What is this? (Samsung SyncMaster 957p CRT)
  • goodpsusearch
    • Oct 2009
    • 2850
    • Greece
    Someone was cleaning his basement and gave me that 19" CRT.
    It is working, it has very good image quality, it's not a Trinitron unfortunately.
    I opened it to check the caps and the build quality. The caps are Samyoung / no name, not a single cap is made in Japan.
    I would like your opinion about that thing:
    https://www.badcaps.net/forum/attach...1&d=1352218675
    Is it a magnet?
    master hoarder
    • May 2008
    • 12175
    • Bulgaria
    Re: What is this? (Samsung SyncMaster 957p CRT)
    Nice score!
    Yes, I *think* that thing is indeed a magnet. Most likely it was added to fine-tune the convergence or something similar after manufacturing. I've seen similar "fridge-like" magnets in other monitors, so I'm only guessing that that's what it is.
    That SyncMaster 957p looks (externally) almost exactly like the 955DF minus the non-flat screen. Perhaps this was the 955DF's predecessor.
    That's not necessarily a bad thing. Shadow mask monitors usually have better focus than Trinitrons. I'm really happy with the picture quality and focus on my 955DF. In fact, it's my favorite monitor among my other monitors. It's got brighter blacks than I'd like, but other than that, the contrast and focus are superb.
    I don't think the capacitors will give you any trouble. I have put close to 2000 hours of use on mine and I got it 2nd (or 3rd?) hand, so who knows how many more it's had. If they were to go, they should have done so by now because mine runs miserably hot in the summer.
    Just a curious question, what's the manufacturing date on your 957p?
      You are correct, they are weak magnet for helping the convergence adjustment of the electron beams. I am so glad that I do not have to do any more convergence adjustment on CRT any more since I do not work on them any more, especially when you have to install new CRT, you can easily spend hours doing it.
      • goodpsusearch
        • Oct 2009
        • 2850
        • Greece
        Summer/Autumn 2003. I can't remember the exact month right now
        Btw the day I collected that monitor I also got a 21" Sanyo CRT TV!
        The thing has seen better days.. The brightness was too low and the image did not fit the entire screen.
        It is an 80s TV, made in ~1982, I assume this from the datecodes of the capacitors. All the caps are Jamicon and Rubycon and there is only 1 Capxon. The TV was serviced in 2001 (there was a note on the PCB) and they probably used the Capxon as a replacement cap.
        I checked ALL the caps with the esr micro meter (took me hours, there must be more than 60 capacitors in there) and found 3 bad/going bad. After replacing the 3 caps with good ones, the brightness improved dramatically and the image fitted the screen perfectly
        But the screen had serious focus problems too - I could hardly read the subtitles... I took a screwdriver and played with the focus setting of the fly-back transformer. Having never done this before, I have to admit I was a bit afraid, who wants to be zapped with 30.000 Volts?
        It improved a lot, but still it is not sharp. The colours are not great, but acceptable, especially for a TV of that age.
        I could post some pictures if you like.
          master hoarder
          • May 2008
          • 12175
          • Bulgaria
          Interesting.
          So the 957p is newer than the 955DF (mine was manufactured April of 2002). I wonder why they switched to the curvy tube then.
          Were any of the bad ones CapXons by any chance?
          I don't mind either way. I like CRTs, so I never say no.
          Meh, I wish I caught the time when CRT repair was still popular. I give my respect to oldschool analog techs any day!
          • goodpsusearch
            • Oct 2009
            • 2850
            • Greece
            Interesting.
            It is possible that the 957p was the more affordable 19" Samsung CRT at that time.
            The 3 bad ones were 2 Jamicon and 1 Rubycon. All the caps on that TV were 85°C. I believe heat and time killed them.
            Here... Take a look.
            Btw I used Chemicon KY, Nichicon He and Lelon as replacement caps. Lelon was the only cap I had in stock at 1000uF, 63V.
            I am a fan of CRTs too. Back at those days they tried for better and better image quality and built things to last, not cheaper and cheaper LCD monitors, that fail just right after the warranty expires.
            • shovenose
              Send Doge Memes
              • Aug 2010
              • 6575
              I fondly remember the Dell CRT I used for a while - the thing had great picture quality!
              Mom made me get rid of it
              Now I'm happy with 3x22" LCDs
              But CRT never had dead pixel and a little impact to the front didn't cause damage
                09-07-2024, 05:50 AM
              • soopacrucial
                Samsung Syncmaster 740BF repair
                by soopacrucial
                Hi folks,
                I'm new here and was wondering whether you might be kind enough to give me some advice on troubleshooting the following problem:
                Quite a few years ago now, a couple of years from new, my Samsung Syncmaster 740BF LCD monitor starting playing up by making a buzzing noise and then the display would go blank. I seem to remember the blue power led would also go off when this happened but that I'm not 100% sure of. By pressing the power button I do remember I could at first get it working again but eventually the problem would come back. At the time I had read about...
                10-29-2024, 02:40 PM
                09-06-2024, 11:40 PM
                09-06-2024, 08:40 PM
