Aquos LC-37H4VU - Blinking Red Light
  • pentium
    • Mar 2006
    • 2778
    I put this TV which was missing its AVR into service as a DVI computer monitor and for the last week it was working flawlessly until I tried programming the remote (which I know sounds weird).
    While programming the Microsoft media remotes the TV was rapidly being turned on and off by accident. Halfway through the second remote it started to turn back on, then the power light went from green to blinking red. No smoke, no nasty noises, no smells.
    Did a google search and apparently the all-around indication of a blinking power light is the PSU has a fault. Opening the unit and turning it on I can hear a faint squealing that changes pitch as the front power LED goes on and off.
    It will however respond to the power button and remote still so the standby power seems to be okay.
    Board is otherwise very clean (wasn't even dusty and the PCB shows no signs of any concerning overheating). All the caps are either KMG or Rubycon ZL. Same seems to apply on the backlight inverters too. I'm assuming the rapid on/off has blown one of the switching transistors, am I correct?
    Find Nedry!
    Check the Vending machines!!
    <----Computer says I need more beer.
    Re: Aquos LC-37H4VU - Blinking Red Light
    If there are any fuses apart from the main fuses blown, then the switching transistors have gone, however my bet would be on the output diodes or the main board (there are usually lots of fuses on those.) Or, maybe the EEPROM is corrupt, or the firmware is (which would be a difficult fix.)
    • pentium
      • Mar 2006
      • 2778
      Well the fuses seem alright so far on the power board and inverters, I have no way to see if the EEPROM is corrupt (why would it do that? Power surge?)
      If there are any diodes on the lone main board (you meant the video logic board, right?), I'm assuming they are surface mount.
      I have not pressed that little green button by the way. I'm too terrified on what it might do.
      Where is the best place to start desoldering and testing components? The transistors on the power board that are attached to the four heatsinks? What about for diodes? I totally wanted to spend my weekend doing this.
      Find Nedry!
      • pentium
        • Mar 2006
        • 2778
        Okay, I'm going to need the service manual.
        After several days of poking around and googling I found a random note that someone was able get their TV to work by pressing INPUT and VOL - while pressing the master power button. I tried the same and sure enough, the power light went green, the backlight came on and I got a picture.
        So, the tv is technically fine but something went out of spec and outside of service mode the screen will prevent the user from using it. The service manual will better tell me what the service mode screens are telling me, unfortunately like all service manuals it's one of those things where everybody has it and you can too....for a premium.
        Find Nedry!
        • pentium
          • Mar 2006
          • 2778
          To respect XKCD's Wisdom of the Ancients, here is the fix I found:
          -Put the TV into service mode
          -On the first screen, scroll down to "L On Reset = 5" (the number might be different and that might mean other problems)
          -Toggle the 5 to 0
          -Turn the TV off
          When you power it back on the unit should work fine.
          If not, go back in and see if "L On Reset" reverted back. If it isn't 0 anymore, something is in a state where resetting the onboard safety will not fix it.
          Find Nedry!
          • pentium
            • Mar 2006
            • 2778
            This thread is old as shit but over the last three years it proceeded to get worse and worse and worse to the point that it just wouldn't fire at all. We also gained a second problem where the screen would fire but you would have an uneven green crawl across the screen left to right.
            I traced the source of the problem to an intermittent connection on the Digital board. Pressing down on one of the XILINX chips would make the backlight fire every time (pictured middle left). Not pressing on it or tapping around the digital board meant that the backlight would fail to turn on.
            After shimming that specific chip failed to give a reliable fix I decided to reflow the three Xilinx chips, the firmware ship and a half dozen other small SMD IC's. Learning experience time here. I've never reflowed pins this close together. Almost screwed up twice but after tediously repairing one mistake the set was reassembled and now it will always fire the backlight. Yay!
            Now, once and a while it will completely kick out and require a power cycle (no diagnostics mode needed) but that might be because I used a new type of flux that wasn't washing off as easily as I wanted and as the set heats up it becomes conductive (bad). I will have to source a much stronger flux cleaning solution besides rubbing alcohol.
            Find Nedry!
            • YasaCh
              Sony kdl 40p5500 red light keeps blinking 3 times
              by YasaCh
              Hello...
              my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
              i opened the back cover no sign of damage on the powery suply or motherboard
              when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
              another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
              07-07-2025, 11:53 AM
            • Fergal22
              Samsung UE40F5300AK blinking red light
              by Fergal22
              I have the above tv that just shows a red light blinking twice 5 times, i have taken the back off and all the capacitors seem ok,
              When i disconnect the mainboard from the PSU all the led's light up blinking fast but as soon as i reconnect the mainboard back to the power supply i get the red light blinking again twice 5 times,
              I have attached pictures of the Mainboard, PSU and a small video (zipped) showing what happens when i disconnect the lead from the psu
              Any help would be appreciated...
              02-02-2023, 09:19 AM
            • matty24
              Samsung UE50MU6172 - red light blinking
              by matty24
              Hello. I have problem with Samsung UE50MU6172.
              TV won't turn on, red standby light is blinking.
              Power supply BN44-00807A is fine. I replaced it with the new one.​
              Main board BN41-02568B (BN94-12530E)
              I've read a dump (W25Q40CL). Can someone check it od fix it for me?...
              03-02-2025, 08:57 AM
            • norbiszoke
              Samsung 50AU7172, only blinking red light
              by norbiszoke
              We have this set here in our shop that is not ginving sign of life besides red light that is blinking one time after pressing the button and nothing more... After detaching the mainboard from the PSU (this set has separate board thank god?! or not...) the backlight comes on. After reattaching nothing besides red light.... Can anyone from the forum help me here? Thank you in advance. Here's a link with images of the mainboard and the memory IC's that are on it.
              Regards, Norbert!...
              04-17-2024, 06:54 AM
            • huzo
              HP 470 G5 blinking amber light no power
              by huzo
              The board is daox8cmb6eo and i can't find no boardview or schematics on the forum or anywhere...
              So i plug in the charger, amber light starts blinking ,there is 3.3V and 5V present, and 2.4V on the power button,board doesn't turn on, no shorts...
              I've tried flashing the bios...
              interesting thing is the battery was around 7,8V, and it's 11.1V battery, the mosfet near the battery is open, but not charging,i desoldered it,tested it and it's fine ,but the amber light kept going on the charger so i charged the battery with power supply and got it to about 10.5V...
              06-08-2023, 04:08 PM
