ACER Swift 3 SF314-52-51KE dead
  • diamon
    • 107
    • Netherlands
    I have a ACER Swift 3 SF314-52-51KE (Main Board SU4EA) that's dead.
    No charger led or power led, when the charger is placed.
    I have 5.15V on L8100 coil and 3.33V on L8101 coil.
    When pressing the power button, the voltage drops from 3.25V to 0V on the power button.
    On coil L8800 I get 3V, on the following coils there is no voltages present: L8300 / L8201 / L8002 / L8000 / L8001
    I have attached the boardview and schematic of this board.
    Could use some help
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: ACER Swift 3 SF314-52-51KE dead
    Check the supply U9101all pins expected GND and note down
    EC pin 25 112 supply as you press the PWRBTWN ? Make sure VCC RTC & SW RTCRST supply is fine & no short
    • diamon
      • 107
      • Netherlands
      Thanks for your answer.
      Have done the measurements:
      U9101
      1 3.34
      2 3.34
      3 no meassurement
      4 5.16
      5 no meassurement
      6 3.34
      7 3.34
      8 no meassurement
      9 no meassurement
      10 no meassurement
      11 no meassurement
      12 no meassurement
      13 no meassurement
      14 no meassurement
      15
      EC IT8987E/BX
      pin 25 2.77 not with pressing power button
      pin 25 nothing happends when pressing power button (it's still 2.77)
      pin 112 no meassurement
      pin 112 no meassurement when pressing power button
      VCC RTC 2.99v
      SW RTCRST (location for part R2406 is not on the board. No power on de Gate of Q2401)
      Do have 2.9V on the drain and source has no power
      • Techtiger
        • Oct 2014
        • 1602
        • france
        EC pin 112 is not responding let’s do some further testing find out bios ic U2801 note down the voltage all pins after you need to test EC requirements
        Pin 11 74 14 120 17 16 19 (87 107 when pressing power btwn )
        • diamon
          • 107
          • Netherlands
          Done the measurements:
          U2801
          pin 1 2.57V
          pin 2 1.06V
          pin 3 1.68V
          pin 4 gnd
          pin 5 3.33V
          pin 6 2.53V
          pin 7 2.75V
          pin 8 3.33V
          U3001 > T8987E/BX
          pin 11 0V
          pin 74 3.28V
          pin 14 3.24V
          pin 120 3.12V
          pin 17 3.27V
          pin 16 0V
          pin 19 3.27V
          pin 87 no meassurement, also not when pressing power button
          pin 107 3.28V and when pressing power button it goes to 0
          • Techtiger
            • Oct 2014
            • 1602
            • france
            back up old Bios bin and flash bios may be due to bad bios since pin 112 U3001 no reaction for power BTWN.
            test some supply's again U3001 pin 14 when pressing power btwn
            pin 127 26 128 supply ?
            voltage on +AC_bat_SYS ?
            U9101 PIN 14 8 Impedance with out power ?
            SRTC_RST voltage ?
            • diamon
              • 107
              • Netherlands
              U3001 > T8987E/BX
              Pin 14 pressing power btwn: nothing changes (still 3.24v)
              Pin 127 pressing power btwn: nothing changes (still 3.28v)
              Pin 26 pressing power btwn: nothing changes (still 3.26v)
              Pin 128 no measurement
              voltage on +AC_bat_SYS: 19.37v (have measured this on a couple of point on the board according to the schematic)
              U9101
              Pin 14 Impedance with out power 730K
              Pin 8 Impedance with out power 7.14K
              voltage on SRTC_RST: 2.98v
              Regarding backup old bios and flash bios, I have a EZP2019+ programmer.
              Can I just read the current file and save it, do I have then everything regarding the bios?
              On https://www.acer.com/ac/en/US/conten...t-product/7226 I have found different bios files, but which one do I need and how can I flash this (they are exe files).
                • 21993
                Backup your bios and post it in this thread https://www.badcaps.net/forum/showthread.php?t=75687
                • diamon
                  • 107
                  • Netherlands
                  I have uploaded the current bios file that's located in the bios chip, in the topic you provided me.
                  • Techtiger
                    • Oct 2014
                    • 1602
                    • france
                    Update one's you flash bios with a working one
                    • diamon
                      • 107
                      • Netherlands
                      I have removed and programmed the chip with the version that's provided in https://www.badcaps.net/forum/showth...28#post1115928
                      Placed the chip but nothing has changed.
                      • Techtiger
                        • Oct 2014
                        • 1602
                        • france
                        how many bios bin files did you try ? what the the supply TP_SENSOR_OFF ?
                        • diamon
                          • 107
                          • Netherlands
                          I have used one bios file, only the one provided in https://www.badcaps.net/forum/showth...28#post1115928
                          All the measurements I have done, with the board on the workbench (so not in the laptop)
                          D3101 1.22v
                          D3103 is not placed on the board
                          The battery is dead, no voltages present. Can I charge the battery with my lab power supply (delta electronics ES030-05) ?
                          • Techtiger
                            • Oct 2014
                            • 1602
                            • france
                            D3101 1.22v
                            Your problem is no Communication between Bios & ÉC may be due to bad EC
                            You must try with a another bump leave the battery for the moment
                            • diamon
                              • 107
                              • Netherlands
                              I have used the following dumps, but still the same behavior > motherboard still dead.
                              https://www.badcaps.net/forum/showpo...2&postcount=14
                              https://www.badcaps.net/forum/showpo...23&postcount=2
                              https://www.badcaps.net/forum/showpo...98&postcount=5
                              https://www.badcaps.net/forum/showpo...4&postcount=13
                              I did a quick search for this EC chip and this specific SU4EA board / laptop model, but did not find anything available (and it needs to be programmed also of course).
                              Any suggestions how to check if the EC chip is dead or something between the EC chip and bios chip ?
                              Did find on some websites, that some laptop motherboards will not start (looks dead) when there is no battery is connected / or a decent charge in the battery available.
                              • Techtiger
                                • Oct 2014
                                • 1602
                                • france
                                for the battery part i have come across some MB with out the battery no power but in you case there is no commutation Bios and EC pin 112
                                conforms it if EC is short it will get hot when you touch it or when you put 100% alcool it will move around
                                do you have another BIOS chip to test ? discharge the EC take a wire with out power remove bios battery one end to GND other to one by one all pin take a around this will discharge EC and try again power up
                                • diamon
                                  • 107
                                  • Netherlands
                                  The EC is not getting hot when the charger has been placed or when I press the power button (I used IPA and my fingers).
                                  I have used two other 25Q64 chips and used 4 bios versions, still the same.
                                  Did the discharging of the EC like you mentioned, but also then still the same.
                                  Which parts are all between the EC pin 112 and the bios chip (which pin of the bios chip communicates with pin 112) and is it possible to rule this parts out?
                                  • Techtiger
                                    • Oct 2014
                                    • 1602
                                    • france
                                    Can you test the cristal X2402 32.766 khz is working or not ? is the power led working ?
                                    • Techtiger
                                      • Oct 2014
                                      • 1602
                                      • france
                                      For power led
                                      • diamon
                                        • 107
                                        • Netherlands
                                        I don't have a scoop to test if the cristal is working, the power led does not work / does not give light when pressing the power button or placing the charger.
                                        On IR24 I do have 3.84v and IR25 i have 4.39v, and I also measure this on the led itself (blue / orange) (with the diode test on the multimeter, the blue and orange does give light).
                                        IC20 is not on the board, but from +5VSUS_PWR (at pin 1 from IC20) I do have 5.16v
