The big main filter cap
  • Rob Northen
    • Jan 2010
    • 137
    • Denmark
    Hello fellow forum brainiacs
    I've noticed that it seems vey rarely that the 400v (can be lover) main filter cap goes bad, and when the people give advice here, its almost also not to change this cap.
    Question is why ? Its often made by some crap company, where there other products fail.
    Is it beacuse there is very low load, current flow through it ?
  • jetadm123
    • 2169
    Re: The big main filter cap
    The reason being that the the large cap operates at a lower frequency (think mains frequency) than the smaller caps. The smaller caps operate at a higher frequency, which in turn causes them to run hotter and dry out.
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      They are right after input rectifier. (The caps are circled, other designs have only one.)
      All they do is smooth rectifier output which is low frequency.
      That's not that much work.
      Mann-Made Global Warming.
      - Dr Seuss
      • TheLaw
        • Jan 2011
        • 477
        They can die though, if they are 85*C of an oddball company, and are rather small.
        • Rob Northen
          • Jan 2010
          • 137
          • Denmark
          The frequency, I see. Makes sense. They will only be subject to the mains, 50/60 Hz
          And the smaller ones have to take switching Hz from the switching transformer.
          Thanks!
          • TheLaw
            • Jan 2011
            • 477
            Thanks!
            Well the smaller ones have to remove much higher frequency noise from the switching transistors and regulators on the secondary side...not the transformer necessarily.
            • cheeky2
              by cheeky2
              05-25-2024, 03:27 AM
            • Dani_2024
              by Dani_2024
              10-28-2024, 05:06 PM
            • acedogblast
              Power supply for main amp blows fuses after replacing filter caps.
              by acedogblast
              Hello I have a Marantz sr5012 that I have been repairing. After I have replaced the 2 main filter caps the 2 fuses for the power amplifier blows. The original capacitors are ELNA LAO 10,000uF 71V and the replacements are Nichicon LKS 10,000uF 80V.
              I assume a short circuit connection has occurred so I set my multimeter to measure ohms across the 2 fuse connections and both read 55 Kilo-ohms so I assume that is ok.
              I am certain that I do not have any bridges on my soldering and after probing around I do find a temporary 0 ohm reading when probing across the positive and negative...
              02-27-2023, 05:11 PM
            • ygorsan
              LG 55NANO77SRA TV – Menu scrolling by itself even after removing button board (Main Board EBU66792103)
              by ygorsan
              Hi everyone,
              I’m looking for help with a persistent issue on an LG TV model 55NANO77SRA, which uses the main board EBU66792103 (also used in LG UQ80 and NANO75/NANO80 series).
              🧩 Problem Summary:
              • The TV keeps scrolling through the menu or selecting items by itself.
              • I removed the physical button board (the entire panel with power and volume buttons) and also disconnected the flat cable (CN202) from the main board.
              • The remote control is not in use (batteries removed), and the TV still shows the same behavior.
              • I
              07-28-2025, 08:34 AM
            • Asraf Atb
              Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
              by Asraf Atb
              Hi everyone,
              Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
              Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
              I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
              01-27-2025, 05:02 PM
