COLORFUL GTX 1060 3GB- fire mosfet .please help me
  • conghuyms
    • Apr 2022
    • 46
    • Vietnam
    I have a COLORFUL GeForce GTX 1060 3GB that is not working. After replacing the NCP81174 ic, the card works again. but 2 mosfets Q625 and Q619 fire . Replaced 2 mosfets Q625 & Q619, still burned. the position I marked in the attached image.
    please help me. thank you so much
  • Prott
    • May 2022
    • 154
    • Czechia
    Re: COLORFUL GTX 1060 3GB- fire mosfet .please help me
    Check the resistors and capacitors attached to that phase. Some of them might have changed their values. You can also check the drivers of that phase - first visually but also try to compare resistances to other phases.
    • DynaxSC
      • Apr 2021
      • 468
      • Poland
      I would guess the driver of that phase is broken, check the resistance on the power supply pin of that driver, and check it against other drivers. To do it correctly you have to remove the serial resistors (usually 2.2 ohms) in series to the power supply pin to that driver. If no serial resistor present, you have to remove 2 drivers from the board, and check them off-board (tricky). Sometimes is the driver has a short on power supply pin, the serial 2.2 ohms resistors may become seriuosly decalibrated (eg 50 ohms) or even burned with no conductivity. Second check you can do is after replacing the bad mosfets, check the resistance on the gates of the three mosfets, they should be same as on other phases (usually 10 kohms to even Mohms, depends on card) - but do not power the card. Check also the resistance on the GPU Vcore, it should be over 0,15 -0.2 ohms - you would need to have a special low resistance meter to do this exactly, any usual meters are not suitable to measure such low resistances. If during the fire of the mosfets the GPU got a too high voltage (over ca 1.2-1.5V) then the GPU might be dead. This can happen, if the high side mosfet is the first which becomes shorted, and puts the full 12V voltage on the GPU. Anyway if you fix the VRM, you will know if the GPU is good or dead. A dead GPU will have a total short, so VRM should should shut off or limit the current, and no VCore will be present.
      • conghuyms
        • Apr 2022
        • 46
        • Vietnam
        thank you my friend, it's working
        • conghuyms
          • Apr 2022
          • 46
          • Vietnam
          Thank you very much ! My friend
          • kotel studios
            Intel D865PERL - no Vcore after replacing MOSFETs and MOSFET drivers
            by kotel studios
            Finally got time to fix this board up.
            At first it didn't give any POST codes. Turns out it was an unsupported Celeron D cpu. After dropping in an Celery 2.6gHz the CPU came out of reset with clock signal, but still no post codes. For a while it did work when I applied pressure to the ADP3168 chip, but on next reboot the MOSFETs started to burn. Then I left it as is for months.
            Now I came back prepared. Replaced the bad MOSFETs and the ADPxx18k drivers. Now I don't get any MOSFETs blowing up issues anymore. But sadly, the Vcore is missing. The whole VRM isn't...
            04-22-2025, 05:08 AM
          • Jane
            How do you test MOSFET in laptops ?
            by Jane
            I tried to use this method:
            Testing an N-channel MOSFET:
            Step 1: Discharge the Gate (turn off the MOSFET)
            Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
            Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
            Step 2: Charge the Gate (turn on the MOSFET)
            Now, place the red probe on the Gate (G) and the black probe on the
            09-27-2024, 03:31 AM
            Gigabyte AERO 14W-1060-BK7 Notebook Specification for Upgrade or Repair
            This specification for the Gigabyte AERO 14W-1060-BK7 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14W-1060-BK7 boardview and 14W-1060-BK7 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
            09-06-2024, 05:46 AM
            Gigabyte Sabre 15-1060-803 Notebook Specification for Upgrade or Repair
            This specification for the Gigabyte Sabre 15-1060-803 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15-1060-803 boardview and 15-1060-803 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
            09-06-2024, 11:44 AM
            Gigabyte Sabre 17-1060-803 Notebook Specification for Upgrade or Repair
            This specification for the Gigabyte Sabre 17-1060-803 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 17-1060-803 boardview and 17-1060-803 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
