Acer x241w
  • azeroid
    • 10
    Acer x241w
    I have an Acer x241w, which I purchased a few years ago. Recently it started failing (going black after a second or two) and when I opened the case, I discovered a bunch of bulged capacitors, which I promptly replaced with the good brand ones. The problem was resolved easily, however after one week of faultless service the monitor started to behave rather strange. When it is cold, it starts just fine and keeps going but if it goes to the 'stand by' mode or the power turned off I have to wait until it cools down to get the picture back. If I turn the power back on after a short time while it is still hot the screen goes black again in a few sec. I had to turn off the stand by mode completely and have it running for the whole day to avoid the problem.
    Sounds like a capacitor problem, but which one? I replaced all capacitors on the PSU and even the logic board (excluding the biggest one on the PSU board - looked fine) .
    Any clues?
  • jsog
    • Feb 2011
    • 220
    Re: Acer x241w
    It's not just the brand of replacements that matters, because manufacturers make more than one series. Use the wrong series on the power board, and they'll last for a while, then fail. Heat changes the way capacitors perform, and can cause this type of problem.
    The series is usually a two or three letter code printed on the caps, What brand and series did you use?
    Another heat-related problem is the solder joints on the transformers cracking.
    • azeroid
      • 10
      Re: Acer x241w
      I used Panasonic 105°C caps. I believe their are FC series.
      • jsog
        • Feb 2011
        • 220
        Re: Acer x241w
        FCs are good, probably okay. Did you also replace the small 5x11mm and 6.2x11 caps?
        • azeroid
          • 10
          Re: Acer x241w
          Yeah, replaced all of them too.
          • azeroid
            • 10
            Re: Acer x241w
            Just realized that I forgot about the caps on the inverter board. Maybe that's the problem?
            • jsog
              • Feb 2011
              • 220
              Re: Acer x241w
              Could be. Might as well open it up to check that and the solder on the transformers.
              • azeroid
                • 10
                Re: Acer x241w
                They do look slightly bulged - take a look at the attachments. I guess I am going to have to replace them. They are 180uf 30v but the closest I could find is digikey P11235-ND.
                http://search.digikey.com/scripts/Dk...name=P11235-ND.
                • jsog
                  • Feb 2011
                  • 220
                  Re: Acer x241w
                  Are those Teapo? What size and series?
                  • azeroid
                    • 10
                    Re: Acer x241w
                    Not sure about the brand. It is 180uF x 30V. I could not find anything FC series with this voltage at all. Any suggestions?
                    • alexanna
                      • Mar 2010
                      • 1346
                      Re: Acer x241w
                      http://search.digikey.com/scripts/Dk...80uf&x=27&y=21
                      look at these pay attention to height and diameter,they will need to fit where you want them to go
                      • azeroid
                        • 10
                        Re: Acer x241w
                        Thanks. I ended up ordering EEU-FR1V181 and EEU-FR1V181B from Mouser.
                        • azeroid
                          • 10
                          Re: Acer x241w
                          Looks like the monitor is working perfectly after replacing the caps on the inverter board. I attached the pics. Thank you everyone for the suggestions!
                          • jsog
                            • Feb 2011
                            • 220
                            Re: Acer x241w
                            Nice job!
                            • Ritalin
                              • Sep 2010
                              • 194
                              Re: Acer x241w
                              Azeroid, do you still have this monitor open? I just acquired one and it looks like some rookie put in caps the wrong way and different values. Any chance I could get a part location diagram? Primarily need one for the power supply, but other boards would be greatly appreciated!
                              EDIT:
                              Wow, just pulled out the inverter board and it looks like he hacked that up too.. the soldering on it is horse crap, but looks like the original caps :S Do you remember what brand they were and was your soldering really bad?
                              • Ritalin
                                • Sep 2010
                                • 194
                                Re: Acer x241w
                                Sigh, no love?
                                • PlainBill
                                  • Feb 2009
                                  • 7034
                                  Re: Acer x241w
                                  Originally posted by Ritalin
                                  Sigh, no love?
                                  Nope, no love. But https://www.badcaps.net/forum/showthread.php?t=16224 might be able to help you.
                                  PlainBill
                                  • RJARRRPCGP
                                    • Jul 2004
                                    • 6304
                                    Re: Acer x241w
                                    Yikes! Looks like X241Ws possibly use lesser quality caps than the X193Ws! lol wtf?
                                    ASRock B550 PG Velocita
                                    Ryzen 9 "Vermeer" 5900X
                                    Arc A770 16 GB
                                    eVGA Supernova G3 750W
                                    Alienware AW3423DWF OLED
                                      09-06-2024, 05:27 AM
                                      Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                                      This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                      09-07-2024, 05:00 AM
                                      Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                                      This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                      Acer Nitro Acer Nitro 5 Black Notebook 5 Specification for Upgrade or Repair
                                      This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                      09-07-2024, 04:10 AM
                                      Acer Swift SF314-511-56CX + Pack Gold Acer 14'' Notebook 3 Specification for Upgrade or Repair
                                      This specification for the Acer Swift SF314-511-56CX + Pack Gold Acer 14'' Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SF314-511-56CX + Pack Gold Acer 14'' boardview and SF314-511-56CX + Pack Gold Acer 14'' schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                      09-07-2024, 03:10 AM
