Hi, I have 2 identical capacitors from an old scope I'm trying to get running.
Both caps measure ok in ESR and Capacitance values imo.
Data sheet says tolerance spec is -10 +50%. And these are way under that.
Both of there original values are marked as (430uf 200vdc).
After ~40 years, they now measure 485uf and 465uf. Well under the +50% tol.
Anyway I charged them up to 24 volts dc and discharged them slowly down to 10 volts using a Digital Multi Meter. Funny thing was one of them just took over 4 minutes to discharge down to 10 volts. And the other took over an hour to discharge down to 10 volts. I'm not sure about either of them now
What do you guys think?
