EVGA GTX 460 - Bad Caps
  • hoomanium
    • Nov 2012
    • 9
    Hi guys,
    I am looking for the correct caps to repair an EVGA GTX 460. There are two blown caps on the card. I have highlighted them in the pictures.
    The first one is slightly smaller and it's called: f0 820 2.5z
    The second one is bit bigger than the other and it's called: f0 ORCZ 270 16V
    I truly, truly, truly appreciate it if you can help me find the right caps to repair my card.
  • c_hegge
    • Sep 2009
    • 5219
    Re: EVGA GTX 460 - Bad Caps
    Stop using that big text please!
    The caps on there are Lelon polies, They made junk lytics, and I've long suspected that they may not be doing polies right either.
    It looks like you have 270uF 16V and 820uF 2.5V caps there.
    Use these for the 270uF 16V polies.
    For the 820uF 2.5V polies use these if they are 6.3mm diameter, or these if they are 8mm diameter
    • mockingbird
      • Dec 2008
      • 5484
      Good, we have a confirmed case that Matsuki/Lelon polymers are worthless, as I've always suspected.
      • c_hegge
        • Sep 2009
        • 5219
        I probably should add, replace ALL of the lelon caps, busted or not, because they will fail sooner or later.
        • hoomanium
          • Nov 2012
          • 9
          Thanks for the quick response c_hegge. I know for a GPU VRM I need "Ultra Low ESR" (The "PSC" Capacitors). Do they meet this criteria? Also, I'm not familiar with these brands, could you please tell me what will be the highest quality product I can find in the market to replace all the caps?
          • c_hegge
            • Sep 2009
            • 5219
            The PSC is simply a series of solid caps made by Chemi-con. The ones I suggested as replacements are all high quality Japanese capacitors, and their specs should be fine for this card.
            For Polymer caps, the following are known to be good reliable brands:
            Nichicon
            FPCAP
            Fujitsu
            Sanyo/OS-CON
            Chemi-Con
            The ones I suggested in my earlier post were from Nichicon.
            • hoomanium
              • Nov 2012
              • 9
              I'm thinking of purchasing this as the 8.0mm 270uF 16V and this one as the 6.30mm 820uF 2.5V. United Chemi-Con seems good to me. What do you think?
              p.s Please double check the specs just in case I'm making a mistake you can catch it.
              • mockingbird
                • Dec 2008
                • 5484
                Lelon "OCRZ" 16V 270uF:
                8x8mm: 0.010 5000
                8x12mm: 0.008 5000
                UCC "PSC" 16V 270uF 8x11.5mm:
                0.011 5080
                Lelon "OCRZ" 2.5V 820uF 6.3x8mm:
                0.007 5600
                UCC "PSE" 2.5V 820uF 6.3x8mm:
                0.007 5000
                The Nichicon polymers at Digikey are better rated.
                • hoomanium
                  • Nov 2012
                  • 9
                  I suspect that's due to the low price. Chemi-Con costs three times more.
                  • c_hegge
                    • Sep 2009
                    • 5219
                    The Nichicons I suggested and the Chemi-cons you were considering should both do the job just fine, go with whichever you like.
                    • mockingbird
                      • Dec 2008
                      • 5484
                      Digikey has better prices for Nichicon than they do for UCC. Nichicon polymers are just as good as Chemicon polymers, and they are around 50 cents less.
                      Here are my reccomendations:
                      2.5V 820uF $0.96
                      16V 270uF $0.84
                      Oh, and listen to c-Hegge and replace all the caps.
                      • hoomanium
                        • Nov 2012
                        • 9
                        Thanks guys for helping out, I really appreciate that. I got the Chemicon caps. Is there anything else I should bear in mind while installing the caps (what to do so that things don't come loose when they heat up etc.) Also, Do you think changing to higher quality caps will help achieve better over-clocking?
                        • c_hegge
                          • Sep 2009
                          • 5219
                          There's not much risk of other things coming off as you heat up the PCB, unless you touch other parts with your soldering iron.
                          Better quality caps probably won't make it OC better. That really comes down to the design of the cooler and the VRM. Better quality caps just don't blow up after a few years like the cheapies do.
                          • Per Hansson
                            • Jul 2005
                            • 5895
                            • Sweden
                            Just curious but that is a pretty recent VGA card; The GTX 460 series was launched in July 2010
                            When was your's manufactured and is it out of warranty already?
                            • hoomanium
                              • Nov 2012
                              • 9
                              No, I meant what kind of filler metal do I have to use for soldering the caps so they won't come loose while being under pressure in the future. I know there are different fillers and each one has a different melting point and other properties. What would you recommend?
                              • hoomanium
                                • Nov 2012
                                • 9
                                That's true. But, I got it from EVGA B-Stock. So, it's basically a refurbished product and didn't come with a warranty.
                                Great card though, that's why I want to resurrect it so badly.
                                • c_hegge
                                  • Sep 2009
                                  • 5219
                                  The solder itself holds them in. Just make sure the joints have an appropriate amount of solder.
                                  • Behemot
                                    • 4845
                                    • CZ
                                    How did you discovered the caps are bad?
                                    • c_hegge
                                      • Sep 2009
                                      • 5219
                                      I'm guessing they exploded
                                      I'm also guessing that the OP won't chime in again (he hasn't in over a month now)
                                      • Behemot
                                        • 4845
                                        • CZ
                                        Just that there are no bad on the pictures, is there more of them on the card?
                                          EVGA e-GeForce 7600 GS AGP 256MD2 [256-A8-N542-T2] with bad caps - fixed
                                          by momaka
                                          I did it again – I had to fulfill my inner desire to fix yet another old piece of hardware. This one is actually kind of worthwhile, too – it’s an EVGA e-GeForce 7600 GS AGP video card, model P/N: 256-A8-N542-T2. With the popularity of “retro” PCs from the Win9x to XP era going up, and the diminishing supply of decent AGP cards, it is expected their prices will go up. Or is it? I bought the this video card rather on the cheap side (~$9 USD shipped to my door), because the eBay seller listed it for parts or repair (and correctly noted the bad capacitors.)
                                          So, here is the...
                                          06-06-2020, 04:39 PM
                                          Seasonic B12 BC-550 – barely 2 years old and with BAD CAPS already!
                                          by momaka
                                          I know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
                                          For today's considerations, I have a Seasonic B12 BC-550 [A551bcafh] 550 Watt ATX power supply for you (click on links for full size images).
                                          https://www.badcaps.net/filedata/fetch?id=3591771
                                          https://www.badcaps.net/filedata/fetch?id=3591772
                                          It's a modern ATX unit with fixed (non-modular) cables and an 80-plus bronze certificate. Here's the label:
                                          https://www.badcaps.net/filedata/fetch?id=359177...
                                          03-12-2025, 03:42 PM
                                        • eryjus
                                          Heathkit IO-4205 Power Supply Caps
                                          by eryjus
                                          First, I am a complete noob with high voltage stuff. I'm learning, but I need help by someone looking over my shoulder.
                                          I recently came into posession of a Heathkit IO-4205 5MHz Dual Trace Oscilloscope. The documentation is copyright 1978. I'm told it works.
                                          I opened it up to check the caps before I applied power, and found the following black caps and wanted to know what they were. They are on the power supply board. I was able to read the name and model and came up with, "Nytronics 162J-1, 0.1uF, 20% tolerance, 2000VDC."
                                          05-10-2023, 11:21 AM
                                        • Paxman_Swede
                                          Identifying caps on an old Zoom 9000
                                          by Paxman_Swede
                                          Hello!
                                          I have two projects on my work bench. One is a friends dead JBL Xtreme speaker with a blown voltage regulator and corresponding bulged and shorted cap. That cap has clear markings so I know what replacement I need for it.
                                          The other project however is a whole different deal. It's a Zoom 9000 guitar effect from the 90th that has developed a devil hound howl when there is no input from the guitar. I'm guessing caps problem. So, since I don't really use this effect anymore I thought it would be a perfect project to learn on.
                                          I have studied the board and...
                                          01-14-2025, 09:51 AM
                                        • captain150
                                          Help with switching power supply caps
                                          by captain150
                                          I'm trying to repair two old VCRs, they both have bad caps. One has leaky ones, the other would barely run until I subbed in some caps from another power supply I had laying around (though they are the wrong values). This vcr works for an hour or two, but then the power supply starts whining and the picture gets lines in it. I didn't replace all the secondary caps, so another voltage might still be problematic, or the values I used are too far off.
                                          I've been on mouser and digikey but the options are a bit overwhelming. I just need some new ones that will work. They don't need to be top quality,...
                                          03-16-2025, 07:34 PM
