pin and negative of the batteries, then check the output reading again.
                                      Guess i just wrecked it. Shortened OUT and GND with my multimeter tip, 0V OUT since then.
                                        I still think this regulator is already bad, I would just get another one.
                                        By the way, when you were measuing 3.6V at the output pin, was the AGJ pin connected to the negative of the batteries, if not, that may explain why you are getting 3.6 instead of 3.3V
                                          I'll order some new, hope they will be delivered on saturday and 0.29€/pc is a good price
                                          I checked the voltage of the battery with my multimeter, positive 9.6V were shown, so I put the GND/ADJ pin to the battery terminal where the black tip was while measuring the voltage.
