Supermicro P4SBA
  • jakah
    • May 2006
    • 31
    Supermicro P4SBA
    Hi!
    I got an old Supermicro P4SBA board for free because it had bad caps. I bought an old cpu for it (Northwood 1,6), and new caps to replace the bad ones with. The bad ones are all labeled "NRSY 1000uF 10V". There were 14 of these. For replacement, I bought 14 "Elna 1000uF 10V"s.
    I'm running x86-memtest on the system now, and it seems to be running fine!
    I took a few pics of the board, before and after recapping.
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: Supermicro P4SBA
    NRSY 1000uF 10V
    elna are making low esr caps?
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      the green nrsy are said to be counterfeit.
      what series elna did you use?
      • Chris1992
        • Apr 2005
        • 561
        Elna RJ* series are low ESR. RJJ, RJF, RJH are three that come to mind. (I've called Elna as they are the only cap manufacturer AFAIK that has a toll free USA number)
        The great capacitor showdown!
        • jakah
          • May 2006
          • 31
          Thanks for you replies!
          Willawake: Apparently
          I used RJH ones.
          Jakob
          • Ady2017
            Are there any datasheets available for Elna RJG capacitors?
            by Ady2017
            I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
            05-25-2025, 02:19 PM
          • Topcat
            Topcat's Supermicro X10DAI Build - Plus NVMe BIOS Mod Inside
            by Topcat
            Yes, I know I don't post this stuff much anymore....the only reason I'm posting this one is because of a NVMe adapter incompatibility; seems rather planned by Supermicro.....or I'm atleast a bit suspicious. It's plenty new enough to have a UEFI bios but a short 'happy list' of NVMe controllers that will work with this board, as if by some 'miracle', all Intel....so lets start at the beginning; we'll get back to this later.
            Of course the motherboard is as the thread title states; X10dai....but we'lre going to have some fun shoehorning this into a modern 'gamer case' that can actually...
            09-29-2024, 03:55 PM
          • nissimezra
            Supermicro C9X299-PG300F bios dump
            by nissimezra
            Device Desktop motherboard
            manufacture: Supermicro
            motherboard: C9X299-PG300F
            S/N: ZM187S026581
            Problem: Black screen.
            Description
            The customer reported a message: usb device over current status detected.
            I tried to download the bios from the manufacture, It has a bin file but didn't work. I'm not sure if the bin file design to be programmed directly to the chip or maybe I need to extract the body
            I programmed this bin file but didn't work.
            https://www.supermicro.com/en/suppor...99-PG300F/BIOS...
            02-09-2024, 08:57 AM
          • frans00000001
            Supermicro Server mainbaord x10dri-ln4+ schematic
            by frans00000001
            Good day
            I am looking for a mainboard schematic for a Supermicro Server mainbaord x10dri-ln4+ as the track broke off on the BIOS chip and I want to repair to use the server again. If possible can someone assist to get this schematic?
            08-06-2025, 05:36 AM
          • Olkus
            Elna capacitors - fake?
            by Olkus
            I have capacitors like this one in the photo. There are differences between other Elna series, I attach foto of Elna RE3. On this green capacitors series is not specified! Fake?...
            09-01-2023, 02:45 AM
