Intel D925XECV2 with bad Nichicon HN
  • goodpsusearch
    • Oct 2009
    • 2848
    • Greece
    That motherboard posts and beeps normally.
    The only obvious problem is a bulging Nichicon HN 1000uF 10V 10mmx12.5mm that is placed next to the 24pin ATX connector.
    The datecode on the capacitor is H0513. Correct me if I am wrong but doesn't that mean that the cap was made after Nichicon admitted the problem and corrected it?
    If the above is true then what killed the cap?
  • c_hegge
    • Sep 2009
    • 5219
    Re: Intel D925XECV2 with bad Nichicon HN
    It supposedly was fixed by then, but maybe PCBONEZ can confirm. Maybe it was killed by a bad PSU or got too hot.
    • goodpsusearch
      • Oct 2009
      • 2848
      • Greece
      I replaced the bad Nichicon HN 1000uF 10V 10mmx12.5mm with 1000uF 16V Panasonic FM 10mm x 20mm.
      There is another Nichicon HN 1000uF 10V not bulging. I would replace that too with Panasonic FM, but the extra length of the Panny would block the PCI-E graphics card...
      The board works like a charm
      • goodpsusearch
        • Oct 2009
        • 2848
        • Greece
        The second Nichicon HN bulged and I had to find a way to make the Panny FM fit. I placed it horizontally, thanks to the long leads. I forgot to take pics though.
        • Clutchbox
          Cap Clutcher
          • Sep 2011
          • 41
          • The Netherlands
          You could have placed a nice Polymer instead for a perfect fit.
          • goodpsusearch
            • Oct 2009
            • 2848
            • Greece
            Aint nobody got money for dat
            • c_hegge
              • Sep 2009
              • 5219
              Was gonna say. It's not worth it on an old board like that.
