This is an interesting Philips based Hitachi/Fujitsu plasma TV. It is an ALiS (interlaced) 1024x1024 pixel display -- technically making it HD capable. But it uses interlacing to reduce the burden on the sustain electronics and buffer boards.
The fault with it is there's a rather loud buzzing which increases in pitch as the TV warms up. Picture is fine. But, I haven't yet got it to shut down! It seems to work perfectly. The only concern is the PFC seems to be misbehaving -- but the TV still functions fine. I had it running for 15 minutes no problem. Person I bought it off says it cuts out in 10 minutes. So, I don't know what to make of it.
I've got to fix the cause of the buzzing. I think the PFC is the problem as I have had a similar issue on Vestel-based sets. The bulk cap voltage is probably not 390~400V, but 260~325V... though I haven't been able to test. I might find it gets worse with a brighter image.
Construction quality is very good -- Rubycon, Nichicon, Chemicon caps only used. Typical old Philips design, a little overdone. Massive line filtering chokes... Never seen such big ones. And Hitachi/Fujitsu used all discretes, no hybrids. (Thanks go to them.)
And yes, this uses an 83V (90V) panel sustain voltage. Much lower than typical 200V.
