17pw26-4 psu
  • hifiguy
    Geoff Scott
    • Jun 2011
    • 12
    17pw26-4 psu
    Hi
    I have a Bush TV in for repair with the standby light flashing rapidly. I've fitted the repair kit ie. C878, 801, 892, 817 and IC829 but the fault is the same.
    Anyone had this? Or any tips?
    Help would be very much appreciated.
    Geoff
  • PlainBill
    • Feb 2009
    • 7034
    Re: 17pw26-4 psu
    Originally posted by hifiguy
    Hi
    Geoff
    Is the standby light flashing in any discernible pattern? Some manufacturers use this as a means of displaying error codes. Others just flash a particular color (standby / power, etc) to indicate a problem.
    Have you checked the output voltages of the power supply?
    Elektrotanya.com has many service manuals; searching the model number of the TV might help; the model number of the power supply doesn't generate any hits.
    PlainBill
    • hifiguy
      Geoff Scott
      • Jun 2011
      • 12
      Re: 17pw26-4 psu
      PlainBill
      Hey Plainbill,
      Thanks for a speedy response.
      The standby light simply flashes with no pattern (I know what you mean about fault codes). So far I haven't found a schematic but I'm hopeful. This type (vestel) psu's are prone to failure as I'm sure you know and usually caps are to blame although I have known one or two exceptions and I'm guessing this one.
      Thanks again. I'll check at Elektrotanya.com.
      Geoff
        Re: 17pw26-4 psu
        I've tried repairing a 17PW20.1 with an identical fault. LED flashes 2-3 times a second.
        My debugging so far has pointed entirely to the power supply; the rails are too low (12V measures ~4.5V, for example). At the moment, it's in the corner of my room, waiting for repair.
        The main board tells the power supply to come on, however the rails are too low, so it shuts down. The cycle repeats until power is disconnected. The main board is what is telling the PSU to go on/off and is what is causing the rail to be so low, but I don't think it's at fault itself.
        • hifiguy
          Geoff Scott
          • Jun 2011
          • 12
          Re: 17pw26-4 psu
          Hi Tom
          Some progress but no real advance (hmmm) Having changed caps and reg I've found D893 s/c. Changed it but the fault remains. I'm searching for service info for the whole set but that's not proving easy.
          Cheers
          Geoff
            Re: 17pw26-4 psu
            Schematic for 17PW22 (the name of the chassis, the PSU itself is 17PW20.1) available on eserviceinfo; just search for "17PW22".
            I've got one for a Sanyo TV, somewhere....
            • hifiguy
              Geoff Scott
              • Jun 2011
              • 12
              Re: 17pw26-4 psu
              Tom, I found the schematic you directed me to. Thanks for that. The diagram doesn't seem to agree with the psu I'm working on. The search continues.
              Thanks again
              Geoff
                Re: 17pw26-4 psu
                Thanks again
                Geoff
                In my case the schematic was okay, but the PCB layout was completely different.
                • hifiguy
                  Geoff Scott
                  • Jun 2011
                  • 12
                  Re: 17pw26-4 psu
                  Ok got the cure.
                  D881 (893) s/c. Print side there is a 0 ohm smd link o/c. Replaced and now all ok.
                    Re: 17pw26-4 psu
                    Ok got the cure.
                    Maybe I should check that on mine.
                    • hifiguy
                      Geoff Scott
                      • Jun 2011
                      • 12
                      Re: 17pw26-4 psu
                      Good luck Tom
                      I noted that on the diagram it showed two 2k2's feeding the cathode but the board I've got just had the one 0 ohm at R1036.
                      • nopain77
                        • 8
                        Re: 17pw26-4 psu
                        Got the same thing on a Telefunken T40R882FHD with powersupply 17PW26-4
                        Error was : On (Red) and Standby LED (blue) blinking alternately.TV stuck in standby.
                        Replacing the D881 with another ultrafast rectifier did it.
                        Thanks for post it.
                        • blado1984
                          • Feb 2012
                          • 1
                          • England
                          Re: 17pw26-4 psu
                          Hi guys just a quick question. I have this issue with my alba tv and 17pw26-4 board. Started off as flashing red and blue and eventually ended with tv completely stuck in standby (condtant blue light). I have replaced c801 and c892 no change so replaced d893/d881 still no change. When i press touchpad there is an audible *beep* but light stays blue. Using thr remote seems to do absolutely nothing. Just wondering that seeing as i am now past the flashing red/blue stage and stuck on constant blue does this mean total board failure? Thanks in advance
                          • abdekader
                            • Jul 2014
                            • 73
                            • Turkey
                            Re: 17pw26-4 psu
                            My 17pw26-4 , no 12v why?
                            5v ok
                            3.3 ok
                            what's the problems ?
                            Electronic Engineer from Syria,Aleppo
                              Re: 17pw26-4 psu
                              Any 24V?
                              • abdekader
                                • Jul 2014
                                • 73
                                • Turkey
                                Re: 17pw26-4 psu
                                No 12v , no 24v
                                  Re: 17pw26-4 psu
                                  Got PSON signal? What is VCC at FAN7711 for the main outputs? Do you have about 390V at the 450V capacitor?
                                  • abdekader
                                    • Jul 2014
                                    • 73
                                    • Turkey
                                    Re: 17pw26-4 psu
                                    Pson where
                                    in capasitor 306v
                                    in vcc 7711 about 14 but flip flop
                                    • promo7uk
                                      • Aug 2014
                                      • 31
                                      • uk
                                      Re: 17pw26-4 psu
                                      HI REASON FOR NO 12V & 24V IS FAULTY DIODE..
                                      COMMON PROBLEM ON THESE POWER SUPPLYS IS FEED DIODE GOES OPEN CIRCUIT MUST REPLACE WITH SAME.UF5404
                                      http://www.ebay.co.uk/itm/UF5404-DIO...item2ec783c7b5
                                      17PW26-4 FAULT NO 12V NO 24V ,,,,, DIODE PLACEMENT,
                                      • promo7uk
                                        • Aug 2014
                                        • 31
                                        • uk
                                        Re: 17pw26-4 psu
                                        Heres faulty diode mate,, let me know outcome thanks lee
                                          Acer TravelMate B118-M-C878 Notebook B Specification for Upgrade or Repair
                                          This specification for the Acer TravelMate B118-M-C878 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the B118-M-C878 boardview and B118-M-C878 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-06-2024, 08:32 AM
                                        • tvguy12012012120
                                          by tvguy12012012120
                                          02-07-2025, 05:13 PM
                                        • fharris1977
                                          Vizio D50u-D1 Dead Set No Standby
                                          by fharris1977
                                          Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                                          12-28-2023, 10:25 AM
                                        • Crystaleyes
                                          Samsung BN44-00259A standby question
                                          by Crystaleyes
                                          Hi all.
                                          I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
                                          SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
                                          Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
                                          The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
                                          08-11-2023, 05:15 AM
                                        • psssst
                                          Yamaha TSX 120 Standby Problem
                                          by psssst
                                          Hello forum. I've recently been given a Yamaha TSX 120 DAB radio and ipod dock. Its working well however when put on standby its using 6.3 watts. The manual states less than 1 watt on standby. I measured this with a plug in monitor which seems accurate with other items. In use it uses around 7.5 watts. Firstly has anyone who owns a similar radio also got a plug in monitor to check if this is normal with this unit? In the first half a second the monitor shows 0.3 watts which I suspect is what it should use but something is switching it to be almost fully powered. I've searched the manual for eco...
                                          03-01-2024, 07:25 AM
