Hisense 50r6- no standby, no power, bad main board?
  • LemoneyF
    • Oct 2022
    • 5
    Hi all
    I have a Hisense 50r6 that quit suddenly, immediately after turning it on. It no longer shows red a standby light and will not turn on. Completely dead.
    I have tested the power supply and found the following:
    363V and 373V across the input caps
    bri- 0V
    ana- 0V
    vamp-17.03V
    vamp-17.03V
    stb- 0V
    12V- 9.3V
    12V- 9.3V
    To the extent of my knowledge (...not far!) these numbers are normal for a Hisense power supply in a standby state, though I would like some confirmation that 9v is normal!
    This is the exact power supply:
    http://www.mxmee.com.au/index.php?ro...oduct_id=11815
    I have heard that the main boards are known to go bad, and I have the opportunity to buy one. (not cheap).
    Is there anything obvious I am missing? anything I could try?
    Been a fantastic TV, hoping I can save it. Thanks!
  • nomoresonys
    • 12187
    • U.S.
    Re: Hisense 50r6- no standby, no power, bad main board?
    can you post a good clear picture of the legend/map of expected voltages of the powerboard, looks like its there by those 4 capacitors? or list each pin number along with the description beside it, looks like theres more than the 7 you listed.
    • nomoresonys
      • 12187
      • U.S.
      looks like something is amiss with those voltages, see if the one labeled stb is connected or not.
      • dskall
        • Oct 2016
        • 2905
        • usa
        Try heating main processor and then try turning it on.
        • LemoneyF
          • Oct 2022
          • 5
          Hi Thanks for the replies,
          Yes this is part of the problem I am having. I cannot find any information relating to expected power output from the board. I cannot recall seeing any information on the board but will look when I get home. Thanks.
          • Dani_2024
            by Dani_2024
            10-28-2024, 05:06 PM
          • JDC
            (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
            by JDC
            ONN 100012588
            Issue: No Power, Then Rebooting After Main Board Change
            Short answer: replace main board and power board
            Technical answer: replace main board and Q306 & Q307 on power board.
            Long answer:
            TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
            07-15-2022, 07:39 AM
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • Destroyer-Br
            [HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
            by Destroyer-Br
            Hi everyone,
            I'm working on an Acer Nitro 5 unit with the following specs:
            • Motherboard: LA-J871P Rev: 1B
            • Model: Acer AN515-55-59MT
            • S/N: NHQ7JAL00403906A973400
            • SNID: 03902728734
            Initial Issue
            The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
            After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled...
            04-17-2025, 08:18 PM
          • stylishconsultant
            un60j620dafxza - Samsung No Display Problem
            by stylishconsultant
            Hi All,
            Need help.
            I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
            So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
            problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
            might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
            09-04-2024, 03:26 AM
