6600 Possible Poly-Mod?
  • delaware74b
    • Apr 2009
    • 628
    I have an older 6600GT PCI-E video card that still has 5 functioning Sacon FZ509's. I have researched that Nichicon HN's are a good replacement for these FZ's. All are 470uF 16Volt 8 x 12mm through-hole. ESR is claimed to be 1150mA @ 0.036 from Sacon's data chart.
    I can go with a lower-voltage on 2 of the caps as they have 5 volts and 2 volts (measured in circuit and running). The three remaining do have 12 volts on them.
    What would be recommended values in uF for the various locations or would I be better off just replacing them with the HN's?
    Also, who made the cap in the lower right corner of the board (the one with 1.02 Volts), looks like a 470uF 6Volt 10mm SMD.
    BTW, the remaining purple caps are Sanyo Os-Cons- 820uF 4 Volts.
    Stupidity should be a crime, especially for drivers. I have NO patience for them.
  • c_hegge
    • Sep 2009
    • 5219
    Re: 6600 Possible Poly-Mod?
    It looks like they all have space for 10mm caps. If so, you could use these for all of them. does the PCB also allow for a through-hole cap to go where the SMD one currently is?
    • delaware74b
      • Apr 2009
      • 628
      c_hegge - the back side of the board allows for through-hole components under all of the smd caps.
      • c_hegge
        • Sep 2009
        • 5219
        In that case, the 330uF Sanyo SEP caps should be fine for all of the 470uF 16V electrolytics.
        • delaware74b
          • Apr 2009
          • 628
          Thanks c_hegge.
          Just ordered the caps from this site.
          • Hemingray
            KABOOM!
            • Jul 2010
            • 143
            Are the ventless purple ones sacons too?
            • delaware74b
              • Apr 2009
              • 628
              They are Sanyo Os-Cons, 820uF 4 Volt.
              I pulled one of the dreaded FZ's so you can see the label. It tested at 2x the published ESR at .07 ohms but the cap tested within spec at 465uF.
              I suppose is wouldn't be too much longer before they
              • delaware74b
                • Apr 2009
                • 628
                I received the poly's on Thursday and installed them on the video card. I ran it for about an hour yesterday and all is well. The remaining Sacon's all tested at .07mohm despite testing fine for uF.
                • u666sa
                  HP Envy x360 13-bf0013dx (i7, 8gb) ipa32 la-m024p rev 1b short near PJ1802, type-c not switching to 19 volts
                  by u666sa
                  Laptop is HP Envy x360 13-bf0013dx, hp website link, it's an i7-1250U with 8 gig onboard ram.
                  Platform: ipa32 la-m024p rev 1b
                  Originally you'd plug power supply into it and it would take up to 1.2 amps and then drop to 200 milliamps and then go back up again to 1.2, staying all the while at 5 volts. Pressing power button would results in power LED blinking amber 3 times. 3.3 volt rail, 5.1 volt rail present, main power rail 8.8 volts. Power button test pads near EC chip 2.7 volts.
                  I found a short on the other side:
                  10-04-2025, 05:03 PM
                  AMD Radeon RX 6600 XT (RX6600XT) Schematic & Board View
                  The Radeon RX 6600 XT is a performance-segment gaming graphics card by AMD, launched on July 30th, 2021. Built on the 7 nm process, and based on the Navi 23 graphics processor, in its Navi 23 XT variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on Radeon RX 6600 XT. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The Navi 23 graphics processor is an average sized chip with a die area...
                  10-01-2024, 12:10 PM
                  FUJITSU CELSIUS W550 CELSIUS i5-6600 Specification for Upgrade or Repair
                  This specification for the FUJITSU CELSIUS W550 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the CELSIUS W550 boardview and CELSIUS W550 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for FUJITSU...
                  09-12-2024, 03:44 PM
                  FUJITSU ESPRIMO P956/E94+ ESPRIMO P i5-6600 Specification for Upgrade or Repair
                  This specification for the FUJITSU ESPRIMO P956/E94+ can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ESPRIMO P956/E94+ boardview and ESPRIMO P956/E94+ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                  HP Z240 Tower Workstation i5-6600 Specification for Upgrade or Repair
                  This specification for the HP Z240 Tower Workstation can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Z240 Tower Workstation boardview and Z240 Tower Workstation schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                  09-12-2024, 03:30 PM
