Measuring Voltages in a LCD monitor
+ More Options
Posts
  • Solder Boy
    • Nov 2006
    • 178
    Hi guys tried doing a search of this topic before making this post, not sure if the question has been asked before.
    I'm aware checking for proper voltage can be crucial when repairing LCD's just not totally clear on the proper way to do it.
    If you have the LCD disassembled.. where do you measure for the 12volt rail etc? What is the procedure? Example: when checking voltages to the logic board.. do you keep the connector between the power/inverter board on or do you do remove it?
    I read about putting the negative lead to a ground screw on the chassis, that much I understand.. just not sure where to insert the red lead.. do you insert it in the cable from the power board that goes to the logic board?
    Thanks again guys!
    www.bcrelectronics.ca
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Measuring Voltages in a LCD monitor
    I don't know if my way is "proper" especially for a person that has only been using a multimeter for 6 months, but I'll describe what I do.
    I look for the 12V (or secondary voltages) on the connector between the power board and logic board. I find it easiest to measure at the connector. I keep the boards connected.
    You can also find 12V DC on the dual diodes.
    For GND, I usually put my black probe on the ground screw that is closest to the connector.
    For the red probe, it depends. If the backside is facing me, it is pretty easy to just put the red probe on the various solder points off the connector.
    If the frontside is facing me, I'll usually use the connectors themselves.
    Hopefully that makes sense. If not, please ask clarification questions.
    --- begin sig file ---
    --- end sig file ---
    • retiredcaps
      • Apr 2010
      • 9271
      PS. For mains voltage measurement, I *was* using 2 hands (one for red probe and one for black probe) to measure the main filter capacitor, but I recently got some aligator clips/leads and will using these in the future.
      So I will clip on the aligator leads to the main filter capacitor and then hook up to my multimeter. Put it on V DC, double check my connections and only then, hit the power bar on button.
      With this new method, I'm less likely to get shocked if something goes really bad.
      • shovenose
        Send Doge Memes
        • Aug 2010
        • 6575
        Lol unless your dmm blows up!
        • Capacitorial
          Powersupply has all the voltages - Monitor still no power
          by Capacitorial
          Hello guys,
          I have a Philips 240B7QPJEB. The monitor seems completely dead.
          I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
          On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
          The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
          The weird thing is, that the Power LED is powered over the TCON board.
          On The TCON...
          12-28-2024, 02:12 PM
          by momaka
          03-15-2023, 10:17 PM
        • Rick_1234
          by Rick_1234
          Good evening, gentlemen.
          Things I tried
          06-22-2024, 04:44 PM
        • sew333
          Pc shutdown, monitor flickered with no signal after 10 seconds
          by sew333
          My pc:
          10850K stock 4800mhz stock Kraken X73 good temps
          2x16 GB DDR4 GSKILL 3000mhz XMP
          Seasonic Tx-850 Ultra Titanium
          Gigabyte Rtx 3090 Gaming OC
          Aorus Z490 Pro Gaming
          1 TB SSD
          4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
          Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
          Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
          Power...
          02-22-2022, 10:27 AM
          HP ProDesk DESKTOP BUNDEL (P5K01EA+M1N98AT) ProDesk 400 MT Intel Core i3-6100 + E232 monitor ProDesk 400 i3-6100 Specification for Upgrade or Repair
          This specification for the HP ProDesk DESKTOP BUNDEL (P5K01EA+M1N98AT) ProDesk 400 MT Intel Core i3-6100 + E232 monitor can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk DESKTOP BUNDEL (P5K01EA+M1N98AT) ProDesk 400 MT Intel Core i3-6100 + E232 monitor boardview and ProDesk DESKTOP BUNDEL (P5K01EA+M1N98AT) ProDesk 400 MT Intel Core i3-6100 + E232 monitor schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon...
          09-12-2024, 03:28 PM
